Question about Dell 1815dn All-In-One Laser Printer
Scanner locked has been setting for awhile. I just reinstalled it. readout says to unlock scanner. Can't find the manual. What do I do/ thanks
  • 1 more comment
  • gschneider Jan 06, 2009
    i pulled the blue switch and then shut down the printer. when it starts back up i get this clicking noise. but the screen still says scanner locked. any ideas?
  • cfamer Jan 15, 2009
    My scanner say i need to unlock it but I can't find the toggle switch. there's a blue wheel but that doesn't seem to do anythign when turned. Any ideas?
  • Anonymous Apr 10, 2009
    Thank you!!
There's a little blue toggle switch where the copies/scans come out from.
Pull the blue switch toward you, turn off the printer, wait a few seconds, and turn the printer back on.
Posted on Jun 25, 2008
Thank you, thank you for this solution
Posted on Sep 25, 2008
SOURCE:
I'm using the pre set cb radio band to scan cb, howevre I locked out a few channels that I would like to unlock. how can I do this?
press the manual button until you get to channels you locked out, then press Lockout and they will unlock.
Thanks,
Dodgem250.com
Apr 15, 2010 | Radio Shack Pro-97 Handheld Scanner
I continue to get the message Scanner cannot be initialized. I have already removed and reinstalled the program and still get the same message.
It's a problem with the scanner hardware. Make sure the lock on the scanner isn't set. Some models come with a locking switch under the scanner or at the border of the scanning plate towards the back of the machine.
If the scanner is unlocked or it doesn't have a lock switch, then is a unrecoverable hardware failure. You should replace the scanner or get it repaired.
Oct 27, 2009 | HP ScanJet 2200C Flatbed Scanner
Digital readout 396 scanner
http://marksscanners.com/396/396.shtml
Feb 02, 2009 | Uniden BC92XLT Handheld Scanner
Samsung CLX 3170 scanner locked
Many scanners contain a scanning head lock to keep the scanning head from moving during shipping. This may still be still be in the lock position. All scanners are different but check the documentation on how to remove the head lock.
Dec 25, 2008 | Samsung CLX 3160fn All-In-One Printer
Scanner problem
To unlock a channel, press 'manual' & keep pressing it until you reach the channel that's locked out, then press 'L/O'. Repeat until all channels are unlocked.
To program, press 'manual' until you get to the first "empty" channel, then enter the desired frequency using the keypad, then press 'E'. Repeat as needed.
Dec 21, 2008 | Uniden BC72XLT Handheld Scanner
Lock out
press manual then scroll though the stored frequencies press the unlock button when you find the number you want, hold down till you get a beep sound. key icon should be displayed and will show that it has unlocked. then resume scanning
Nov 23, 2008 | Radio Shack Pro-95 Handheld Scanner
Xerox One Touch 2400 - Problem please help
Shut the computer down.
This makes sure the message is cancelled
Unplug scanner.
move the lock to -unlock
plug scanner in
restart compute
tell us what happens
Aug 18, 2008 | Xerox One Touch 2400 Flatbed Scanner
Scanner Locked
On the underside of the scanner assembly is a LOCK, it has two positions LOCK and UNLOCK. The manufacturer sets it to lock so the scanner doesn't move during shipment. You should be able to slide this to the unlock position.
Jun 12, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Scanner lock is on
Do you not have a manual or 'get you started sheet?' It is the first thing you do when unpacking a scanner is to unlock the shipping lock. In all probability it is under the scanner base so if it is a lifting item[to access the printer] check there,or on the backplate of the scanner where all the sockets are. Failing that get onto the Tech support site at Canon.
May 16, 2007 | Canon MP830 All-In-One Printer
Dell 1815dn All-In-One Laser Printer Logo
3,176 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
