Question about Jensen's VM9312 Car DVD Player
JENSEN VM9312 CAR DVD PLAYER HOW
HOW TO BYPASS THE PARKIN BRAKE
  • 6 more comments
  • Anonymous Apr 13, 2008
    is there a code that i can use to unlock it
  • Anonymous Jun 10, 2008
    jensen's vm9312 car dvd player
  • zeblangley Jul 28, 2008
    I Got the bypass code but my remote doesnt work
    no remote can i get the code in still
  • Anonymous Feb 23, 2009
    HOW TO ENTER BYPASS CODE WITH OUT REMOTE CONTROL
  • herrinlarry Apr 07, 2009
    dvd will not play because the pink brake wire is not hooked up. i want to know how to by pass parking brake to play the dvd
  • winslow16 May 11, 2010
    if you use the code to override does the pink wire need to be hooked up to anything or can it just stay unhooked
  • Anonymous Mar 13, 2014
    Car DVD player no sound
Go to am/fm
then open the settings screen
next on your remote type 5,4,3,2,1,0 listening for each beep
a new screen should come up
after that look for brake override
Posted on Mar 20, 2008
I just hooked mine to the ground wire or the frame just so its grounded and it works fine mines a vm9312
Posted on Aug 25, 2008
Hey,, nimrods,,,,,,
what if dont have remote
Posted on Jul 23, 2008
6ya staff
SOURCE:
Brake bypass without remote
My Jensen play on and off but it's on on the face
Jan 12, 2014 | Jensen's VM9312 Car DVD Player
Can i run my pink wire on my jensen vm9312 to the ground
yes, that will bypass the safty feature and allow you to play a DVD while the car is in motion.
Note ; you can also just enguage the park brake ONE CLICK and achiev the same.
Nov 01, 2011 | Jensen's VM9312 Car DVD Player
How do i by pass parking brake wire for indash dvd jensen vm9312 i'm puting it in old car no p.b.
Hi jason
To answer your question;
You do not need to connect that wire but you need to bypass the parking brake function in the menu.
Here`s the parking brake bypass procedure:
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number
entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
6: Use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another.
Hope this help Cheers
Apr 20, 2010 | Jensen's VM9312 Car DVD Player
Emergency brake wire connection
Here's a Bypass to solve that. Turn your 9312 on and set to radio then Using your remote enter 543210 and make sure you hear a beep each time, a new menu screen will pop up, click the hammer and screwdriver on the upper left side,Next press the menu line for brake override, a sub menu will appear, select ON,Press the X at the lower left of the screen and you're done enjoy and be safe.
Apr 12, 2009 | Jensen's VM9312 Car DVD Player
Need help bypassin parkin brake wire
yes it will.... it just wants to see an earth
Mar 21, 2009 | Jensen VM9510 Car DVD Player
Vm9312 jensen dvd bypass
I just hooked the pink wire directly to the same ground spot as the head unit and it works fine
May 05, 2008 | Jensen's VM9312 Car DVD Player
How do i do to bypass my jensen vm9312
go to www.ecoustics.com then click on forum at top click car audio then multimidea. and read Teir are bypass codes for several models here.just have to look for them.
Dec 18, 2007 | Jensen VM9510 Car DVD Player
Jensen's VM9312 Car DVD Player Logo
1,236 people viewed this question
Top Jensen's Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Jensen's Car Audio and Video Expert? Answer questions, earn points and help others
