It used to work (Adobe PageMaker 7.0) but it doesn't load up now. When I click on it it starts to open than shuts down...Help
Try re-installing it.
Posted on Mar 19, 2008
SOURCE:
Pmd to pdf
PMD stands for Adobe PageMaker also called PageMaker Document. You can down load PageMaker free from Adobe. https://www.adobe.com/cfusion/tdrc/index.cfm?loc=en%5Fus&product=pagemaker Have a Nice day.
Feb 12, 2014 | HEWLETT-PACKARD HEWLETT PACKARD - HP -...
Problems Installing Adobe Flash Player For Firefox
The MSCONFIG file shows programs (and other services) which are scheduled to load at system startup. But that doesn't tell you which programs and services are currently running.
If you launched the Firefox browser, and then closed it, it's possible that the application file may still be open (running), even though the browser window is no longer visible. (Like other large programs, Firefox doesn't always shut down properly.) Fortunately, it's easy to check on that, and to terminate the application if necessary, by using the Windows Task Manager.
In Windows, right-click on the taskbar (at bottom of screen), and select "Start Task Manager". Then click on the "Processes" tab, and scroll down to see if "firefox.exe" is listed. If so, highlight that entry, and click on "End Process". That will terminate all Firefox processes, so other activities (such as Adobe Flash installation) should be able to proceed.
See also this Firefox help file:
http://support.mozilla.com/en-US/kb/Firefox%20is%20already%20running%20but%20is%20not%20responding
Hope that's helpful.
Nov 29, 2011 | Adobe Systems Adobe Flash Player
How do insert page numbers on page maker automatically?
To have AdobeĀ® PageMakerĀ® automatically number your pages, if the template isn't used, place a page number marker on the Master page of the document.
  • Go to the Master Pages by clicking on the page icons with the L and R on them at the bottom left corner of the screen.
  • Using the Text tool, draw a text block in the general area for the page numbers.
  • On the Mac, press Command+Option+P or in Windows, Ctrl+Alt+P.
  • Depending on the page you are on, the page marker will show up in the text block, LM on the left page, RM on the right page.
Auto page Number
  • This text can be formatted like any other text on your pages.
  • Select the Pointer tool and move the copy block into the correct position.
  • Click on a page icon to go to a page in your file and the actual page number will appear.
  • If the page icons do not have the correct page numbers on them, go to the File menu, select Document Setup and change the Starting page # field to the correct starting page number.
Another solution
Adding Page Numbers in PageMaker 7 Page numbers add shine and organization to any publication. In Adobe PageMaker 7, page numbers are quite simple to include, but function is difficult to find first time. After activated, page numbers show throughout selected project.
Instructions
Step 1
Start project in PageMaker 7.
Step 2
Choose text function from toolbox. It appears as T.
Step 3
Click L/R function. It is placed under ruler.
Step 4
Click master page where page numbers placed and push "Ctrl+Alt+P." Page number must show.
Jun 09, 2011 | Adobe PageMaker 7.0 Classroom in a Book...
Sir, if i want to copy from nets Hindi than doesn`t paste in page-maker.
If you want Copy Hindi in your page-maker - Install Hindi Font to your computer - go to - start - Setting - Control Pannel - Fonts = Open and Paste Hindi Font
- then open your Adobe Pagemaker it will show Hindi Font.
Apr 13, 2010 | Adobe PageMaker Plus 6.5 for PC
I downloaded PM 7 Tryout from adobe When i
Hi. You'll be better off downloading and installing the tryout for Adobe Indesign than PageMaker. InDesign is the improved version of PageMaker and it can open your old PM7 files. With your current PC specs, you can definitely run that software.
Jul 21, 2009 | Adobe PageMaker 7.0 for PC
Solution for adobe pagemaker 7.0 spell checking problem
For those running Windows Vista, you can enable spell checking in Pagemaker 7 by simply turning off the user account control. This control is what pops up every time you attempt to run a program windows Vista isn't familiar with, asking if you really want to run it.
To turn it off, go to Control Panal, select user accounts and forms, select User Account Control, and in the follow up screen delete the checkmark.
Of course, the account control is there to protect you against unauthorized running of spyware and such. Be sure you have good virus protection!
May 06, 2009 | Adobe PageMaker 7.0 for PC
I cannot load Pagemaker 6.5 onto my laptop w/ Vista
Pagemaker 6.5 is designed to be used with Windows 95 / 98 / NT 4, therefore in order to run it in Vista I'd suggest to run your Pagemaker 6.5 using Compatinity Mode --> Go to your Desktop --> Right click on the program icon--> properties-->Compatibility--> select one of the versions above
Nov 08, 2008 | Adobe PageMaker Plus 6.5 for PC
Translate a pagemaker file into indesign
This is from Adobe InDesign (CS3) Help module:
Convert PageMaker documents InDesign can convert document and template files from Adobe PageMaker 6.0 and later. When you open a PageMaker file, InDesign converts the original file information to native InDesign information. InDesign files are saved with an .indd filename extension.
For more information, see the PageMaker Conversion Guide (PDF) at www.adobe.com/go/learn_pmconv. Before opening the document in InDesign, you may want to do the following:
  • If the PageMaker file or its linked graphics are located on a network server, floppy disk, or removable drive, it may not open as expected if an interruption in data transfer occurs. To prevent data transfer problems, copy documents and their links to the hard disk, preferably in the same folder where the PageMaker publication is stored, before opening them in InDesign.
  • You may want to use Save As in PageMaker to clear unnecessary hidden data.
  • To ensure that all links are maintained, copy all linked files to the same folder where the PageMaker publication is stored.
  • Make sure that all necessary fonts are available in InDesign.
  • Repair broken graphics links in the PageMaker publication.
  • If you have a problem converting a large PageMaker document, convert portions of the PageMaker file separately to isolate the problem.
If you cannot open a corrupt PageMaker document in PageMaker, try opening it in InDesign. InDesign can recover most documents that PageMaker cannot open.
Oct 29, 2008 | Adobe InDesign CS2 for PC
Help section not working in pagemaker 7
download the full version along with help menu on torrentz.com
Jun 21, 2008 | Adobe PageMaker V7.0.2 for PC
Open Questions:
Computers & Internet Logo
Ekse
Alun Cox
