Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Standby/timer light The TV is working fine. The standby/timer lights continues to flash. How do I turn it back off?
  • Enbridge Mar 28, 2008
    Unable to turn on the tv. standby light is on.
    Sergeant:
    Champion:
  • 375 Answers
Check your menu settings to see if your off timer is activated or set.
Posted on Mar 20, 2008
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
Tv will not stay on standby timer light flashing
On Sony the standby or red is for shutdown---
If you unplug the set and plug it back and turn it on and it repeats this look to see if the light is either constantly blinking or blinking a specific number of blinks---specific number would be an error code.
Apr 29, 2012 | Televison & Video
My Sony tv will not turn on. The standby/timer light keeps flashing red.
Problem with the Sony Trinitron KV-J16PF 20" TV The standby/timer light keeps flashing red
Jun 07, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My standby/timer light is flashing and will not turn on.
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jun 02, 2011 | Sony KV-27S66 27" TV
My Sony Trinitron TV 1999 (KV-32V42) made a strange popping sound and I lost both the sound & picture. When I turn it back on, the two red lights on the front of the TV(standby/Timer light & Stereo...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Hlp 5063w on off front button flashing lamp then stanby..hear sound no picture.. shuts off then comes on.
If the lamp and standby lights are both flashing and the timer light is off, check that the lamp cover on the back of the TV is properly positioned in the groove and secured by the screw. Take it off and check that the screws that hold the lamp itself are secure. There is an safety feature that keeps the lamp from turning on when the lamp cover is off.
If the three lights (timer, lamp, and standby) are blinking, then the lamp needs to be replaced. If the timer and standby lights are blinking and the lamp light is off, then a cooling fan isn't working. When only the standby light is blinking and the other lights are off, the unit is overheating and a ventilation area may be blocked.
I hope this helps.
Sep 30, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
TV went off, standby timer light flashing
Try unpluging from the wall and theplug back in and try turning back on to reset. Sometimes holding the power button in while pluging back in will reset it, every brand is different for the hard reset.
Scott
Apr 17, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
244 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
