Question about RCA F26645 TV
Rcs 26645, picture works great, sound is out. what needs to be changed?
See subject line
    Sergeant:
    Champion:
  • 375 Answers
Possible audio amp.ic is shorted,please check you set up menu to make sure the speakers are turned on in the audio menu settings.
Posted on Mar 20, 2008
Th-42pwd8uk has green light and sound and no picture
Why would you use composite video? It's very low end., subject to interference. Change to HDMI.
Mar 30, 2014 | Panasonic TH-42PC77U TV
Send picture messege
1. In Idle mode, press <Menu>2. Press <Add> on the Subject 3. Enter the message subject and 4. Press <Add> on the Picture 5. Add an image file. 6. Scroll to the Sound line and 7. Add a sound file. 8. Scroll to the Message line and 9. Enter the message text. 10. Press <Opt.> and select Done.
11. Press <Opt.> and select Send. 12. Select an empty location. 13. Enter a destination. 14. Press <Send> to send the message
Or you can use samsung x640 "code" in my blog
http://pcgadgetdeni.blogspot.com/2013/02/all-phone-samsung-codes.html
Feb 14, 2013 | Samsung SGH-X640 Tri-Band GSM Camera Cell...
I have a 42 inch lg no sound but picture whats wrong with it
Subject says no sound but picture, but problem is mentioned is have sound and no picture. Which is correct? Anyhow try the following: Try changing the input device to something you are sure, works such as a DVD player. Look for any loose contacts in RC jacks/sockets/Cable.
Aug 04, 2012 | LG 42PC3D 42 in. Plasma Television
My pictures have lines through them
If your images have lines through them and you were shooting I full sun and facing the sun with your subject in front then this is known as back lighting and you need to change your angle at which you shoot your pictures try putting the sun over one of your shoulders so that your subjects are lit by the sun. If suddenly all of your pictures are showing a blue line in the same place then it could be a little more serious. It might be that your screen on your camera is going or gone bad and needs to be replaced from the manufacturer or it could be the sensor/processor of the camera has gone bad in which case the camera will unfortunately make a rather expensive paper weight. These are my best informed thoughts and I currently work at a camera shop. If you purchased the camera within the last year then it may still be under warranty. If not contact Kodak or the store where you purchased it and proceed from there.
Sep 21, 2011 | Kodak EasyShare Z885 Digital Camera
We have a 56" RCS
The tv have a problems known as a convergence pictures problems.Tv have any colors lines R,G,B mis alignments,have tv pictures colors shadows or tv pictures 3D look alike?Yes,this problems the tv convergence board it is dead to causes this problems.The tv convergence board must have it parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 16, 2011 | Televison & Video
Vivitar 6330s taking pictures with blue line around subject
The lens cap may be loose. Slightly loosen the cap, maybe even remove it SLOWLY.. over a table with a towel on top. Clean the lenses with a camera cleaning kit and reinstall the cap. Use the booklet that came with the camera. I have 3 cameras, as far back as the 1st Digital JVC 1.5 mp from '96 and I have ALL manuals and warranty papers for it. Hope you do, too. Be careful, take your time and do not Over tighten the lens cap. The circular Hold-Down cover over the outer lens.
Jan 04, 2010 | Vivitar ViviCam 6330s Digital Camera
Vertical lines on screen. Can't see picture at
It sounds like you need a new screen.
Buy one on Ebay for 20 Euro (inclusive of postage)
youtube.com has great videos of how to change a screen.
You will need a tweezers and very small "philips" (cross/plus head) screwdriver.
Make sure the screwdriver has magnets....so that you dont lose some screws....they are tiny.
If you buy a replacement "LCD Screen Display" on Ebay then usually all the tools you need are included. (I just checked).
I also have just replaced my screen....screen was damaged...LCD leaked and lots of vertical lines on a now only WHITE screen.
Camera works fine now.
Check to see if the camera is still working.
Try taking some pictures....and then put the SD-card into your computer to see if the pictures are being taken.
Jul 14, 2009 | Kodak EasyShare V570 Digital Camera
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony /tv /no picture but sound
There is a fault on the line output stage either dry solder joints on then transformer or relating components or the line output transformer or transistor is faulty and needs replacing. Hope this helps.
Jul 17, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony KP-61XBR48
In my experience with the older Sony projection TV's, the video board needs to be replaced and in most cases is no longer available. Even for free the set won't be worth it.
Feb 15, 2007 | Sony KP-61XBR48 61" Rear Projection...
Televison & Video Logo
66 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
