My TV Doesn't have any picture???
We have only had the TV now just short of 2 years. We were sitting there watching it and the screen went blank. It has a slight faint line across the middle of the screen. I have tried it in other TV points and still it doesn't work. We have had this problem once before about 1 week after our 12 months guarantee it did the same thing. We got someone to repair it and 8 months later it has happened again.
Please advise.
I dont know what any of the numbers meam so I hope something makes sense to you?
Sharon
    Scholar:
  • 105 Answers
This is what is known as frame collapse - which means there is no vertical deflection applied to the tube.
Please do not continue to watch the set in this condition as it may burn a horizontal line in the middle of the screen.
The most likely cause is either bad solder connections to or failure of the frame vertical output IC.
Please rate the assistance I have given - I hope it is useful. If you call a serviceman and tell him its frame collapse as this type of repair is not for amateurs - voltages in television receivers can kill.
Posted on Mar 19, 2008
6ya staff
SOURCE:
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
HCN5527W Samsung wide screen 55" will not turn on, scree went black unit 4 1/2 years old
picture tube pro...so pls change ut picture tube and use...and also due to some fluctuation it may cause tis pro so try to plug ur pin in some other slot in ur home
Aug 29, 2008 | Samsung HCN5527W 55" Rear Projection...
I have a 8 years old apex tv. while watching tv the picture went out but it still has sound. i can't see the channel numbers or volue bar is it worth fixing
I WOULD SAY NO ! THE PICTURE TUBE IS PROBABLY AS MUCH AS THE TV IS WORTH. i had a very nice sony trinatron tv. the picture tube whent on it at about 5 years so I CALLED FOR REPAIR AND THE PICTURE TUBE WAS 2-300 DOLLARS. good-day !
Jan 20, 2012 | Apex Digital Televison & Video
No picture on my Toshiba 42HP66 plasma tv.
I too have this problem with no help from hh Gregg, where I bought the tv, and no help from Toshiba. I resorted to calling the BBB and complaining about the defective workmanship. I took the tv, which is less than 2 years old, apart and found the y-sus board, behind the y-sus board is a foam rubber spacer to seperate the circut board from the backside of the screen. I think this pad is designed to prevent heat buildup in the y-sus board. The pad itself is held on by glue and that glue melted causing the y-sus board to short out. I noticed this after finding a tacky substance behind the board. The heat from the plasma screen melted this and also the pad itself. Toshiba claims no resposibility because the tv was out of warranty. Thanks Toshiba.
Jan 22, 2009 | Televison & Video
JVC i art 32" flat screen
your tv is under shutdown state, there is a protecting circuit that prevent the tv from turning on when there is a short
Sep 10, 2008 | Televison & Video
Does anyone know where can I buy a screen for a 27" LCD Insignia TV. Model is NS-27LCD? My screen creaked. I checked out e-bay and have not found a broken TV with a good screen. Does anyone know where I can buy a screen at.
Thank you all for you time.
JC
Jul 22, 2008 | Televison & Video
Rca 32flascreen tv
high volatge transformer shorted...or component in hi E.
Jul 18, 2008 | RCA F32450 32" TV
Hitachi will not show picture or sound
look in back fo tv on curcit board left side there should be two regular 125v 1.5 amp fuses see if they are black or wire in side is broken
May 14, 2008 | Hitachi 50UX57B 50" Rear Projection...
Loud electrical sounds
It sounds like the Power transistor that drives the High Voltage Transformer shorted out. The rapid clicking sound you are hearing when pressing the power button now is that of the power supply starting to come up, detecting a short circuit and shutting back off again, preventing further damage. It is likely that the HV Transformer is shorted as well which usually causes the Output transistor to fail. Since the set is only 2 1/2 years old, it is probably worthwhile getting it to a repair shop as long as you have been very satisfied with the picture quality up to this point. If the picture size was larger than you needed, you might consider going down to a 37" LCD HDTV set. Toshiba is tops in this category IMHO.
Mar 30, 2007 | Zenith R40W46 40" Rear Projection...
After 2 years of use, screen on TV went to white but sounds still works
Hi Sounds to me like the Tuner Module went out, this is something a qualified technician would have to fix.
Mar 08, 2007 | Apex Digital PF2720 27" TV
Televison & Video Logo
197 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
