Question about PNY Verto GeForce FX 5200, Graphic Card
I have a blank screen
When i install the graphics card drivers and reboot my computer my grub loader displays and my windows load screen displays but after the load screen goes away it stays black but i can hear windows loading.
  • egregious Mar 20, 2008
    I had to go in and disable my on board video device. FIXED thanks anyway
  • 57 Answers
Glad you got it fixed. Next time something like this occurs, try searching the forum of your distro (or the Ubuntu forums as they seem to have just about every error ever listed in there) as you will usually find the answer faster.
Posted on Apr 09, 2008
Monitor works only in safe mode
graphics problem on your desktop is malfuctioning, after the computer turns on it uses all the drivers for your monitor which if broken or wrongs drivers will cause the display to be blank,
when using it in safemode it only loads the basics. try un installing the drivers for your graphics card in safemode, "with command prompts" and let windows download the correct one
Mar 04, 2014 | HP Pavilion F1703 17" LCD Monitor
My graphics card does not show up on my Device Manager
I had just run into the same problem while installing my new graphics card earlier today. This is what I did to fix it:
1. Uninstall the new driver for the new card, if you can, in control panel if it installed.
2. Reinstall the new driver.
3. Go to Device Manager and UNINSTALL, not disable, UNINSTALL the on-board card. Don't worry this won't kill anything. It will ask you to restart your computer. Click yes.
4. While the computer is restarting and on the shut down screen for windows unplug the monitor cord from the onboard card and plug it into the new card.
5. Wait for windows to boot up and load the new drivers. It should be working with the correct drivers.
If it takes more than 8 minutes for anything to come on the screen(icons, login screen, etc.) reboot your computer again.
Apr 08, 2013 | PowerColor Go Green AX5450 512MK3-SH...
Black/blank lcd screen after 2 seconds
try this - boot into "safe mode" - (this loads just minimal drivers). Reboot and press F8 while it's booting - it will ask if you want to boot into safe mode - say yes - if the screen works with the low resolution inherent drivers, it's probably a driver issue, or if you have a video card, it may not be able to work at the higher resolutions (which could be a card issue)
This should help you narrow down if the screen actually works, or if it's a graphics card and/or driver issue.
If it works - try reloading the driver for your graphics card (if you don't have a graphics card - try reloading both the chipset driver and the video driver from the manufacturer)
let me know if this works...
(I had a Toshiba Tecra laptop that did the exact thing - you could see the Windows boot menu, and once it completed boot up, the screen would go black - if you started it in safe mode (crummy resolution) it worked but of course the graphics are unacceptable at that resolution)
Turns out this is common with those, it was the graphic card built into the motherboard that's shot....
Oct 21, 2009 | Dell D1728D-LS VS17X Monitor
Cannot access XP after Ubuntu Installation
- reboot with LiveCD
- in CMD run command fixmbr, fixboot
restart, load Windows XP.
OR in Unbuntu Grub write XP portition
Aug 20, 2009 | Computers & Internet
Blank Monitor
I have the same system and card. The problem is the system is trying to run two monitors at once. Use Windows safe mode (F8 during boot) to uninstall any Pny drivers you may have put on. Reboot. Install the pny drivers again. Before rebooting, use the device manager to look at the display drivers. There should be two, an Intel one, and the pny Nvidia one. Disable the intel driver and reboot. Worked for me. Youmay also want to upgrade the power supply. The 3000 has a 225W and the 8400 card wants at least 300W.
Mar 28, 2009 | Computers & Internet
Flatscreen goes blank and displays the message
Out of range indicates that the refresh rate or resolution is set too high for the monitor to display. I would suggest re booting into safe mode by pressing F8 during boot, before windows begins to load. Select safe mode with networking if you can, and once in safe mode, uninstall the ati display driver from the control panel. Then go to ATI's site and download the latest driver for your card. Save that file to your desktop. Reboot normally, as Windows should load default vga drivers for your card. Once in Windows, install the latest driver you just downloaded. That should reset the resoultion to one that your monitor can display. Good luck:)
Jan 02, 2009 | ATI RADEON X1650 Graphic Card
Display blanks after installing drivers
Try the final AMD Display Driver (version 8.31) downloaded directly from AMD for the Radeon 9250 series running in XP. It will be several years more recent than any provided in Windows XP (by Microsoft), and may just fix your problem. The fact something causes XP to identify your Radeon 9250 as a 9200 Pro shows that something is not right. You might also want to launch Device Manager, use the option to show hidden devices, and delete any "ghost" video cards. I suspect a 9200 Pro may be a ghost, which could be causing problems.
Sep 13, 2017 | GeCube Computers & Internet
Screen going blank for a second or two while video freezes then jumps.
If you have on board graphics try removing video card and reboot when computer rebooted turn it of and refit card and restart when restarted computer should recognize new hard ware and should find the already installed drivers if not try installing drivers again
Sometimes windows does not recognize new hardware until its refitted
had this problem with modems alot and the above method solved it
Jul 31, 2008 | ATI RADEON X1650 Graphic Card
No post (blank screen) after intial driver install Acer 1716 LCD monitor
Please clarify something for me, after installing drivers, system reboots, and you have no POST information or startup screens at all?
Dec 15, 2007 | ATI RADEON 9550 Graphic Card
Open Questions:
See all PNY Verto GeForce FX 5200, Graphic Card Questions
PNY Verto GeForce FX 5200, Graphic Card Logo
111 people viewed this question
Top PNY Computers & Internet Experts
Alun Cox
Jim Thurston
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
