Question about Dell E173FP 17" LCD Flat Panel Monitor
Monitor vertical lines
I booted my computer up as normal, but when the prompt for my windows password (Windows XP Home Service Pack 2) and blue field came up, I had vertical lines off the the white password enter area and windows picture blue field. I also saw in the top left of the screen a circle with verticle lines. I continued to enter the internet, thinking it would go away, I checked my monitor connections and they were all plugged in properly, upon accessing Yahoo, my screen went to a few lines here and there to a complete fuzzy red lines all over. Since, I take care of my equipment, I was dumfounded as to why this is occuring. I checked my monitor settings on the bottom right of the monitor itself and clicked factory restore. Did I get rid of the problum or from it reoccuring again?
    Novelist:
  • 77 Answers
Dear Choji,
If obviously the problem has not occured again then you have solved it on your own. Bravo to that. You shoud give yourself a proud pat on your back. But if the problem still exists, then its with the device driver settings of the monitor. Try reinstalling the monitor by reinstalling its drivers.
If this still does not help then refer to an authoised service personel.
Posted on May 05, 2008
SOURCE:
Dell computor message on a black screen windows root \system 32\hal.dill what do I do
Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file:
  1. Use the Windows XP CD-ROM to start your computer.
  2. When you receive the message to press R to repair Windows by using the Recovery Console, press the R key.
  3. Select the Windows installation that you want, and then type the administrator password when prompted.
  4. Type bootcfg /rebuild, and then press ENTER.
  5. When the Windows installation is located, the following instructions are displayed: Add installation to boot list? (Yes/No/All)
    [Type Y in response to this message.]
    Enter Load Identifier:
    [This is the name of the operating system. Type Windows XP Professional or Windows XP Home Edition.]
    Enter OS Load options:
    [Leave this field blank, and then press ENTER]. After you perform the preceding steps, restart the computer, and then select the first item on the boot menu. This should allow Windows XP to start normally.
    After Windows XP has successfully loaded, the Boot.ini can be modified to remove the incorrect entry.
May 16, 2011 | Dell Microsoft Windows XP Home Edition
Ntfs is missing
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows Vista startup disks or the Windows Vista CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows Vista installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows Vista CD, and drive is the drive where you installed Windows Vista .
  7. Remove the Windows Vista CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
  9. rate me 4 thumbs up please
Jan 10, 2011 | Microsoft Windows Vista Home Premium with...
I haveMicrosoft Windows XP Professional on my computer and in the last few day then i put my computer on its say windows installer can find why is thay
I am assuming your mean it cannot find the installation of windows...
it sounds like the boot record has become corrupted.
With the install disk in the cd rom, load your pc and choose to Boot from CD - you may need to go into the BIOS to change the CD to be your first boot device (you get to the BIOS by pressing F10 on start up)
When Windows goes through its blue loading screen follow the screen prompts until you can see the option to "Press R to repair a windows installation".
Press R
When the DOS prompt appears on the screen choose the Windows installation you wish to repair (usually 1 and press ENTER)
When prompted for the administrator password either enter the password you have specified or if you have never set a password press ENTER
Type:
FIXMBR
Choose Yes
Press Enter
Reboot yuour PC.
Hope this helps...
If not please provide the exact error message in a post
Feb 22, 2010 | Microsoft Windows XP Professional With...
Forgot my password for logging on computer
Passwords. Those ubiquitious alpha-numeric codes that protect us and give us access to everything digital. Unfortunately, passwords can be confusing because, though your computer likely won't forget a password, you very well might. When this happens, you can be locked out from your whole system, as in the case of the Windows XP Administrator Password. This article will show you how to remove an Administrator password.
Instructions:
Insert your Windows XP CD into your CD drive and boot your computer. If you receive the message "press any key to boot from CD," press any key.
Step 2 Press Enter to setup Windows. After accepting the license agreement, you wil be asked if you want start a Repair process.
Step 3 Press R to begin the Repair process. Setup will now check your disks and then start copying files, which can take several minutes. After this, reboot. Let the computer boot normally (do not press a key to boot from CD).
Step 4 Keep your eye on the lower left hand side of the screen. When you see the Installing Devices progress bar, press SHIFT + F10. This will open a command line console.
Step 5 Type NUSRMGR.CPL at the prompt and press Enter. This will give you access to User Accounts. Remove or change your password. Write it down! After the repair is finished, you will be able to log on with your new password.
