Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Hitachi ultravision Sounds and functions OK. No picture, no menu. Bulb gone? Yes?
    President:
  • Hitachi Master
  • 1,779 Answers
If it's a DLP, you can try that first.With the volume turned all the way down, in the rear of the set close to where the lamp is, (with the set on) listen to hear if there is a buzzzing sound, if there is then chances are it is the lamp. The buzzing sound you may hear is the lamp inverter power supply trying to start the lamp of which it can't.
Posted on Mar 20, 2008
Hitachi ultravision projection that is turning off
Ur tv projection bulb,been a long time had not been replaced?If the the bulb been,replaced the ballast might be dead.
Apr 14, 2010 | Hitachi UltraVision 55HDS52 Television
TV: Hitachi UltraVision no Picture.
Hitachi Ultravision power light on but on picture
Nov 18, 2009 | Hitachi 57SWX20B 57" Rear Projection...
I need to make the picture smaller to fit the screen. do not have original remote.
Tries this website for a new remote 1-800-Remotes Factory original for new remote or tries the manual controls on the tv for functions to ajust the screeen sizes.
Oct 31, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Our hitachi 50c20 is overheating and turning off. It also has a red tint on whole screen when playing. We replaced the bulb but still the same. It is located in a well ventilated area.
i dont know about the overheating problem, but as far as the red tint goes, it you go to the picture setting within the menu and reset it to default, it should take care of that.
Jul 03, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
We have an Hiatchi UltraVision Model# 53SWX10B that the sounds comes on initially then 30 seconds later goes mute. The picture is still great but since it's 8 years old is it worth repairing. What could be...
Hi , audio output failure, possibly needs re-boot of cable/sat system, too many variables to troubleshoot on here, and thats generally a great tv so yes I would advise you to get a tech to fix it, video-tek
Jul 01, 2009 | Hitachi 61SWX10B 61" Rear Projection...
Hitachi 50V500, no picture ,sounds for about 15 sec.then goes off
I would try to re-seat the lamp. Pull the lamp out, check it to see if it may have gone bad again, then put it back in to make sure the contacts are connected. Before applying power, unplug the TV for 5 minute, and then plug in/turn it on.
Most lamps, if bad from the factory, will go out within 3 months of use. It does happen, and happens more often than you would think.
Try this, and see what happens. Good luck.
Jan 05, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
50" Hitachi Ultravision with yellow picture
Good Day, steveb13;
It stills points to yhe Light Engine. Good Luck, big IRISH.
Jul 15, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravision
It could be you need a new lamp again (your might have gotten a defective one) or "temp" is the temperature sensor that is located on top of you lamp, could be bad also. If the lamp gets too hot, the temperature sensor will shut down you lamp so your TV will not catch on fire. If your temperature sensor has gone bad, your lamp will not turn on at all.
Mar 22, 2008 | Televison & Video
52 hitachi ultravision
Yes, you can search these threads for the answer or ctechnicians.com
Jan 02, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
131 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
