Question about Hitachi 53UDX10B 53" Rear Projection Television
My Hitachi Keeps Turning Off
When i turn it on its turns right back off and i keep trying to turn it on but it just keeps turning off again.
I am having the same problem, when you turn the tv on the power light comes on and there is an immediate click as if a relay has tripped and then a shutdown. It started on an intermittent basis but would come on after several attempts clicking the pwr button on the remote. It was getting progressively worse (ie. more clicks and time before it started) so I took to leaving the tv turned on at all times. Everything seemed fine until a couple of weeks ago when we were hit with a power outage for 6 hours.....this was too much for the tv to take, and it has not been on since.
Standard operating procedure dictated removal of the back first (yes with it unplugged) for investigation and familiarization to see if the solution to the problem jumped out at me but again no luck as usual. There was however with no exaggeration up to an inch or so thick of dust and dog hair covering everything so first order of business is careful removal with air gun and vacuum of all this crud to eliminate overheating as the cause.
This work continues at present, will advise outcome
  • Anonymous Apr 14, 2008
    my tv after warming from 3-5 minutes shuts off and i keep turning it back on until i get aggrivated. please help me determine what the problem part is so i can order it and fix it.
    thank you,
    lori
  • 927 Answers
Good Day,
There is no common problem with this TV for the problems you all described. So, I would recommend that you all call a Factory Authorized Service Center to come to your home and give a written estimate b4 any repair is performed.
Good Luck, big IRISH.
Posted on Sep 01, 2008
My hitachi 32ld8600 keep turning off after 4 minutes
This is a good indication that the capacitors on the power supply are failing. Is it under warranty? If so, contact Hitachi to find a certified service center. If it isn't, you will have to find somewhere to take it to get the power supply replaced or fixed.
Apr 18, 2014 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
The hd tv keeps cutting out and saying no signal
It not the tv,u restart the Sky HD box the signal come back right?The Sky HD box is the problems,replaced the box,u will solved this problems.
Apr 22, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Hitachi Plasma TV 55HDT79 that is turning on and off and back on
Go Setup in the menu. At the bottom you will see Reset The Software when power is turned off. Switch this to No.
Apr 21, 2010 | Hitachi 55HDS69 55 in. Plasma Television
Pioneer DEH-P3100UB car stereo keeps turning off and on again
broken wire, or dirty connection....oh check your ground wire for radio...
Jan 04, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
Compressor keeps turning off
that know your turning is the defraost timmer
itg should turn the machine back on in like 20 min
if its not turning the machine back on then its bad
Oct 07, 2009 | Daewoo FR062R Compact Refrigerator
Paper keeps feeding through and won't stop
Two possibilities;
One you have a messed up print job trying to print and when you turn the printer on the job just starts over.
Two the clutch that stops the pick roller is bad and the roller just keeps turning.
Unplug the machine from the computer and turn it off unplug power for awhile turn it back on not connected to the computer. If condition remains it is the clutch.
If condition goes away delete print jobs and re connect printer.
Hope this helps
Mar 26, 2009 | HP LaserJet 1300 Printer
My nokia n95 keeps turning itself off
my nokia n95 keeps turning of . every time i try to turn it on it turns on and keep restarting till the battery dies.. any solutin for it please.
Jul 05, 2008 | Cell Phones
sir i think theres something wrong with the power supply kindly check it out,,,thankss and hope too help you,,gud luck
Feb 26, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
182 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