Second way:there is some recovery tool like Windows Password Recovery Tool can help you.
If i am helpful please rate me.
Thank you.
Oct 19, 2009 | Microsoft Windows Vista Home Premium with...
HOW DO I BLOCK AN IP?...IM GETING HACKED, IT WONT STOP
The easiest means to block IP addresses in Windows XP is to use Internet Protocol Security (IPSec) filtering rules. The primary reason to block IP addresses is to protect your computer from network-based threats, such as computer worms, viruses and other malware. To block IP addresses in Windows XP, you will need to activate and configure IPSeccmd, the firewall that comes bundled with Windows XP. IPSeccmd does not come preinstalled with XP on your computer. It can be found on Disk 2 of your service pack upgrade or downloaded from Microsoft directly.
  1. Install IPSeccmd from your Window's XP Service Pack 2 installation disk.
  2. Step 2 Open the Command Prompt on your computer by selecting "Start > Run" from the primary file menu and type the word "cmd" in the blank text field that appears.
  3. Step 3 Enter the following command at the DOS command prompt to block a specific communication type (UDP or TCP) and port number on your computer:
    "IPSeccmd.exe -f [*=0:PortNumber:Protocol]
  4. Step 4 Open the user interface for IPSeccmd on your desktop, and select the "General" tab under the "Policy" section. Choose the "IP Block" option and enter the specific IP address of the host(s) that you desire to block. Exit the application when complete.
Jul 07, 2009 | Microsoft Windows XP Home SP3 for PC
Aspire M1100 boot up problem
Method 1
Edit the Boot.ini file to restore or correct the Default entry and to ensure that the other entries in the [Operating Systems] section of the Boot.ini file point to the appropriate directories.
Method 2
Method 3
1. Start the computer by using your Windows XP CD-ROM. Press any key to boot from the CD.
2. After the setup files are finished loading press R to repair using Recovery Console.
3. When you are in the recovery console, select the installation to log on to (usually number 1), and then press ENTER.
4. Login to the Administrator account by typing the password for this account, and then press ENTER.
5. At the recovery console command prompt, type the following command, and then press ENTER:
For Uni-Processor systems:
expand <cd-drive>:\i386\ntoskrnl.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe
For Multi-Processor systems:
expand <cd-drive>:\i386\ntkrnlmp.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe
Note In these two commands, the <cd-drive> placeholder represents the drive letter of your CD drive, and the <hd-drive> placeholder represents the drive letter of the hard disk on which windows is installed.
6. If you receive a prompt to overwrite the file, press Y.
7. Type exit, and press ENTER at the command prompt.
Method 4
Start the computer by using the Recovery Console, and then run theCHKDSK /rcommand.
Note You do not have to include the /p switch in the Chkdsk command-line because the /r switch causes the Chkdsk utility to locate bad sectors and recover readable information. This command implies the /p switch..
Jan 11, 2009 | Acer Computers & Internet
Forgot password
Reboot the computer. Press and hold the f8 button. Select safe mode from the menu. You should be able to see the admin login. Then you can make the changes.
Nov 22, 2008 | Microsoft Windows XP Professional With...
Laptop wont work after installing vista service pack 1
Please try booting from OS CD then go to command prompt (fix windows from console).
Then chose the right os (in case you have more than one)
then type in your admin password (in case you have one)
then type fixboot at the command prompt.
Hopefully it'll help... if not please drop a line I'll take it to the next phase.
Thank you for using agadycom.
Nov 21, 2008 | Microsoft Windows Vista Home Premium with...
Windows could not start because the following file is missing or corrupt: \system32\ntoskrnl.exe Please re-install a copy of the above file.
Fix the problem
Best Method would be this one, if you have the Windows Disk.
Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file: 1. Use the Windows XP CD-ROM to start your computer. 2. When you receive the message to press R to repair Windows by using the Recovery Console, press the R key. 3. Select the Windows installation that you want, and then type the administrator password when prompted. 4. Type bootcfg /rebuild, and then press ENTER. 5. When the Windows installation is located, the following instructions are displayed: Add installation to boot list? (Yes/No/All)
Nov 11, 2008 | Computers & Internet
Dell E173FP 17" LCD Flat Panel Monitor Logo
144 people viewed this question
Ekse
Clive
Clive
Alun Cox
