Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Ryobi cs30 rope problem
I just recently bought a ryobi cs30 weed eater, used it for about an hour, now the rope is stuck and I am unable to pull it all the way to start it. What can solve this problem? Thanks in advance.
--Roy
  • 3 more comments
  • pick pock May 02, 2008
    I have the same problem
  • Anonymous Jun 09, 2008
    Can't remove spool. Please advise. Thanks
  • motherof7 Jul 31, 2008
    We have a ryobi weed eater and the pull cord is stuck,It only goes part of the way, so we cant start it. We didnt do anything to it,afraid it would do more dammage.
  • Anonymous Oct 12, 2008
    I just bought this yesterday - having the same problem - stopped to change from the edger to the weed wacker and now I cannot pull the string to start. Any advice?
  • ehsling Dec 26, 2008
    Hi, my starter rope for the Ryobi line Trimmer (model RLT 30CDN) has broke! Could you tell me how I could replace it on my own? Thanks!
  • 163 Answers
Try removing the starter housing, inside will be a large white or black wheel, visually inspect to make sure the componets are not damaged and that nothing jamming it. try using a lithium spray grease to lubricate the componets. if it still doesn't work the inner coil is probably damaged or came off track. it is very difficult to fix or replace this coil. i suggest taking to your nearest service center but if you would like to try it yourself, let me know and i will give you further instructions.
Posted on Nov 29, 2008
What is the factory carbuerator settings for ryobi cs30 weed eater
The Walbro WYC-9 only adjustment is the idle speed. This is just slow enough for the trimmer head clutch to disengage.
Feb 04, 2015 | Ryobi Garden
Weed eater featherlight XT260 rope pully
Your recoil could be messed up if you cant pull the rope out or if its just too hard to pull out you could have it too tight.
Jul 29, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
My Ryobi cs30 weed eater tends to shut off after I release the throttle.
Find the idle speed screw (not the jet screw) and turn it CW until the engine idles without dying. If too high, the string head will turn all the time. Hope this helps
Sep 06, 2010 | Ryobi Garden
Cant pull the rope but when you take the spark plug out the rope will pull
Sure its the correct spark plug? Sounds like the piston is coming in contact with the spark plug.
Aug 13, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How to remove drum connector off ryobi weedeater
I believe there are four phillips headed bolts around the outside edge of the housing
Jul 23, 2009 | Ryobi Garden
What is the fuel mixture on the ryobi cs30 weed eater?
Mine says 50:1 on the gas cap. It's a 2006 CS30. Model #RY30120.
2.6 oz of 2cycle oil to i gallon of 89 octane fuel is what i use and have no problems
Jun 30, 2009 | Ryobi Three Trimmer Combo
Have a Ryobi CS30 Weedeater, will not start, it is about a year old, did not see a spark, just bought new plug.
If you still don't have a spark with the new plug, then you may have a kill switch wire grounding the motor, keeping it from starting. If it's not that, then you have a bad ignition module (coil).
Jim
Jun 07, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a Ryobi Reel Easy bumb feed stringhead on my Cs30 Ryobi weed eater with an expand it curved attachment. Loading the replacement string is no problem, but getting it to come out is another problem. I...
what model is trimmer? cs30? if you found the line on it clockwise, that's your problem. on the cs30 it rotates counterclockwise if youre looking at the head while trimmer is upside down. the line has to be wound opposite direction or your going to have a MESS of string in the head.
May 13, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Replace pull cord on ryobi model cs30 weed wacker
Good fix, mrfixit-jerr! Also, if you remove the rear cover (4 screws) you can stabilize the crankshaft by inserting a screwdriver between the lobe of the shaft and the counterweight.
Apr 03, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
859 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
John Wilson
Level 1 Expert
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
