Question about Toshiba RD-XS35 DVD Recorder/HDD Recorder
Dvd drive bad disk error Toshiba RD-XS54 Hard drive/DVD recorder
I need a replacement DVD Drive for this and they no longer make or sell the exact drive. A newer version is available but I have found no Info on if it works the same or at all.
snakehead
  • 1074 Answers
SOURCE: D-KR2 writes bad disks
you are having problem with your lens and the microchip.you will need to replace them soon. the malfunction is a warning that a repair will have to take place.the problem is intermittent at this time.soon you will have no function.good luck
Posted on Jun 17, 2007
SOURCE: DVD Burner will not read disks.
Hi ****,
I've one of these machines too, and you've stumbled upon the one flaw that lets the machine down. In my experience the only way to solve this is to:
1/ Eject the DVD
2/ Turn the machine off (standby mode)
3/ Unplug from the wall for at least a minute or 2
4/ Reconnect the machine, leave it at least a minute in standby mode.
5/ Attempt to play a known 'good' (commercial) DVD
This usually works although I have occasionally had to repeat the process. Hope this helps, regards,
Lone Starr
(Rust Never Sleeps)
Posted on Mar 16, 2008
jaffa012001
  • 376 Answers
SOURCE: i am unable to find
RD-XS32
DVD-R
DVD-Rw
http://www.videohelp.com/dvdplayers?DVDname=RD-XS32&Search=Search&dvdportable=&dvdchanger=&dvdtv=&chipset=&orderby=Name&hits=50
RD-XV45
DVD-R
DVD-RW
The link tells you about the first player. It says that this player is really picky with discs but people have had success with 4x vertabrim DVD-R discs. The link also has some information on a firmware upgrade to improve the DVD-R/RW selection of discs which the player accepts. Coudn't find much on the second player though other than a french manual which told me what it accepts which i've put above. Hope this helps.
Posted on Aug 20, 2008
  • 26 Answers
SOURCE: err-14
http://www.avsforum.com/avs-vb/archive/index.php/t-579864-p-2.html
Hope this helps
Posted on Sep 26, 2009
SOURCE: I need a user manual for a Toshiba RD XS 25 DVD Recorder
Go to tesc.toshiba.co.uk select "customer access" on bottom left, then select what model, etc and there you go.
Posted on Feb 16, 2010
How to recover deleted video from toshiba rd xv48dt hard disk?
try hard drive data recovery software, recommended Asoftech Data Recovery which helped me before. You may take a look at this hard drive data recovery guide that helped me before
How to recover deleted video from hard drive
good luck!
Dec 07, 2012 | Toshiba rd xv48dt
Error message
ERR-15 hard drive error. need to replace hard drive also it would be easier if you just take it in a repair shop
Sep 10, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Where can I get a fireware update CD for my RD-XS54?
Do you have a computer that can burn CD's? If so you can download the iso file here and burn your own:
http://tacp.toshiba.com/customersupport/model_firmware.asp?model=rd-xs54
May 04, 2011 | Toshiba RDXS54 DVD Recorder/HDD Recorder
I have a Toshiba RD-XS27KE DVD/VR. It does not perform any recording on the HDD - error code E49. I have deleted titles and it still does not record. What can I do ?
I fixed it by 1. delete all on HD drive (a function described at the end of your manual) 2. turn off your recorder 3. turn on your recorder 4. now should E49 not be vivible and recording function again
Jan 31, 2011 | Toshiba RD-XS32 DVD Recorder
Toshiba RD-XV48DTKB HDD&DVD/Video recorder. I am having trouble dubbing a VHS home recording onto DVD. It records for 20 minutes then it stops and comes up with message that further recording is not...
Perhaps it is a limit of that software? Is it a "Trial" ? I also suggest you use another type of program see if that one will record longer, also it may simply be either or both NOT enough, RAM &/or Hard Drive space. You need HEAPS of memory when doing any Video work. To do stuff such as this you would need at least 4GB RAM and at least 50 - 100GB FREE Hard Drive space.
Feb 15, 2010 | Televison & Video
I have stand- lone Toshiba DVD Recorder/player model No RD-Xs32SU which has a Maxtor Diamond Max 16 80GB HDD. This drive is kaput. I am looking for a replacement, and information on whether the DVD Rec...
The answer is to replace the hard drive with exact same specs (80GB, ata 133,5400rpm) formatted Fat32 and completely empty. Machine will format/recognize it and will be operable.
May 27, 2008 | Televison & Video
Hi ****,
1/ Eject the DVD
Lone Starr
(Rust Never Sleeps)
Mar 16, 2008 | Toshiba RD-XS34 DVD Player/HDD Recorder
Toshiba tech support for this one. If it is not accepting the cleaner disk - you have to wonder if something is already intere or do you mean will not rune the disk? Inwhich case it is a drive failure and needs replacement[of drive if available] or whole machine. Contact Toshiba first though it may be a known issue.
Jul 05, 2007 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Toshiba DVD recorder problem
Generally, this problem is caused by bad sectors or other problems on the hard drive and can be resolved by going into the setup menu and re-formatting the hard drive. Of course, all recordings on the hard drive will be erased, so spin them off to dvd first. Be sure to have unplugged and replugged the unit immediately prior to going into the setup menu (don't try to record anything). If this doesn't work, no-one will repair this unit locally, as it must be returned to Toshiba's(TACP) depot for repair. Best of luck.
Feb 02, 2007 | Toshiba RD-XS52 DVD Recorder
Toshiba RD-XS35 DVD Recorder/HDD Recorder Logo
327 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
