Question about Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player
Radio install Courious to know how the pad on a 97 Jeep Wrangler is removed to install an aftermarket radio
    Problem Solver:
  • 15 Answers
It's not that hard to remove the panel you'll need to pop up the defrost dashboard trim with a flat head screw driver and then you'll reveal the top screws for the center panel, then you'll need to pop out your ash tray and reveal the bottom screws. after all screws are out you'll be able to remove center panel by hand. then there will be 4 bolts holding your radio to the dash that you'll need to remove and you're done.
Posted on Oct 04, 2009
Radio wire configuration 97 wrangler
Red constant power yellow accessory black ground blue is power antenna
Apr 11, 2014 | 1997 Jeep Wrangler
2001 Jeep Wrangler makes whistling sound except when you accelerate. Everytime you put your foot on the gas, it stops....take your foot off the gas and it whistles
if you have an aftermarket intake on the jeep the throttle body is making the whistle... there are many aftermarket throttle body spacers out there that can eliminate this...
if you dont than I think that we have the same problem... might be a vacuum leak if the jeep idles funny or it could be an exhaust manifold leak... I'll let you know if I figure out mine. :)
Oct 03, 2009 | 2000 Jeep Wrangler
1998 Jeep Wrangler - Radio and Wipers stopped working
Some of the factory and aftermarket radios have a fuse in the rear of the unit. You will need to remove the radio from the dash to check it. It will have a spade type fuse in it. If it is bad the radio will not work.
Aug 29, 2009 | 2003 Jeep Wrangler
Need to know how to take apart dash to replace radio
Likely it's not much different than ones just a bit older...remove the bottom panel and any screws along the bottom of the plastic dash face plate. The top is held on with clips and it should pull out, exposing the radio mounts. Go from there. They make a face plate adapter for the radio and a harness extension to help with wiring, available where they sell aftermarket radios.
Jul 20, 2009 | 2008 Jeep Wrangler
Need to install cd player in 97 wrangler. need to know which wires are speaker ground power etc.
easiest thing to do is to go to best buy and buy a radio harness kit for $15-20 which will plug ontop of your radio harness so you don't have to splice any wires. the kit is a plug on one end and labeed wires on the other end that will tell you where everything you need is to install a new cd player in such as your power, ground, remote, and speaker wires...much easier to do then to splice and trace each wire.
Jul 11, 2009 | Wrangler Jeep Twin Stroller
I have a 98 Wrangler also and my problem is similar, only my dash lights and gauges work but lights on the center on my dash don't work, AC and Heat controls, I have an aftermarket stereo so it actually...
i had some similar problems after i installed my aftermarket radio and i had to go back and rewire it and now the dash works fine. you might want to double check your wireing. i know wiring a stareo is simple but after rewiring i didnt have any more problems with dash lights
May 09, 2009 | 1998 Jeep Wrangler
How to change starter on 1994 jeep wrangler
is it the straight six? if so first disconnect the battery then there should be 2 bolt 13 or 14 mm. take wires off. then reverse for install.
Mar 11, 2009 | 1994 Jeep Wrangler
97 Jeep Wrangler Dash Gauges Arent Operating..everything else ok!
check fuse #17 in fuse box under hood. It's a 10 red fuse. that's how i fixed my problem.
Dec 20, 2008 | 1997 Jeep Wrangler
Removed aftermarket radio from 1999 Wrangler, no gauges work now
first, you have to tape any open wires with electrical tape, so they DON"T short anything out again. second, check your gauge fuse.
Dec 04, 2008 | 1999 Jeep Wrangler
Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player Logo
133 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
