Question about Dishwashers
WHEM I START MY IGNIS DISHWASHER IT STARTS TO FILL THEN FROM THE RIGHT HAND CORNER CLEAN WATER STARTS TO LEAK OUT . I LOOKED AT THE DOOR SEALS AND THEY SEEM FINE I HAVE ALSO PUT IN A NEW FLOAT SWITCH AND STILL THE SAME PROBLEM ! COULD IT BE THE INLET VALVE ? HELP THANKS MANDY
    Sergeant:
  • 351 Answers
It sounds like it overfilling,it may be a preesure switch problem.if you turn the dishwasher off the valve should stop if it doesnt then its the valvle.you may have to try cleaning the sunp under the filter.it may be clogged with sludge stopping the pressure switch from working.you shold hear a click when the switch activates.its difficult without being there.hopr this helps.
Posted on Mar 20, 2008
SOURCE:
Maytag dishwasher dwu7400aax leaks water from lower right corner of door
Possible that the door seal is worn out , check for leak at the bottom to confirm this case. Click on : Door seal
Jan 25, 2013 | Dishwashers
I have a kitchenaid dishwasher model KUDMOITJBLO installed as new unit in Oct. 2002 in a new home. Current problem is water coming from front door, bottom as unit starts wash cycle after filling. Leak is...
Hello, Thank You for using FixYa. I will be helping you today.I would start by removing the outer door panel remove the screws around the inner door to do this.Then close the door and start a cycle. Sometimes you can see obvious signs of leaks just by removing the panel too. But if not let it run and see if you see water leaking anywhere. You will see water in the bottom corners its normal. If water is splashing over those corners the check the lower spray arm gor damage or cracks it can cause this problem also make sure the screws under the spray arm are tight. also check the upper arm.
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | KitchenAid 24 in. KUDM01TJ - Multiple...
At some point the dishwasher leaks onto the floor. what could be the possible problem?
this are the possibilities for the leak :-----
Door gasket loose/torn
Corner gaskets or door baffle/vent gasket
Door lock/latch loose/broken
Split spray arm
Over filling with water...usually the level is just under the heating element is normal
Something leaking through the door...like the soap or rinse agent dispenser gasket, silverware basket button.
Door hinge(s) bent
Wrong soap was used...dish sink soap instead of dishwasher soap
Rinse aid being used with mechanically softened water ( makes foam or suds inside the dishwasher )
Leaks from under the unit:
Look for whiting or calcium stain on the motor and pump assembly = motor and pump assembly seal leak...access panel removal help
Hose for upper spray arm split
Fill hose split or fill hose spout air inlet is calcium covered
Drain hose is split
Rusted liner...metal liners only
Fill valve leaking or allowing water to fill all the time
Heating element ends....where they come out through the dishwasher liner
Float or float gasket.
Sep 23, 2009 | Whirlpool 24 in. GU980SCG Built-in...
Dishwasher leaking
just an idea...if i'm understanding you correctly,could the door seal be creased there or folded over by use and age to permit this to happen? cause you said nothing is missing
Aug 28, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Maytag Jet Clean leaking through right side of door during rinse
It is important to examine the leak to see where it probably originates.
If the water is leaking from the right hand side of the door on your dishwasher, it is time to replace the gasket that seals the door when the door is latched.
Aug 10, 2009 | Dishwashers
LG LDS 5811 has started leaking at the bottom of the door left hand corner.
Could be 1 of 2 things.
1: Open door and look for any" Obstruction" Between the Door Seal and the Dishwasher.
2: the Seal is Warped from General useage or, twisted.
hope that helps
Please Rate Me
George
Apr 30, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Maytag mdb6000awb built-in leaking problem
it can be 3 problems. Most likely one is the seal from the acces apnel is leaking.
Or hinge of door is too lose or door seal.
My bet is on the seal for the acces panel.
HERE is drawing. However seal (#12E) is not drawn in.
You can also order the parts here and have them within about 3 days
Jun 29, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
GE Nautilus
make sure the door is not hitting on cabinet when shut.
Dec 31, 2007 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
245 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
