Question about Kenmore Elite 21082
Calypso kenmore wash motion "kenmore elite" model # 110.21082000
Last night it keep saying the balance was off, so we would move clothes around, it would work another minute and do the same.. well I went ahead and cancelled the wash and then tried to start it again and now it makes a humming sound and it sounds like no water is coming thru.. we have no manuel, we moved like 5 times since we bought it. we have replaced the pump once since we bought it, could it be another pump problem and if thats the problem, why did it also keep saying it was unbalanced,,
Thank you!
    President:
  • 1,314 Answers
It could have something to do with the water flow as it uses water to help balance the load take the hoses off the water valves to see if they are clogged look at the screens push pause cancel twice to clear the error code kenmore is built by whirlpool so if you send me an email at [email protected] ill send you an owners manuel also get a mop bucket and stick the hoses down in it to make sure your valves are clear
Posted on Mar 19, 2008
    President:
  • Kenmore Master
  • 2,651 Answers
Very possible that you do indeed have a pump issue, try clearing the lint out if it, there is a mew pump/motor assy, its one piece, redesigned with a larger impeller and less room for lint to get **** in, if your pump clips into place onto the motor assy you have the older model. you can still pop off the hoses, and check for lint build up..... the reason it faults as an off bal is that it tries to spin with too much water in drum and throes itself off bal, def a related problem
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Kenmore elite calypso doesn't respond to buttons except cancel
I've had a similiar problem on my calypso. In my case the key pad would go dead after washing or pushing stop after a few minutes. If I unpluged the unit for a few minutes it would work again. This would appear to be in the controller board. I removed the board and inspected it finding no problems. After re-installing the board the washer appears to be working again. My conclusion is that there is a loose connector/connection. I'd suggest you remove and re-install all the connectors on the controller board. This is the board closest to the power chord.
Good Luck, George S.
Posted on Sep 24, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite washer model 21082000, won't
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
Where is the reset switch located on the Calypso
There is no reset.
Simply unplug for 40 minutes to reset the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 19, 2009 | Kenmore Elite 45986 Front Load Washer
Trys to spin but stops every time.
Sounds like you have a small clothing garment maybe a sock or similar stuck in the waste pump.
Take the lid off, Follow the bottom rubber hose inwards it connects to the waste pump, remove the hose from the pump and check inside the hose and the pump for clothing, make sure the pump spindle can spin round with your finger. Please make sure the power is switched off before removing the lid
May 29, 2009 | Kenmore Washing Machines
Plastic in drum
REMEMBER IN 4- 6 -8 MINUTES IS YOUR DRAIN AND SPIN CYCLE, PLZ INSPECT PUMP,,, AND SUMP THAT WILL RESOLVE YOUR PROBLEM
Nov 25, 2008 | Kenmore Elite 45986 Front Load Washer
Washplate problem Kenmore Elite Calypso washer
Hello genny2626
Welcome,
You said,your 6 year old Kenmore elite top loader's wash plate doesn't seem to go through its proper motions. When the lid is closed and the washer has filled and the agitating cycle begins, you can hear a vibrating noise as if the plate is trying to move on the gentle cycle, but when the lid is opened, nothing has moved at all. The drain and spin work fine, and the machine goes through an entire cycle without error messages, but the clothes aren't clean. You said, you have heard a lot of horror stories of how expensive these washers are to repair, so would like an idea of what's wrong beforehand.
Here are a list of common vibration noises
Noisy, vibrating, off-balance
 Is the washer level? Does the washer rock when pushed
against the corners?
The washer must be level. The front and rear feet must be in
firm contact with the floor. Check that the locknuts are
tightened. See “Level the Washer.”
 Is the floor flexing, sagging or not level?
Flooring that flexes or is uneven can contribute to noise and
vibration of the washer. A ³⁄₄" (1.9 cm) piece of plywood under
the washer will reduce the sounds. See “Location
Requirements.”
 Is the load balanced?
Evenly distribute the load in the washer basket and make
sure the height of the load does not exceed the top row of
basket holes. See “Starting Your Washer.”
 Do you hear clicking or other noises when the cycle
changes from washing to draining or spinning?
When the drive system shifts or the washer basket settles
between cycles you may hear noises that are different from
your previous washer. These are normal washer noises.
 Is the washer gurgling or humming?
Is the washer level? The wash load
should be balanced and not overloaded. The washer must be
level. The front feet should be properly installed and the nuts
tightened. Reset the rear leveling legs (if needed). See the
Installation Instructions.
Did you completely remove the yellow shipping strap with
cotter pins? See the Installation Instructions.
• Are the gears engaging after the drain and before spin, or
is the upper part of agitator clicking during wash? These
Let me know if any of these are the solution!
Huuum
Oct 13, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite calipso was motion
calyso is a low water use machine similar to front loads only enough water enters machine to get clothes soaking wet water is recirculated through tube on back right corner of tub to insure clothes are soaked if pressure switch determines minum water level not reached it will add more
Apr 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Calypso Wash Motion
Basically its saying that the motor is pulling very high amperes. This could signify a faulty motor, motor controller, or thermal protector, or there could be a mechanical bind in the transmission. i would use a amprobe and check to see how much power is being pulled when the machine starts, and as it is operating if it is 5.55 amps or greater and higher than 20 amps on motor start surge, than the motor controller is correct in saying there is a problem. ------Dont forget to rate my help!!!!!! thanks
Sep 30, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
265 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
