Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Problem with Colors Seperating
Hi, I have a Philips 60 inch Rear Projection TV that I purchased about 4 years ago from Costco. A few months ago the colors starting seperating on the screen and the only way to fix it was to unplug it while it was on, plug back in and turn on again. For a few months that seemed to fix the problem. About a month ago it started getting worse and needed to "warm up" for a few hours before unplugging and plugging in would work. Well, now there are red lines all along the bottom and center of the screen and the picture is also messed up and not in line with where it should be. I've tried converging the colors (all of them) using my remote and even went as far as taking the back off of the TV and trying to see if one of the projectors was maybe out of place, but I couldn't find anything that looked out of the ordinary, not that I would even know since I've never assembed or disassembled a TV before this. Please help. Prior to this my TV was great, I want it back. Thanks so much!
  • Esjae Mar 30, 2008
    I' ve taken the same steps as Litisha, I'm pretty handy, and would like to know where inside the tv are the ic chips and ......
  • babymac Apr 09, 2008
    i have the same problem what do i need to do to replace them my self
    Habit-Forming:
  • 55 Answers
The IC's in my tv were on the right side attached to the mainboard, so you would have to remove some screws and plugs to get to it. It is fairly easy if you know how to use a solder gun good. The IC's are attached to a silver looking vertical metal piece and has two clips holding them close to the unit. Good Luck!
Posted on Jun 22, 2008
  • Philips Master
  • 8,617 Answers
Can the remote move the clors in all 4 directions? If not the convergence ICs need to be replaced. Also check the resistors that power the ICs they are located right next to the ICs
Posted on Mar 20, 2008
SOURCE:
Several years ago we purchased a Philips 60" Rear
It seems problem with convergence output section of tv and convergence output ICs need to be replaced by professional because it requires soldering work with proper tools.
Please call local tv repair shop to get tv repaired.
Thanks.
Jan 18, 2011 | Philips 60PP9202 60" Rear Projection...
The colors look very weak. The green is weaker than the blue. Red seems ok. I have a philips 60 inch rear projection. It almost looks like a haze. The colors are not crisp. .
The TV has coolant in the CRTs that after years of use get cloudy. you will need to have a shop replace the coolant in all three, it is pretty involved so its best to have a trained tech. do it.
Oct 30, 2010 | Philips 60PP9202 60" Rear Projection...
Bad color on mitsubishi dlp wd-73732 hdtv
Light Engine Failure.
Mitsubishi extended the warranty on THIS model to 3 years. Check your manufacture date on the back of the TV, , Then call Mitsubishi. They are replacing light engines and/or replacing TVs with newer models without the problem part.
Jul 22, 2009 | Philips 60PP9202 60" Rear Projection...
I have a philips 60 inch tv with on picture and sound
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 28, 2009 | Philips 60P8342 60" Rear Projection...
Philips 60 inch rear projection screen is wacky!!
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 10, 2009 | Philips 60PP9202 60" Rear Projection...
Phillips 60 in. rear projection approx. 10 years old
This is a common problem with the older models. The opt chip fails. You can get a repair kit at www.magnavoxhelp.com. After a few months of getting smaller and smaller the audio and video will go out but the power light will remain lit.
Aug 18, 2008 | Philips 60P8341 60" Rear Projection...
Philips 60PP9202 60 in. Help
You will need a service call by a qualified technician....
Red & green = yellow, therefore the blue CRT has a problem..T.
Feb 12, 2008 | Philips 60PP9202 60" Rear Projection...
Philips Magnavox 60PP9701 60 in. Rear
If the picture is changing size when bright images appear on screen, then a power regulator issue is what you have. Have a technician look at it.
Feb 23, 2007 | Philips Magnavox 60PP9701 60" Rear...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
80 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
