Question about NAD C720BEE Receiver
NAD CI 9120 (12 Channel)
I keep losing sound to half the speakers and my red light keeps popping on(protection mode) I turn it off and back on, works for a few minutes then goes back on. I air dusted it out, not sure what else to do.
Call a Tech?
Thank you,
Stephen
  • 20 Answers
Check all your cables, not likely but just in case.
Try removing all but two. Left and Right. Does it still happen,
If you can identify the speaker channel try swapping the speaker if possible.
It sounds like one of the speakers has an issue, could be a short in a cross over or speaker coil. If true the speaker is drawing too much current and causes the protect circuit to trip.
Depending on the quality either replace the blown speaker driver or purchase new ones.
If the speaker is not the issue it could be an issue with a power amp. Best to take it in for service.
Posted on Apr 03, 2008
Nad c370 keeps switching off
Check the speaker wiring for shorts, a common problem. If everything checks out there may be bad solder joints on the main board especially in the output stage, or there is a fault in one or more driver transistors.
Jun 02, 2012 | NAD C370 2-Channel Amplifier
Nad C350 2 channel Amp continually in protection mode
That could indeed be the issue, but you must check your speakers, wiring, and also the oupt stages for problems. Maybe the prtection circuits are actually doing their job. lol
Hope that helps...
Geno
Apr 02, 2008 | Audio Players & Recorders
NAD M3 power light turns red immediately and PROTECT message displays. Amp keeps functioning but volume control doesn't work up or down.
Hello
Check the connection to speaker with this amp, for any short or any other fault. disconnect the outputs, ie, speakers from the amp, and switch it On, and see the protect display comes or not. If it comes, the fault is internal and the set need service.
Your M3 dual Mono integrated amp, is of high output power and its outputs are protected against any overload or short circuit. If the system detect any among this condition specified above, it will show protect mode display.
Never load this amp, as protection display is there, as it may damage the speaker or its internal power amplifier section circuits, may cause more money to get it repaired. OK.
Jan 23, 2012 | NAD M3 Master Series Integrated...
I OWN A NAD M 25 ---7 CHANNEL AMPLIFIER. I AM USING 4 CHANNELS TO BIAMP MY SPEAKERS. ONE OF THE UNUSED CHANNEL IS SHOWING A RED PROTECTION LIGHT.THE BIAMPED CHANNELS ALL WORK FINE ...I HAVE CHECKED ALL...
The manual would suggest you have a problem.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-M25-Amps-manual/id/8043ci561/t/2/
Try unplugging all of the speakers and see if that amp is still distressed. If it looks clean and happy start adding speakers until it returns (or not).
Jul 03, 2011 | NAD M25 Amplifier
Losing the right channel
usually this would indicate a dry joint inside or some other temp related intermittent fault, component problem. Take it to a tech and tell them what happens
Sep 17, 2009 | NAD C370 2-Channel Amplifier
Sony STR-D590 RECEIVER
This is a power overload protection circuit, to prevent you from blowing out your speakers. It's measuring the amperage through the circuit; I suspect you have a short-circuit in your speaker cables (do you have pets?).
To check, disconnect all speakers, then add one at a time until the problems appears. When it does, that's the speaker wire to check.
Jun 27, 2009 | NAD C350 2-Channel Amplifier
I have an av316 NAD, surround sound Amp. Just got back from repair. The wires to the speaker may have been reversed when hooking, the amp went into protection mode, can I fix this problem. It wont come out...
Having the speaker wires hooked up backwords will not cause protect mode. If the wires were crossed (in other words shorted), that would. Disconnect all speaker wires, if the unit is still in protect mode, than the output transistors are probably shorted and the unit will again require service. Upon return from service, I would turn on the unit without speakers to insure that the unit at least works that far. Also, if you have an ohmmeter, measure across the speaker terminals. You should read either 3 or 6 ohms. If you read 0, the problem is a shorted speaker that then shorted the amp.
Keep us posted.
Dan
Jan 20, 2009 | Audio Players & Recorders
Nad c372 prob
The unit is detecting a problem and shutting down in what is usually called "protect" mode. Look for bad connections on the board near the voltage regulators.
Dan
Sep 05, 2008 | NAD C372 Amplifier
NAD C370 Right channel distortion
Sounds like you have lost the power amp transistor(s) or IC for this channel.
Aug 29, 2008 | NAD C370 2-Channel Amplifier
NAD C720BEE Receiver Logo
217 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
