Question about Sony KP-51HW40 51" Rear Projection Television
The whole picture has a red/purple tint - Sony KP-51HW40 51" Rear Projection Television
  • 2 more comments
  • jasonward Sep 13, 2008
    i have this same problem. about a year ago was the first time i saw a difference. all of a sudden while i was watching tv, it went crazy and started giving me a weird light show. but it seemed like after me playing with the settings it got a lil better. But a couple days ago it happened again and its so much worse. there is nothing i can do to help it at all! The picture has a purple/red tint and there seemes to be a lot of yellow at times.Please help
    if anyone can help, my email is jasonwardmusic@yahoo.com
  • Anonymous Nov 10, 2008
    Our Lamp went out now theres a Red Halo and the colors are messed up the repair man said its the panel i believe a circuit instead of a tube hr assures us thats the problem and that its worth us to repair since its not that old & cost $3400.
  • blakeman_cla May 11, 2010
    I don't know if the picture color went red all of a sudden or over time because it was given to me, I need to know if this is worth repairing or not.
    Don't know because it was given to me
    President:
  • Sony Master
  • 1,779 Answers
Did this happen all at once, or over time?
Make:
Model #:
Posted on Mar 20, 2008
Panasonic Viera PC-to-TV Via VGA has Purple Tint
Purple Panasonic PC>TV Problem:
The VGA cable uses three primary color RGB channels.
Red, Green, and Blue.
The picture is made up of pixels or dots arranged in a grid along the "X" horizontal axis and "Y" vertical axis.
The computer mixes the intensity of each color channel to create a unique color per pixel.
All RGB at 100% creates white.
R+G creates yellow.
R+B creates magenta, ie purplish.
G+B creates cyan.
So a purplish tint sounds as if your Green wire has no signal, which may indicate a faulty VGA cable or VGA socket.
Put another way, (R+G+B)-G=R+B=magenta.
So try another VGA cable, spray all socket pins with "Servisol " or similar contact cleaner.
0%<--------->100%
Cyan<------->Red
Magenta<--->Green
Yellow<------>Blue
All 0%=Black; All 50%=Grey; All 100%=White.
Jan 17, 2018 | Televison & Video
The picture has a purple tint to it, the TV displays one until it warms up. How can I fix this???!
Older TV units have a tube which is where the picture displays. It sounds as if the green firing beam could be failing which leaves the blue and red firing beam working causing you to get a purple haze on the screen. You might be able to get it repaired, however more often than not it is much cheaper to buy a new tv set.
Oct 03, 2012 | Televison & Video
Green tint on picture 60in mitsubishi
Turn the color all the way off---examine the screen to see if black and white or screen green in areas or whole screen.
The other possible issue is tint will not vary enough from green to purple when adjusted.
Two different issues--which do you seem to have?
May 31, 2012 | Mitsubishi WD-60737 60 in. HDTV
My JVC HD56 has a purple/green tint and isn't very bright.
Not worth attempting to fix and that is the reason it was tossed.
Apr 01, 2012 | JVC HD-56FN97 56" Television
LG Flatron W2234S 22 purple tint problem
your LCD monitor has bad ccfl lamps or inverter circut..
May 08, 2010 | LG 22" FLATRON LCD Monitor
Red tint is gone
It sounds like the red cable on your component input is bad, one way to check this is press menu and see if the menu bars and letters are the right color. if they are then you may have a cable issue, if they are bad you may have a bad DG board in the unit. This will probably require a service technician. Hope this helps
Apr 03, 2008 | Panasonic TC-32LX20 32 in. HD-Ready LCD...
Toshiba 32AF41 Power up Problem and Green Screen
My first inclination would be to check the picture tube, especially if the set is over 7 years old. If it is not that, then anything from bad solder connections to capacitors or a defective IC could be the cause. If it's over 10 years old, replace it. No use flogging a dead horse.
Jan 13, 2007 | Toshiba 32AF41 32" TV
Sony KP-51HW40 51" Rear Projection Television Logo
49 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
