Question about Saeco Incanto Classic Espresso Machine
Just bought the Saecco Incanto s-class de luxe machine
Just finished getting it ready - plugged it in. Folloowing iunstruction for the 1st ventilate...turn the steam knob...and nothing. No water is coming out..what am I doing wrong?
  • 487 Answers
Lol there is a water button on it. Press that first and than turn the steam knob
Posted on Apr 25, 2008
How it works decalcing, saeco incanto de lux
from the menu select descaling and open the steam knob. The machine is doing descaling.When descaling proces finish fill the water tank with frsh water and rinse from the hot water .When water finish you are ready to drink coffee.
Jul 04, 2014 | Saeco INCANTO DELUXE Espresso Machine
My Incanto de luxe is stuck on descaling
Fill the container with a little water and turn on and wait until the tank is empty, then he goes to the wash, and you can finish the descaling
May 26, 2013 | Coffee Makers & Espresso Machines
1. Where is the lever located in the Saeco Incanto De Luxe located? 2. How do you decalcify the same same product? Thank you for your help
Hello Dolls36,
I understand you have two questions the lever question I assume you are taking about the steam lever. The second question is how do you descale the unit.
Lets answer the first question first. The steam lever is not a lever but a knob. The knob is located on the right side of the unit.
1. Put container under steam tube turn knob downward to open until you get steam
2. Once you get steam turn knob upward to close
3. Put item you want to steam under steam tube and open valve back up to steam
Now to answer the question about how to descale the Incanto De Leluxe. When you are ready to descale the machine follow these steps.
1. Hold down the "x" button for 5 seconds, the machine will tell you it is ready to descale
2. Remove the filter
3. Fill the water tank with your descaling solution
4. Insert a container under the steam tube and open the steam valve
5. The machine will display descaling and finished
6. Then it will prompt you to fill tank with clean water for rinsing.
7. Press the "x" button once tank is full
8. Place container under steam tub and turn knob to open steam tube
9. When finished press "x" button one more time to confirm done
10. Replace water filter and fill tank
I hope that I have answer you question as for question 1 I assumed that is what you were asking about. However, if that was not the right question please post back to this tread and I will be more than happy to answer the question that you specify.
Thank you for choosing FixYa.com
Justin
Mar 11, 2011 | Saeco INCANTO DELUXE Espresso Machine
Saeko incanto delux
It was an easy solution in the end. Just opened the steam knob vent for the steam to escape and vioala a great coffee was on its way......................
Apr 13, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco incanto parts
I've found this site very informative - click HERE
You can navigate and order parts etc. The Incanto Rondo parts list is HERE - or ask again if you have problems.
Thanks for usind Fixya!
Jun 26, 2008 | Saeco Vienna De Luxe Espresso Machine
SAECO SAECO INCANTO DE LUXE
descaling it with special produit not vinegar 1 part descaler 1 part water put in water container start machine open water valve for few second leave it for 15 minute repeat untill empty rinse very good cheers
Jan 21, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto De Luxe S-Class - Fill Watertank constantly on
The machine appears to be blocked due to limestone formation in water piping. Suggestion is decalcify following instructions of manufacturer .
Jan 13, 2008 | Saeco Incanto Classic Espresso Machine
Machine Is Stuck on "VENTILATE" Command
Sounds like you all have the same problem. Your flow meter has been obstructed with a small chip of coffee bean that got into your water tank receptacle when your tank was off. You need to remove the top or back depending on your machine and remove the flow meter. It twist apart. The intake is a small opening and that is creates the jet of water that spins the flow meter. If it gets obstructed the meter doesn't spin and you will get the ventilate message.
Dec 05, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco S-Class Incanto de luxe coffee machine not working.
If it is what it sounds like to me I had this same problem with a split pipe on my saeco vienna machine. The place tried to say I had not descaled the machine 4 times in under a year leading to the pipe bursting. This is what wrecked my machine but it could be a simple case of a hose blew off. Sounds like an internal fuse also blew. It should really be check out and should or could still work again once dry.
Jun 11, 2007 | Saeco Incanto Coffee Maker
Saeco Incanto Classic Espresso Machine Logo
237 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
