Question about Mitsubishi Diamond WD-65831 65" Projection HDTV
Blotches on screen.
I recently changed bulbs hopeing it would resolve the issue. It has not. There is one prominate greenish blotch about 1" in diamiter just left of center, then several faint dark in the upper right corner. What could be causing this if not the bulb?
    Sergeant:
    Champion:
  • 301 Answers
Suspect the optical engine. are they present after initial turn off before the blinking light comes on and the cooling process starts? if so then it will be optical engine issue. can be very pricey by the way
Posted on Mar 29, 2008
KF-50WE610 blotch of color on screen
Either dust/dirt inside (unlikely but possible) or a damaged optical light engine--Google the model number with "problems" etc.
Apr 17, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
I have a 50inch DLP Hitachi that is 3 and a half years old. I replaced the bulb about 5 months ago now the blacks are blueish and it has a greenish blotch on the screen. It also leaves an image on the...
Contrary to popular belief, any display product can have "Image Retention" and even "Burn-In". This is true for Plasma, LCD, LCOS, DLP, and CRT. I do not see a model number provided, but I would bet that you have an LCD rear projection TV rather than a DLP projection TV. If this is the case, the Blueish and Greenish blotches you are seeing on the screen are the result of UV light damage. UV light will move heavily damage the Blue panel, due it's short wave length. So, bad Blue or Green (absence or Blue) is typically the the first visual indicator of a problem. Replacing the Light Engine will resolve the problem.
Mar 15, 2010 | Hitachi 43FDX01B TV
Red spot, Yellow Spot, Blue scratch on the printing document
Hi hope you fine.
is it just a spot or a continous line kind of?
is just a spot check the service kit on the front door (ETB ) alighnment might be touching the prnt drum units.
Sep 21, 2008 | HP Color LaserJet 2600n Printer
Sony Trintron KV-36HS500 TV color distortion
Sounds like the set is out of degausing, you will need someoen with a degausing coil to come and fix it. Should take all of 10 seconds and cost $100 or less. Let me know if you need more help.
Tim
Sep 11, 2008 | Televison & Video
Dark Blotch on rear projection TV screen
usually these are caused by cleaning the screen with a damp cloth or fkuid rear projection tv's usually have two plastic screens separated by about quarter inch with bulbs between,one being a magnified screen.problem is,condensation can occur causing various blotches,letting the screens naturly dry out usually solves this but failing this you have to strip down and wipe them with clean dry cloth.be careful though the inside screen is very delicate.
Feb 21, 2008 | Televison & Video
Dark blotches / Dirty behind screen
it could be dust in the mirror or in the optics,in this set if im not mistaken you have acces to the mirror from the back, anywhere from 12-20 screws it sould be easy to remove plastic cover first and the the mirror.this mirror are very delicate you dont want to leave fingr prints on it it will show just like the dust is showing right know. taking the mirror off will also give acces to the lense.
use someting soft to clean it.
hdtvman.
Dec 28, 2007 | Mitsubishi WD-62528 62 in. LCD Television
Dark blotches behind the screen
When I had this problem with my 52525 I cleaned the bulb with a lint free cloth. The dark blotches went away.
Dec 28, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Purple blotches
Ok, so I'm about to flip a lid with my TV. I am showing purple quater sized blotches all over my screen. I bought it for a discounted price because of this issue, in hopes i could fix it. I took the back panel off the TV. ( about a 6in * 6 in plate) removed the light bulb and cleaned the bulb and lens, where the light bulb faced. I used a dust cleaner and special cloth. NOTHING! I took the entire front screen off cleaned it and then cleaned the mirror and second lens.... NOTHING! Then i heard that dusk sometimes gathers behind the lens and that should be cleaned. Try this, Its 4 screws, just be careful and remember the way you took it out, because it has to be replaced the same way.
Lindsey <3 AZ
Nov 28, 2007 | Epson Livingstation LS57P2 57" Rear...
VT45 Projector: Blue pixels throughout screen
If the problem is what I describe as a blue haze over the entire image projected, I was told this is a defect in the cable - we have a Dell Video Projector 2300 - and it takes only a dell VGA cable.
So, the problem is in the cable - solution is replace cable.
Feb 28, 2007 | NEC VT45LPK Projector Lamp for VT45
Mitsubishi Diamond WD-65831 65" Projection HDTV Logo
113 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
