Question about Maytag Freezer MQU2057
Maytag freezer Our 3 year old freezer was making a loud noise off and on for about a week and then it stopped making the noise. Now the items on the inside door are thawed out but after a week the items in the freezer on the bottom three shelves are still frozen. When I turn the temperature to colder I do not hear the motor turn on as I usually did. There is water coming out of the botom corner of the freezer. Is the freezer worth repairing?
  • Anonymous Aug 17, 2008
    Model MQU2057ASWL1 - Our loud noise started this morning. We turned it off so ice could melt if that is the problem. After several hours we tried it again and the noise continued.
    History: There was an initial problem when we purchased the unit - something to do with the thermostat. That problem was corrected after a few months and we were told that there was an internal problem that had nothing to do with the initial installation. (2004). We had another problem in 2006 which seems much like the one we are now experiencing. A new part was ordered and installed. According to information we received then this may have been the result of the initial problem.
    Thank you.
    President:
  • Maytag Master
  • 2,651 Answers
Sure its on ly 3 years old. you rseled system should be covered for 5 years (compreessor, freon, evap, condesor). was it making a buzzing noise?? trying to start and clicking right off??? thaose are sounds a bad compressor makes,
Posted on Mar 19, 2008
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
Nov 04, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
The fan motor makes a noise when it's running. I'ts 7 yrs old.
The noise could be the blade is coming loose on the shaft. It would need to be tightened. Or it could be it is striking the frame.
Feb 21, 2013 | Maytag Freezers
I have a upright frostfree Woods freezer. It is only around 4-5 years old and this year it is making very loud running noises. It is not keeping things fully frozen.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Mar 15, 2010 | Woods Upright Freezer MU07W
Loud buzzing noise doesnt stop freezer is still working everything still frozen, just loud noise coming from back bottom of freezer where the parts are, and compressor is very hot to the touch. freezer is...
Locate what is making the noise. There is a fan in the freezer behind the rear cover inside. There is a fan underneath accessed from the rear behind the cardboard backing. The compressor is also there with a starter/overload relay which could make the noise.
Aug 20, 2009 | Frigidaire 20.6 cu. ft. Upright Freezer...
My upright freezer is making a loud screaching noise something like a car's slipping fan belt makes in winter. It is still freezing but sounds like something is on the way out.
If you have the model number you posted under, you are looking at replacing the evaporator fan motor, which would be a part number 4309014 for that Maytag MQU1556A. It is located inside the freezer, behind the lower back wall.
Jun 22, 2009 | Maytag 15 cu. ft. / 425 liter Upright...
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Oct 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Noise Problem
Is it a frost free freezer ? if it is it sounds like the evaporator fan motor making the noise
Aug 29, 2007 | Danby 16.7 cu. ft. / 473 liter Upright...
Maytag Freezer MQU2057 Logo
354 people viewed this question
Top Maytag Freezers Experts
John Tripp
John Tripp
christian nielsen
Ismael Rodriguez...
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
