Question about Philips Digital Voice Tracer 7655
Software Hello, Using window media player software for wave file transcription, the recording stop as soon as I start typing is there better software to use?
  • 8,596 Answers
WAV Editor
Posted on Mar 20, 2008
SOURCE:
HOW TO INSTALL OLYMPUS DRIVER FOR FOOTSWITCH RS24
Hello your foot pedal don't need drivers but you need for sure a transcription software, the pedal will required a program to work together to control your audio files for example you can get a Olympus transcription software that will be compatible with your pedal, at http://www.tvps.com/Products/Olympus-AS-5002-DSS-Player-Pro-Version-5-Transcription-Software---New__OL-AS-5002.aspx or you also can used http://www.tvps.com/Products/Olympus-AS-7002-Pro-ODMS-R6-Transcription-Software---New__OL-AS-7002.aspx
May 01, 2014 | Olympus AS-2300 PC Transcription Kit
Olympus DSS Player Pro Woes!
Could it be that the files are just being regularly accessed by one of the server admin tools and the DSS Player application interprets an open file as 'being transcribed'
What happens when a copy of a .DSS file is made to an operators machine and then loaded locally for transcription?
Oct 21, 2007 | Olympus DS-40 Digital Voice Recorder
I need Digital Wave Player soft to work with VN-480PC
If you have previously connected the recorder:
1. Make sure the recorder is connected correctly.
2. Open the 'System' control panel: Start menu -> Control Panel -> System.
3. Click the 'Hardware' tab and then click the 'Device Manager' button.
4. Right-click the item that shows as 'Digital Voice Recorder' and choose 'Uninstall' or 'Remove'.
5. Disconnect the recorder.
If you have the software already installed:
1. Open the 'Add / Remove Programs' (Pre-Vista/Windows 7) OR 'Programs and Features' (Vista/Windows7) control panel: Start menu -> Control Panel -> Add / Remove Programs (Pre-Vista/Windows 7) OR Programs and Features (Vista/Windows7).
2. Click 'Olympus Digital Wave Player' and choose 'Change / Remove' or 'Uninstall'.
Please restart the computer before reinstalling if you had connected the recorder or installed the software previously.
Digital Wave Player (2.0):
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
SAVE to the desktop
RIGHT CLICK on the DigitalWavePlayer.zip and LEFT CLICK on EXTRACT ALL
CLICK on NEXT, Then NEXT again, Then FINISH
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update 2.1.4:
http://olympusamerica.com/files/DigitalWavePlayerUpdate214.zip
SAVE to the desktop
RIGHT CLICK on the DigitalWavePlayerUpdate214.zip and LEFT CLICK on EXTRACT ALL
After extracting the file, click on the SETUP.EXE file to begin installation.
For 64-bit systems, save the driver to the desktop and run the installation within it:
http://www.olympusamerica.com/files/oima_cckb/VNSeries64Driver.zip
Mar 06, 2010 | Olympus VN-4100PC Digital Voice Recorder
No voice recognition
You must have already set up and trained a user with the Dragon NaturallySpeaking software prior to transcription. Make sure that the Digital Voice Editor (DVE) software is not opened prior to starting these steps.
Open the Dragon NaturallySpeaking software.
The Dragon Bar window opens. From the Dragon Bar menu, click the Sound button.
From the Sound button, select the Transcribe Recording menu item.
The Transcribe a Recording dialog box opens.
Click the large square button to the left to start the DVE software.
The Digital Voice Editor window opens.
NOTE: If the file you want to transcribe is still on the Integrated Chip (IC) recorder (which will be reflected on the left side in the IC Recorder window), you will need to connect the IC recorder to the computer using the supplied USB cable, or transfer the file to the computer.
Select the item you want to transcribe from the PC window on the right side.
Click on File from the tool bar.
Select the Voice Recognition menu item.
The Converting.. Dialog box opens.
The Transcription Options dialog box opens.
Click the Transcribe button to continue.
The Transcribing window and Dragon Pad window opens.
The text is displayed while the transcription is in process.
NOTE: Once the transcription is complete, it may be necessary to make grammar, word, punctuation, and formatting adjustments.
To save the text file, click on File from the tool bar.
Select the Save As. Menu item.
The Save As dialog box opens.
Browse to the folder location to which you want to save the text file and double-click on that folder.
The folder you chose should now be showing in the Save in drop-down box near the top.
Type in the desired File name in the File name drop-down box towards the bottom and then select the document type.
Click the Save button.
