Changing Fuser Oil
Does anyone know how to change "Fuser Oil" on a Ricoh 1232C copier? Please let me know
  • jl0123 Mar 21, 2008
    Spinal,
    Thank you very much for the instructions that fixed the problem. Please let me know how to rate the solution....I couldn't find the rating on the website.
    Thank you.
  • jeff heightchew
    jeff heightchew May 11, 2010
    hello jl0123,
    You cannot, or should I say need not "change the fuser oil" in your copier. You should have gotten a prompt that says "fuser oil low" or something like that. I can help.But you must take care of this soon because waiting too long will cause the copier to get pissed off and give an error code and then you are in deep doo doo. Here is what you do.First of all you need fuser oil to replenish the oil tank which is almost empty. You should be able to get the oil from the same place you get your toner or other consumables. Once you have it ,we will need to spin the machine around so you have good access to the back of the machine.When you view the back of the machine you will see I believe a total of 4 "button" looking things. The top 3 are to access air filters. At the bottom towards the right you will see a cover that has one of these button looking things that you can open with either a flat screwdriver or a penny,nickel, dime etc... Turn the slot counterclockwise and remove the cover.Don't worry you are not going to hurt anything unless you intend to. Once you remove the cover you will see a small clear tank with a black cap. Thats where the oil goes. Remove the cap and add the oil till it reaches close to the top.A lite would be helpful. The only worry is that you overfill it. You will have a mess,no damage. And you can tell when it approaches full as the tank is clear. There ya go. The only caution is that this oil is very slick, can stain, and is tough to clean up. So just be a little careful. You are the hero!!!!! Take care and I hope this helps. Please feel free to give positive feedback to the fixya website if I helped you. :-)
  • 287 Answers
I am glad that drichards gave me am an "atta boy" considering the fact that I could not have given a more thorough explanation.
Posted on Mar 25, 2008
  • 87 Answers
Sounds about right, but if the oil is really low, it will code. If you catch it in time, the machine will pump the oil to the fuser unit.
Posted on Mar 20, 2008
SOURCE:
I want to empty my used toner bottle on a Richo Aficio 1232C. Where is this located? Is there any particular sequence to the changing? Robert
you study this copier.If you are not have user guide you collect it by ricoh copier support webside.
Thanks
Tareq Bin Mostaq
Bangladesh.
Aug 13, 2011 | Ricoh Aficio 1232C Color Copier
Comment enlever message sc 570 sur ricoh 1232c
This error code is related to a Insufficient oil.
The fusing oil tank is in the rear of the machine.
You have to call Ricoh to supply the oil.
See you
Mar 29, 2011 | Ricoh Aficio 1232C Color Copier
My Ricoh 1232c is appearing Offline & won't let me print! It happend once before but I don't remember how I fixed it, any ideas what to do??? Thanks! :)
Try this:
Control panel - printers - Double click it (in the printer) - Click print and change to on-line.
I think it may work
Feb 28, 2011 | Ricoh Aficio 1232C Color Copier
How do I clear Fuser oil low message on Ricoh Aficio 1232C after refilling fuser oil bottle
At the machine. Press in this order. Clear all ( yellow button) then 107, then press and hold the pink stop button until the screen changes. You will see some icons that say Copy SP, Sytem SP.
Select Copy SP, if thats not available select System SP.
You will see several buttons. Select sp 7 Data Log, Then scroll to page 804 and select that. Then scroll to item 11. That is where you will select to clear the fuser oil count and reset it.
Jan 28, 2011 | Ricoh Aficio 1232C Color Copier
ERROR SC 570 RICOH AFICIO 1232C HOW CAN I FIX
The machine has no fuser oil.
Fill the little tank at the back side of the machine. If the tank is full, check the tubes, oil pump, and oil sensor.
Reboot the machine to clear the SC.
The problem will be solved
Aug 10, 2010 | Ricoh Aficio 1232C Color Copier
Ricoh Aficio 1232c REFILL
You can't use any other brand of color toner to refill the AF1232, you'll have all kinds of issues. They do have compatible toners (generic) for that model but highly recommend OEM.
Mar 31, 2010 | Ricoh Aficio 1232C Color Copier
Ricoh 1232c scan to email SSL issue
no work around for machine. you can scan to a folder on the network, than attach your doc to an email. only way to do it on a ssl.
Mar 24, 2010 | Ricoh Aficio 1232C Color Copier
How to clear error code SC571 on Ricoh 1232c copier
See thread I left you this morning on this. I hope it helps.
Press the yellow button. Press the 107 keys. Press and hold the red clear button for a few seconds until the service mode screen appears on the LCD display.
Oct 30, 2008 | Office Equipment & Supplies
Ricoh Aficio 1232c copier error code SC571
Enter SP 5-810 and set to 1, then switch off and on the machine.
280 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
