Question about HP PSC 2210 All-In-One InkJet Printer
Remove and Chk Cartridges
I have put new cartridges in twice and still get this msg.. the Copy, Fax, Scan and Photo Card buttons blink and will not stop...
    Novelist:
  • 188 Answers
Hi Timcarter,
Please click on the web link given below and perform the following as given in the web link.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00055502&cc=us&lc=en&dlc=en&product=79499
This will help you fix the issue.
Posted on Mar 21, 2008
Why does it keep asking to replace black ink when already a new one has been put in
Did you use genuine ink cartridges or no-name ones? Some non-genuine cartridges just will not work no matter what the seller tells you.
If you were using genuine Epson cartridges, have a careful read here, especially the steps at the end of the article:
http://www.inkbank.com.au/webcontent31.htm
Feb 09, 2015 | Epson ME OFFICE 620F MULTIFUNCTION INKJET...
Canon pixma 882
bad cartridges or you set it not to remind you of ink running low
If so maybe try to remove the head and let it cap.
Unplug it for 30 minutes and re-install head etc.
Aug 18, 2014 | Canon Pixma Mx882 Mx 882 Photo All-in-one...
Ink cartrige problem i replaced both cartriges keeps saying right cartrige is incorrect wont let me print
Wiping the nozzles with a moistened soft cloth or removing and reinserting the cartridges usually helps. The cartridges for the Lexmark X7170 are black: 32/34 and color: 33/35. If these are the cartridges that you purchased and even tried your old and new cartridges yet the problem persists, please don't hesitate to contact Lexmark technical support.
Mar 23, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Had the cartridge filled instead of buying a new one. I was told at costco that the printer sometimes shows low ink when it's filled to check the manual there is an option that needs to be changed. I...
Some menus on the X8310 and X8350 are repeated in the Copy Mode, Scan Mode, Fax Mode and Photo Card menus.
If you press the Menu button while in any of the above menus, two ancillary menus will be listed, Maintenance and Device Defaults.
To select either of these menus, press the check mark pattlnk_442006_155-selects.gif at the center of the navigation keys on the printer.
Maintenance Menu options View Ink Levels Clean Cartridges Align Cartridges Print Test Page Reset Defaults
Device Defaults Menu options Set Date and Time Language Country Copy Paper Photo Paper Photo Size Button Beep Power Save Timeout Caller ID Pattern
The ink levels should reset when the ink jet cartridge is installed
Another thing which is mentioned at their support site is quote:
If you have refilled the cartridges you got along with the printer, you can't reset them. 23 and 24 are not meant to be refilled. They are what Lexmark call "return program cartridges"- they can't be refilled, you can send them back to Lexmark ( that's why they are called "return cartridges"). You need to buy either 23A and 24A or 34 and 35, those cartridges are refillable.
Here is a link to Lexmark, with a list of cartridge compatibility for your printer:
http://lexmark-cartridges.com/cfv2/printer.php?lang=uk&partner=&productName=x3550
If you find my answer helpful, please vote. Thank you!
Nov 16, 2010 | Lexmark X8350 All-In-One InkJet Printer
How do I reset the ink level on my lexmark x8350?
http://support.lexmark.com/index?locale=en&segment=SUPPORT&startover=y&userlocale=EN_US&question=x8350+ink+level&productCode=LEXMARK_X8350&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X8350&searchid=1280474419390#1
The above is the description page for you Lexmark printer.
Solution
The ink levels should reset when the ink jet cartridge is installed.
Jul 30, 2010 | Lexmark X8350 All-In-One InkJet Printer
My black cartridge was empty so I bought a new one. When I inserted the cartridge...the screen read "Remove and Check Cartridges." The "Copy", "Scan", and "Photo Card" tabs keep blinking as well....
hawleydn,
I know this might sound crazy, but your brand new cartridge is junk. Take it back and get a new one. I've done this several times with my HP PSC 2210. the all-in-ones are sometimes finicky with the cartridges. Also, be careful when you insert it into the slot. There is a small wire clip thing on the right side that is easily broken if you try to force it in.
If this helps, give me a vote :o)
samson39
Jul 25, 2009 | HP PSC 2175 All-In-One InkJet Printer
Hiya timcarter1... Clear tray of any paper...would suggest you are ceratin that the cartridges are engaged! Otherwise try doing a reinstall of your software... and are you using generic cartridges " copy" rather than the branded ones .. tends to result in same message!
Regards Faggly
Mar 19, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
91 people viewed this question
Seeker5211
Seeker5211
