Question about Teac (DW-224EA-AM6) CD-RW/DVD-ROM (Combo) Burner
Issues with my cd/dvd drive
My drive was opened and i accidently yanked on it with my pant leg and it came off the tracks, so i took it apart and fixed it, but in the process i had to unplug it and when i plugged it all back my computer says there is no cd drive detected...but it opens and closes like i fixed it. just cant use it anymore...someone please help!!!!!!!
    Genius:
  • 1,554 Answers
Go into the bios and see if it has the drive detected,
if dell go in get out and save.
Posted on Mar 20, 2008
My DVD Writer/CD Writer Combo got hung and I pulled out the tray
yes it is repairable but best way to get it repair is get it to some professional only
Nov 20, 2009 | Computers & Internet
My xbox keeps on reading open tray when i put a disc can any one help me
Mine had the same problem. On mine the spindle wasn't turning the game. It kept trying to then quit and said "Open Tray". The warranty was out so I took it apart opened the dvd drive and took apart the spindle. The grease in the spindle was black, I guess from all the heat. Cleaned it out and put some high temperature grease on spindle shaft and in the hole. It now spins with ease. There are videos on youtube on how to take apart the xbox and to take apart the dvd drive and spindle. Just pay close attention at how tight the screws the hold the spindle down are.I hope this helps.
May 16, 2009 | Microsoft Xbox 360 Pro System Console
DVD/CD drawer does not open when button pushed - Averatec 3360
this is an issue with the tray release, built into portable disk drives. I would recommend replacement or repair by a good technician.
-this is not a software or firmware issue.
-this is an actual physical damage to the tray mechanism itself.
hope this helps you out.
Dec 22, 2008 | Averatec 3360-EH1 Notebook
Bonnett on 1999 daewoo nubira stuck down after minor accident
Have a helper pull the latch as normal. Don't yank it!! Then press the 'bonnet' down. If it dosn't open, push the hood down and toward the damaged side. Frankster016
Oct 10, 2008 | 1999 Daewoo Nubira
I have a HP media centre pc, which has a lightscribe DVD writer/CD writer. It will only run certain cd's, most of the time it will not recognise there is a disc in the drive. The drive will start up,...
unfortunately it's a sure sign your drive is faulty, the noises are the laser trying to read the tracks, cd's can be easier read than dvd's because the tracks are wider apart, whereas dvd's data is packed tighter together and the reading is more difficult for a faulty laser, you will need to replace it or buy an external usb writer.
Sep 08, 2008 | HP Computers & Internet
Wont unlock
Usually when the drive door won't open in either a DVD player or a CD player, it's because someone has put a CD or DVD that was not seated correctly in the tray, and once the tray closed the disc caused it to jam.
The only other causes are the mechanism. If it uses a belt to open the drive tray it may be slipping. There could be a broken or misaligned gear, or the tray may have come off of the track or rail it slides on. In these cases the unit would have to be taken apart and repaired.
If it contains a misaligned disc, you will have to take it apart, and remove the top from the drive. Then remove the disc and reassemble the unit.
If you're really lucky, the manufacturer may have put a small hole at the front of the drive. It almost looks like a pinhole, but slightly bigger. If you push a piece of wire (like a paperclip) into the hole, it may force the tray open for you. However, if there is no hole, the drive will have to be disassembled.
Jan 31, 2008 | Fisher DVDS1100
XBOX 360 Console
Your issue is likely a dirty lens. First step, try a DVD lens cleaner, if not, you may have to take the drive apart to manually swab the lens with some rubbing alcohol.
Nov 07, 2007 | Microsoft Xbox 360 Console
Message "To play game put game in xbox 360 console"
Pick up in the DVD is bad or weak and will need replacing.
Or replace the whole DVD unit.
Make sure the disks are clean and not too scratched up
Check here for more things to try
CD drive stuck please help!
Hi I guess ya mean that the CD tray will NOT open? If this is the case... then ya can "Open" it by way of a paper clip straightened... and then insert one end into the hole provided, on the front of the CD... There is a small hole usually just above the LED, inset & push it in until the mechanisim releases.. the tray should pop open and ya will B able to recover ya DVD...
Aug 30, 2007 | LG (GCR8525BK) Internal 52x CD-ROM Drive
Teac (DW-224EA-AM6) CD-RW/DVD-ROM (Combo) Burner Logo
Top Teac Computers & Internet Experts
Starnley Johnwells
Starnley Johnwells
k24674
Are you a Teac Computer and Internet Expert? Answer questions, earn points and help others
