Brother HL 1030 Laser Printer Logo
Posted on Apr 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Alarm light is flashing as well as the Data light
Alarm light is flashing as well as the Date light what is the problem?
Anonymous
Level 3:
President:
  • Master 405 Answers
  • Posted on Apr 15, 2010
Anonymous
Master
Level 3:
President:
Answers
405
Questions
0
Helped
205299
Points
1407
It indicates that the toner cartridge is nearly empty.
You will need soon to Replace the toner cartridge with a new one.
How do I set alarm on Armstrong 45/7041 watch? Did not come with instructions
A= reset
B= Mode
C= ST/STP
D= Light  (edl)
•SETTING TIME AND CALENDAR
1.For time telling mode, press 'B' three times. The seconds should start to flash. Press 'C' to zero out the seconds.
2. Press 'A' minutes will flash, press 'C' to set the minutes.(holding down C will advance the digits faster)
3. Press 'A' hours will flash, press 'C' to set hour.
4.Press 'A' date will flash, press 'C' to set the date.
5.Press 'A' month will flash, press 'C' to set month.
6.press 'A' The day of the week flashes, press 'C' to set day of the week.
7.Press 'B' to finish and it will return to the time.
IF ANYMORE QUESTIONS ABOUT SET FEATURES SUCH AS 'STOPWATCH, SPLIT TIME, SETTING 24 HOUR ALARM, ACTIVATING ALARM, OR SNOOZING THE ALARM'. FEEL FREE TO CONTACT ME @ [email protected] WITH 'ARMITRON WATCH' IN SUBJECT BAR AND I WILL SEND YOU PICS OF THE MANUAL.
-Savannah:)
I cannot set the time on a wr165
here's a simple instructions of setting your watch
Watch setup instructions
for the Armitron Instalite All-Sport :
Mode B / \ C Date
Light A \ / D Alarm
_____________________________________
Set time time / date
Press and hold B (Mode) untill alarm hours flash
Press D (Alarm) to advance these
Press B (Mode) again, seconds will flash,
press D (Alarm) to advance these
Press C (Date), minutes flash, press D to advance these
Press C again, hours flash, press D to advance these
Press C again, month flashes, press D to advance these
Press C again, Date flashes, press D to advance these
Press C again, Date flashes, press D to advance...... [suggestion from Chikita]]
Activating/Deactivating Hourly Chime
1. From "Normal Time Mode", press and hold "D" (Alarm) and
at the same time press "C" (Date) once. Hourly chime symbol,
( a house shape) appears in "chime" windows to indicate
the hourly chime will beep every hour.
Activatin/Deactivating Alarm
2. With "D" (Alarm) still pressed, press "C" (Date) again. Alarm symbol
( a clock shape with waves above it) appears in the
upper right to indicate the 24 hour alarm is now activated.
[I assume this "toggles" between off and on states,
so performing it again should turn off the alarm]
i hope this will help you.
How do you set the time on an Armitron 165 wrist-watch?
Hi wtgillo,
Hi there I see that you are in need of assistance setting time on your Armitron Wrist watch.
I would be more than glad to give you details on how to, Please see steps below.
  • Your Armitron Watch will have Four Button on the side of the watches rim.
  • Button on the upper Left is MODE.
  • Button on the lower Left is LIGHT.
  • Button on the upper right is DATE.
  • Button on the lower right is Alarm.
See Steps below:
*Setting the time*
  • Press and Hold down the Mode Button til the Hours flash
  • Then push Alarm Button to set the Hours
  • Press and Hold down the Date Button till the Minutes flash, then push D/Alarm Button to set the minutes
  • After setting the minutes on your watch, Press date till you get the month flashing push Alarm to set the month
  • Press the Date again till the Date flashes, then push Alarm to set date
  • Press the Date again till the Date on your watch flashes, then push Alarm to set the date
  • After setting everything push the Mode Button again just once to set everything or finalize your settings on the watch.
I hope that this will be of help regarding your query on how to set the time on your Armitron watch, I also included the setting of the time and date just for further details.
