Question about KitchenAid KUDS24SE Built-in Dishwasher
Replacing detergent dispenser on Kitchen Aid Model KUDI24SEAL3 Dishwasher
How do you replace detergent dispenser assembly? Do you need to remove the entire door panel?
  • The EE Mar 24, 2008
    Is there a replacement part for just the door that covers the detergent dispenser??
  • jercanfixit Mar 15, 2009
    My detergent dispenser has a broken latch and won't stay closed. I'm sure if I take the door apart I can install a new one but I am wondering if you can just by a new cover\door instead of replacing the entire unit.
    President:
  • 1,314 Answers
Send me an email at b4829@yahoo.com and ill send inst
Posted on Mar 19, 2008
Kitchen aid dishwasher rinse dispenser not working
Hello Cecil;
My name is Peter. I am a retired field service appliance technician.
Your problem is one of two components: Either the dispenser or the main control board. I will bet on the dispenser. Sears wants about $100.00 for the assembly. Go into the internet. Search W10195174. You can get this part for $38.00 plus shipping. If you install this part and it does not solve the problem, you can return for credit less shipping and restocking charges. Get back to me if it does not solve your problem. I have faith in you.
Do not ruin my record. I received three personal E mails today. Two were from people such as you advising they got his clothes dryer and her oven working. The other person we are still working on her refrigerator. Peter Goodwin, Glen Burnie, MD, Goodwinpeg@aol.com Keep me up to date.
1.) Dispenser assembly -
a.) Turn power off at the breaker box
b.) Replace as instructed on the video below.
Dishwasher Dispenser Assembly part W10195172 How To Replace
May 09, 2015 | KitchenAid Kitchen Aid KUDS35FX Dishwasher
How do I remove the suds after having used regular dishsoap instead of dishwasher soap?Kitchen aid dishwasher
you will just need to run it a few times. I know of no way to kill bubbles except to dilute them.
Oct 13, 2014 | KitchenAid Kitchen Aid - KUDS30FXBL...
Why does the low rinse light stays on?
The obvious answer is that you need to add rinse-aid to the rinse-aid dispenser. Barring that, then you probably have a bad level sensor in the dispenser and would need to replace the whole detergent/rinse-aid dispenser assembly. On the other hand, it could just be a loose or disconnected wire going to the detergent/rinse-aid dispenser.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 09, 2014 | Samsung DW7933LRABB
Top draw is stuck on rinse / can't move push button to go on anything else
make this tests and fix it. God bless you
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Jul 24, 2013 | Fisher and Paykel DD605FD Stainless Steel...
How much salt do I put in ,,, and why won't it
follow this steps and fix it. God bless you
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Jul 08, 2013 | Dishwashers
Dtergent dispencer does not open
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
Dishwasher suds up and leaks during wash
Suds in a dishwasher usually come from using too much soap or the wrong kind. Soap can build up over times causing problems. First start a cycle.Do not add detergent or any dishes.When it starts washing, pour a cup of vegetable oil directly into the tub. This will cut the existing soap suds. You may need to try this a couple time before the dishwasher will drain. After all suds have been removed, load you dishwasher and start a cycle filling the detergent cup up half way. If it goes through the cycle with no problems, you should be all set. Still have the problem? A rinse aid dispenser that dispenses too much rinse aid will also cause the dishwasher to suds up. You can remove the dispenser from the door, flush it out and reinstall. Make sure you turn the circuit breaker off before taking the door apart. After rinsing it out, do not add rinse aid. Try the dishwasher and see if the problem goes away. I've seen people accidentally put liquid dish detergent in dispensers too. A dishwasher that has suds is apt to leak. Fix your suds issue and you most likely will fix you leak
Dec 27, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
How do I replace myself the detergent/rince aid assembly on a Maytag Jetclean dishwasher EQ plus model #MDB9150WB? I only need to replace the door, but I don't see a part for that, just the entire...
Carol,
This is a simple repair. Remove the screws around the outer door edge and separate the door. The dispenser is clipped into position with several screws. Remove the screws and push the dispenser through the door.You can purchase the part from the link below.
Appliance & Refrigerator Repair
Mar 23, 2011 | Dishwashers
Soap dispensor on kitchen aid dishwasher is leaking
First try rinsing out the dispenser cup and switching to a gel detergent.
Second,the door is spring loaded, and the spring may need to be replaced.Do this byturning off the electricity, then removing the front panel of the dishwasher-loosen screws holding the cup to the door and replace the springs. If the cup does not have springs, then it probably works on a was motor or bi metal switch that can be changed.
I can also be a defective timer switch
Sep 19, 2010 | KitchenAid 24 in. KUDP01DLBS Free-standing...
Dishwashers Logo
1,701 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
