Too much blue on LCD TV display
Just brought a new Samsung LCD TV and the picture contains a lot of blue pixels/rings/blobs?! especially noticeable on skin and sky/light colours. Is it one of the settings, have tried changing most things but cannot get rid of the blue lines.
SOURCE: Samsung LE32R7 Picture Flashing
I have a 37"Samsung LCD and having just spoken to the Sky engineer (also a friend) he says it is a national problem between Sky+ and Samsung. I have the same problem when on playback but not on real time? If you had your box changed to an Amstrad what sort did you have the problem with?
Posted on Apr 21, 2008
  • 6 Answers
SOURCE: We have a samsung 50"
If the samsung is more than two years old it is probably the Tv. I have a 42" samsung and the color blue will appear all over the tv for awhile and then go away. It started after two months and I just thought it was from playing xbox. I believe its a known defect in the tv or related to burn in. If you got it from a store use your coverage on it
Posted on Apr 29, 2008
chrispurs1
  • 372 Answers
SOURCE: The picture on my goodmans
Hi.
Your problem sounds like the lead that connects from main pcb to the lvds pcb.
These have gold coloured connections that become tarnished & dont make good contact.
You can try to sort this out your self but please be very carefull the fine wires on the plugs can be easily damaged.
If you do decide to have A go you will need tin of air duster & elecrical spray switch cleaner, You are only to clean plug & socket connections on lvds lead & pcb.
http://dysonmanuals.llc.nu/
Posted on Jul 13, 2008
Benimur
  • 6966 Answers
SOURCE: My new Samsung flat panel
At best described, your unit is getting RFI (radio frequency interference) or basic electrical noise. Such could be brought about by other electronic devices physically near the Samsung flat panel LCD TV which may include (but not be limited to wireless phones, electronic ballast of florescent lamps, VCR/DVD/Gaming consoles with Channel 3/4 outputs.
Possible corrective actions:
  • the simplest, move such devices away;
  • try using a power filtered strip;
  • try plugging other devices in another wall outlet.
The technically correct procedure would be to improve the shielding of all these devices including the Samsung but that would be beyond normal user actions. Additionally, it should have been addressed in the manufacturer's design in the first place.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 03, 2008
romsky79
  • 822 Answers
SOURCE: Vertical lines showing in picture, especially noticable on black
in these issue you can see vertical lines due to filter capacitors bad in the secondary power supply. 100micfarad/j35volts, 220microfarad/25volts.
Posted on Jun 09, 2009
Screen is displaying Red background color with glittery pixels effect around the figures
Please change the T-CON board, if it did not fix the problem, you may have a defective LCD Panel.
Apr 24, 2017 | Samsung LN52A650A LCD TV
Bcoiradas@aol.comhi ibe got some blue little blobs appering on the screem and some little lines coming from them . please help ive got a samsung le40m87bdx
Hi, A lot of these LCD screens have the same problem (strip of white,blue,red) lights on the screen.
Try this move the TV to another room to rule out any interference. Check all connections on back.
Good luck.
Aug 04, 2011 | Samsung LE40B553 40 LCD TV
Pixelated lcd tv picture
it indicates that the problem is aspect ratio or pixel settings for thescreen
bring up the on screen menu and adjust the pixel setting to fit the screen or the apsect ratio to fit the screen
read the operators manual to see how the adjustments are made
May 19, 2017 | Sylvania LC370SL8 37 in. LCD Television
usually this issue is caused by a week signal issue, those tv's need a stronger signal than an analog tv, i would call the cable company, have them come out and hook a meter to that cable, they may sujest a house amp, usually charge 50 bucks for it
Jan 11, 2009 | Televison & Video
SOMETIMES I CAN SEE A BLUE DOT ON SCREEN
Most manufacturers consider a few dud pixels to be normal and not a defect. Especially if not in the center of the picture.
Don't get fixated with watching the dot, look at the overall picture. It is like staring at a pimple on a pretty lady's chin.
easyab
Aug 20, 2008 | Samsung HCN4226W 42" Rear Projection...
You need to get your sky box changed! just ring them up and tell them your problem. the TV is a known issue with certain boxes.
Feb 14, 2008 | Televison & Video
Samsung plasma PS42D5S
You need to adjust the panel voltages, adjust the VS voltage to around 186 volts, if that doesn't change it then adjust the V-Scan voltage down, turn the unit on and apply a video source to it, and while adjusting the voltages look at the screen and you should be abe to watch the video noise fade out.
Dec 14, 2006 | Samsung PS42P2S 42 in. Plasma Television
Televison & Video Logo
304 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