Have a nice day,
mvincentc
2helpful
Do you have directions for armitron mens pro sport watch 49/1000
Hi robinmsavage,
I will be glad to help you with your concern regarding your Armitron Wristwatch, what exactly would you be experiencing? cause I only put info on how to set time and date on the Watch.
Please see below steps:
See Steps below:
*Setting the time*
  • Press and Hold down the Date Button till the Minutes flash, then push Alarm Button to set the minutes
  • After setting the minutes on your watch, Press Date till you get the month flashing push Alarm to set the month
Thank you for choosing Fixya,
mvincentc
Instructions for setting time & date of armitron watch 44/1001?
Nov 08, 2010 • Watches
How I change the time Armitron WR165
Thank you for contacting FixYa.
Light = A - lower left button
Mode = B - Upper left button
Date = C - Upper right button
Alarm = D - lower right button
Best regards. Jewel
1helpful
How do I turn off the alarm on my Armitron watch?
I don't know whether this is what you are looking for, as the watch comes with no packaged instructions OR general support, on their website, XD,
Nik.
http://home.earthlink.net/~eldonenew/armitron.htm
or
http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Armitron All-Sport Watch Instructions By Brian Walker eHow Contributor 9 Found This Helpful The Armitron All-Sport is a unisex style of watch made by Armitron that features a digital readout and four buttons around the outer dial for adjusting various aspects of the watch. It can set alarms, keeps the time as well as the date, and has a built-in backlight. Accessing and adjusting these various settings is a fairly simple process.
Other People Are Reading
Setting Date, Time and Alarm
  • To enter the date and time setting mode, press and hold the "mode" button, located on the top-left of the watch. Continue holding this button until the display begins to flash. This first display is the alarm setting, should you choose to set an alarm to go off. If you'd like to set the alarm, use the "alarm" button on the bottom-right of the watch to advance the hours to the desired one. Then press the mode button again; this will cycle through the minutes and seconds of the alarm to allow you to set those as well. Once you have set the alarm, you can press the "date" button at the top-right of the watch to proceed to the regular time setting. These numbers, which will now be flashing, also are adjusted by pressing the alarm button to change them. Pressing the date button again will now cycle through the hours, minutes, seconds and the date. As you continue to press the date button, the All-Sport will continuously cycle through these options; don't worry if you forget to set one, you can simply press the date button a few times until you get back to the setting you need to change. Once the alarm, time and date have all been set, you can press the mode button one more time to exit to the normal watch mode that will display the date and time.
Using Chime and Alarm
  • The Armitron All-Sport features both an alarm and an hourly chime. The alarm function will cause the watch to continuously beep at the selected time until you turn it off by pressing a button. The chime will cause the watch to beep once every hour. You can turn both these features on and off by pressing and holding the alarm button and while holding it pressing the date button. The first time you do this, the chime will turn on and a small house symbol will be displayed on the watch face. Performing this button-pressing sequence again will turn on the alarm, which in turn displays a small clock icon on the watch face. Each successive pressing of this button sequence will alternate between the chime and the alarm, turning them either on or off.
Backlight
  • The All-Sport also features a built-in backlight to help you view the watch in dark conditions. This light can be activated by pressing the "light" button on the bottom-left of the watch. Pressing this button is the only way to activate the light, and doing so will only cause the watch to illuminate for a few seconds at a time.
Read more : http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
6helpful
2answers
Setting Armitron Watch model WR330
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ARMITRON watch manuals. Rate me, please.
Mar 14, 2010 • Watches
Alarm light and fax light flashing screen shows printing fax data
The alarm light is flashing and the screen indicates read maintenance chapter in the user's guide.
1helpful
Brother HL-1440/ flashing alarm light and flashing yellow data light
(blinking every 5 seconds) Toner Low Indicates that the toner cartridge is nearly empty. Purchase a new toner and have it ready for when Toner Empty is indicated. (solid) Toner Empty Replace the toner cartridge with a new one. User's Manual is available at the following location: http://www.brother-usa.com/Data/Documentation/Printer/User/UM_HL1440_1450_1470N.pdf Hope this helps.
Norman Weimar
Norman Weimar
k24674
