Question about Logitech (980361-0403) Headphones
Yes it is bluetooth, and already rapidly flashing.
Is there something I should do after it begins to rapidly flash? It has been for a while now.
  • 61 Answers
It should go off after rapidly flashing for a few times..Is this a bluetooth headphone ?
Posted on Mar 20, 2008
Why is my USB Bluetooth Adapter not showing up under settings?
Make sure the headphones are in the searchable mode or try searching from the headphones instead of the PC.
Oct 17, 2016 | Insignia Bluetooth Wireless Headphones...
How to pair a Plantronics Explorer 245 Bluetooth headset and a Samsung Intensity...
To pair a Samsung Intensity cell phone with a Plantronics Explorer 245 headset, follow the 10 steps below:
1. Turn your cell phone on and your headset off.
2. On the Intensity, press the Menu button (the center round button) and from the main menu, go to Settings & Tools (in the bottom right corner).
3. Select item #3, Bluetooth Menu.
4. Select item #1, Add New Device.
5. If your Bluetooth radio is currently off, you'll be asked if you want to turn it on -- select Yes.
6. Turn on the Explorer headset. After a few seconds you should see either red and blue flashes or just blue flashes. If you see red and blue flashes, go on to step 7. If you see only blue flashes, hold the Call button down (the button on the side of the earpiece) for five or six seconds, until the LEDs begin to flash red and then blue.
7. On your cell phone, click OK on the screen telling you to place your device in discoverable mode.
8. The phone will search for Bluetooth devices in the area, and the Plantronics headset will appear at the top of the screen. It should be labeled "245Plantronics" or something similar. Once you see the headset appear on the screen, press the menu button to stop the search.
9. Press the menu button again to pair the two devices.
10. A message will appear once pairing has been completed, and you will be prompted to connect the phone to the headset. Select Yes.
The connection has now been established between the two devices, and you can use your Explorer 245 as a hands-free headset in conjunction with your cell phone. To see information about the headset (such as what services it offers, what its Bluetooth address is, or how long it has been paired to your phone) scroll down to its name on the phone's Bluetooth Menu and click the right option button to bring up the device's Options screen.
on Oct 26, 2010 | Samsung SCH-U450 Cell Phone
we are getting a rapid flashing between the prime and coffee icons, flashing back and forth, when we push the brew button.
the machine does not need descaling, it primes properly when turned
on, it is only when I try to brew that it begins this rapid red flashing between the two icons.
Aug 08, 2013 | Saeco Coffee Makers & Espresso Machines
Why wont my logitech boombox go into bluetooth search mode
I had the exact same problem. Boombox flashing blue, but not rapidly flashing blue. I did two things that seemed to fix it:
1: Reset the device by switching it on, then holding both volume up and volume down buttons at the same time for 10 seconds. The blue flashing light will briefly flash quicker to confirm.
2: Switch off the boom box
3: Switch on using the power button and (very important) immediately press and hold the Bluetooth button. The Bluetooth button needed pressing and holding almost instantaniously after the power button for it to work for me. I had to try several times to get it to work.
When you do this successfully, the Bluetooth light starts flashing rapidly and it enters search mode.
I nearly threw my speakers away, now it works and connects fine :)
Oct 10, 2012 | Logitech Radio Communications
How does one turn on a Motorola 537w bluetooth
To power your headset on, press and hold the Multifunction for 3 seconds until LED flashes rapidly.
To turn your headset off after use, press and hold the Multifunction button for 3 seconds until the headset flashes rapidly and turns off.
Hope it helps
Apr 16, 2011 | OEM Systems Motorola Bluetooth Headset ,...
Earbud will not connect to lg env2
Pairing will create a unique and encrypted wireless link between two Bluetooth enabled devices, such as your Bluetooth phone and Bluetooth headset.
  1. Ensure that the headset is off (see Turning the headset on/off).
  2. Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
  3. Set your Bluetooth phone to discover the headset by following your phone's guide. Typically, the steps involve going to a 'Setup', 'Connect', or 'Bluetooth' menu on your phone and then selecting the option to discover Bluetooth devices.
  5. Your phone will find the Samsung WEP200 headset and ask if you want to pair with it. Confirm this by pressing the Yes or OK key.
  6. Enter a passkey or PIN, 0000 (4 zeros), then press the Yes or OK key.
wep200-5.jpg If pairing was successful, the indicator light will flash in blue 10 times rapidly before going to flashing every 3 seconds. If unsuccessful, the light remains on, and you will need to re-attempt pairing.
Dec 04, 2010 | Samsung WEP200 Headset
What is the passcode for the Scala LX700 bluetooth?
Four zeros is the PIN you want to use for pairing
  • 0000
That's also the default code for a majority of bluetooth headsets.
Here is the entire pairing process broken down:
1. Turn on your phone and make sure that its Bluetooth function is activated.
2. While the Headset is turned off, press the Wheel inwards for at least
8 seconds. The Status Light will begin rapidly alternating red and blue,
indicating that the Headset is in Pairing mode.
3. Using your phone, search for Bluetooth devices by following the
phone’s instructions.
4. After a few seconds the phone will list the scala-700LX as a “discovered
device”. Select it and follow your phone’s instructions to accept the pairing.
5. When prompted, enter 0000 (four zeros) as your PIN or passkey.
6. Your phone will confirm that Pairing was successful and the Headset’s
Status Light will begin flashing slowly in blue.
Apr 22, 2010 | Cardo scala 700LX Bluetooth Headset
Have blackberry flip phone, blue tooth worked fine,now shows bluetooth:disabled, can't get it to work HELP gene
Hi to enable Bluetooth follow the steps given below: 1. Click on OPTIONSfrom the main Menu 2. Click on Bluetooth then 3. Click on the Menu key (which is next to track ball) 4. click on Enable Bluetooth If you find any problem please contact the Service Provider of your SIM Thank you for using Fixya
Nov 13, 2009 | Cell Phones
Got a New Nokia BH-106 bluetooth Headset, i'm
i purchase new Nokia bluetooth headset BH-106 and i want to connect my laptop ( Dell INsprion N5010) plzz give some advise who to connect it.
Sep 21, 2009 | Nokia BHF-2 Headset
Guitar hero world tour for ps3
i had the same problem but with trial and error i came up with a soulution
1. Turn on the Playstation 3
2. Plug the dongle for the drum set into an open port on the PS3, the light will begin to flash slowly.
3. Hold down the button (where the light is flashing) on the dongle until it begin flashing very rapidly. Release the button and the light continues to flash rapidly.
4. Hold down the PS button on the drum set until the red light starts flashing rapidly.
5. Within a few seconds you will get a solid light on both the Guitar Hero World Tour Drum Set and the Playstation 3.
Jan 04, 2009 | Video Game Consoles & Games
Logitech (980361-0403) Headphones Logo
77 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