Click the X (close) button in the upper-right corner to close the Dragon Pad window.
Click the X (close) button in the upper-right corner to close the Digital Voice Editor software.
Feb 10, 2010 | Sony ICDSX68 Digital Voice Recorder
I have an Olympus Digital Voice Recorder WS-311 M and a new Macbook Pro. I cannot seem to download to my Mac
http://www.olympusamerica.com/cpg_section/cpg_archived_accessories.asp?id=1308&ct=all
"DSS Player Version 7 (Vista Compatible) Item: #147467-410
DSS Player version 7.x provides computer support for Olympus DS-Series, WS-Series and VN-3200 and VN-5200 PC digital voice recorders using Windows 2000 Professional, XP Professional, XP Home, Vista, and Windows 7.
Functions include USB file download, file playback, editing files, conversion of DSS files to WAVE format, and archiving files. The installed application provides for the purchase of an optional Plus upgrade that enables splitting and joining files, and compatibility with voice-to-text transcription software.
The CD also contains DSS Player for Mac that provides computer support for Olympus DS-Series, WS-Series, and VN-3200 PC and VN-5200PC digital voice recorders on Macintosh platforms using Mac OS 10.3 and later, excludes: DS-3000, DS-2000, DS-660, DS-330, DS-320, DS-150, DS-10 and DM-1. Functions include USB file download, file playback, editing files, conversion of WMA and DSS format files to AIFF format, archiving files, and splitting and joining files. This MAC software version is not compatible with older foot switch RS-25, only the RS-27.
Item #147467
Opened software cannot be returned.
Price: $29.99
Sep 24, 2009 | Olympus WS-311M Digital Voice Recorder
Olympus DW 90 VN series. I have been using the
get switch audio converter software from www.nch.com.au
works for us like a charm
Aug 30, 2009 | Olympus VN-4100PC Digital Voice Recorder
Voice Recorder-Files to CD?
Please follow the below solutions to create either an audio CD-ROM of .wav files or back-up
.wav files to a CD-ROM.
Problem: .Wav files downloaded to PC computer from the DW-90, VN Series, and DSS Files
created with DS Series recorders cannot be copied to a rewritable CD-ROM using Windows
Media Player to create an audio CD-ROM.
Explanation: These digital voice recorders create .wav files at 8kHZ, 12kHZ, or 22kHz
depending on the Quality setting. Digital Wave player software is used to download Wav files to
a PC computer from the DW or VN Series of recorders. DSS Player is used to download DSS
files from the DS Series recorders and convert them to Wav files. If Windows Media Player is
then used to copy the files to a rewritable CD-ROM to create an audio CD-ROM, the files will
not copy properly or an error message may appear. Windows Media Player can only create an
audio CD-ROM if the .wav file is 44.1kHZ, 16 bit stereo.
Solution: Follow the procedure below to convert the .wav files to 44.1 kHZ, 16 bit stereo. Then
use Windows Media Player to copy the files to a rewritable CD-ROM.
1. Click Start, click All Programs, click Accessories, click Entertainment, and then click Sound Recorder.
2. On the File menu, click Open.
3. In the Open dialog box, specify the name of the audio file that you want to convert, and
then click OK. Files are usually located at C:\Program Files\Olympus\Digital Wave
Player\Message\Folder A.
4. On the File menu, click Save As.
In the Save As dialog box, click Change.
In the Attributes box, click 44.100 kHz, 16 Bit, Stereo, and then click OK.
Click Save. After you convert your files, try to copy them to a CD-ROM again.
Mar 21, 2009 | Olympus VN-4100PC Digital Voice Recorder
DS2 to DSS format
Dss Player Pro release 5 has the option to automatically convert to dss or wav upon download.
Dec 20, 2008 | Olympus DS-2 Digital Voice Recorder
Re: Play button on DSS AS-2300 Transcription player
several solutions you can try.. first of all, convert it to wave and try to play it (file. convert to wave)
if it is for all dss files, then the program may have to dll files that updated and will not work now
depending on operating system... windows xp media edition maybe the cause would be my first guess and there would be no fix for it...
2nd guess... service pack 3.... try to uninstall the program and reinstall it... and if you have service pack 3... go thru control panel and uninstall service pack 3 if you have it
Nov 15, 2008 | Olympus AS-2300 PC Transcription Kit
VN240 PC software stops running as soon as you start it
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Jul 07, 2008 | Olympus W-10 Digital Voice Recorder
Philips Digital Voice Tracer 7655 Logo
423 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
