Question about Sylvania 6419TA 19" TV
Need help with video
I just got tv and trying to hook philip dvd with it how do i do it and on what channel
    Scholar:
  • 105 Answers
Usually AV in via the external connections - probably RCA black and red - stereo sound in left and right. and yellow for composite video in - for the USA, In the UK and europe we use a combined connector called scart. Hope this is useful - please rate accordingly.
Posted on Mar 19, 2008
Trying to hook up dvd player to a philips 27ps55-s121. I cant get it to show up on the tv screen. I dont know what channel the tv needs to be on to show the dvd. and i am unsure where what plug (cable)...
Connect one end of the VIDEO
(yellow) CABLE to the AV1 in VIDEO
jack on the back of the TV. Then connect
one end the AUDIO (red and
white) CABLES to the AV1 in AUDIO
L and R(left and right) jacks on the rear
of the TV. Connect the other end of the cables to the appropriate color on the DVD player (yellow to yellow etc.)
Press the CH + or – buttons on the
remote to scroll the channels until AV1
appears in the upper left corner of the
TV screen.
Slide the TV/VCR/ACC switch to
the VCR position.
Insert DVD into player and press PLAY.
Aug 23, 2010 | Philips Televison & Video
Looking for user manual for philips magnavox tv. 9P6044 C104, 3911Q1716. Trying to find out how to hook up my VCR to this tv. It has s viedo, video, L audio & R audio holes on front side of tv. I want...
Barb..be sure you run a TV signal through the VCR first. And then a coaxial from the VCR to the TV. This is the easiest solution for now. And set the vcr to tv/video {channel your movie is on}hit record and hit tv/video and watch your tv for another movie!
Feb 06, 2010 | Philips 9P6044C 60" Rear Projection...
DVD and older magnavox TV
On most of the older sets the video input is found by channeling down below channel 2 where you will find the video input source.
Nov 23, 2009 | Philips DVP3140
Trying to hook up a Philips 22'' TV to Sony CD/DVD player. Need help. I have a Red, White. and Black connector to go from TV to CD Player. Do I need anytning else? TV model # 22PFL3504D/F7
Usually the Color Red and White is for the audio channels and yellow is for the video but in your case you find black instead of yellow.
So you do the connection as per the instruction given below.
TV DVD Player
Red--------------Red
White------------White
Black-------------Yellow
Jul 25, 2009 | Televison & Video
LOST INSTRUCTIONS HOW TO HOOK UP MY DVD & VCR PLAYER TO MY TV SONY?
Sony maintains most manuals on their website. The general principle is to hook the cables from the video and audio OUT of the DVD/VCR player to the video and audio IN of the TV. Once the cables are hooked up correctly, just press the input, source, av, or video button on the tv or tv remote to change the television to the correct channel so that you can watch videos.
Jun 14, 2008 | Philips Televison & Video
TV channels
If cable is hooked through cable box with a coaxial cable, then turn tv to ch 3 or ch 4 as appropriate.
If cable is hooked through any other type of cord (red/green/blue or red/white/yellow) use the AV+ or Source button to change your source to Av1, AV2, HDMI, or however you have the cable box hooked to TV (I am assuming your TV is a Philips).
Feb 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
Hooking up a magnavox MWD7006 DVD player to a APEX TV
honey and guest: connections: Red, white, and yellow composite from out of cable/sat box to in of this dvd, and then a 2nd red , white and yellow cable from out of this player to in on television. Every television calls the correct channel something different - make note of where you plug the r,y,w cables to TV -- it may be labelled video1, video 2, av1, av2, input1, ext 1, etc. Turn tv to correct input/av/source/video channel. Call 1-800-605-8610 for further assistance.
Jan 13, 2008 | Philips Magnavox MWD7006 DVD Player
DVP334V cant connect to my LCD TV
  1. Connect the video cable to the players VIDEO (CVBS) OUT (yellow) jack and to the TV's VIDEO IN jack.
  2. Connect the audio cable to the players 'AUDIO LEFT' (white) and 'RIGHT' (red) output and the TV's 'AUDIO LEFT/RIGHT' input jacks.
  3. After it is hooked up, you will need to select the TV’s video input channel that corresponds to the jacks connecting the player to the TV.
    • Press STANDBY-ON to turn on the player.
    • Turn ON the TV.
      Note: Video Input selection varies for different brands/models of TVs. Consult the user manual or manufacturer or your TV if none of the below is successful.
      • Press channel 2 on your TV. Then press the channel down button to locate the video input channel. (This channel is usually located between the lowest and highest TV channels.)
        OR
      • For some TVs, there may be a button on the TV’s remote control that accesses the video input channel labeled SOURCE, AV or SELECT.
        OR
      • Select the Video Input Channel from the TV’s on-screen menu system.
Composite Video Connection. (Example Only)
051104165152_4352.jpg Attachments
    No attachment available.
Dec 25, 2007 | Philips DVP3340V
Connecting to a DVD/VCR player/recorder
In the menu of the Philips dual unit,select set-up then look for channel auto-program instructions. Be sure to hook-up a tv channel signal source before beginning auto-search.Hope this helps.
Oct 03, 2007 | Mitsubishi CS-27205 TV
Sylvania 6419TA 19" TV Logo
97 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
