I have a desktop dell runining XP software. I have a tungsten E hand held. I cannot get the contacts on the handheld to appear on the screen of the desktop. I just tried putting a new contact in the desk top and it does not showup on the hand held. The hot sync appears to be working properly but the desktop amd hand held are not communicating in contacts. I tried reloading the software, that did not make any difference. Thanks, Terry Gargan
    President:
  • 1,017 Answers
Try right click on the Hot-Sync icon, on the Taskbar and select Custom then select Address book and change the Action to Synchronise the files. You might have to use Windows Explorer to view your contact. I'm not 100% sure about this one but try it anyway.
Posted on Mar 20, 2008
I have a Tungsten E2 and I receive a message that my Handheld is only compatible up to Microsot Outlook 2002 and I have Microsot Outlook 2007. Do you have a patch or update for this?
there is no patch or update for this. You will have to get Microsoft Outlook 2002 because Microsoft Outlook 2007 cannot work with your Tungsten E2
The Tungsten E2 has been programmed by the manufacturer. It is only when you go for a higher Tungsten Hand-held, that you will be able to use Microsoft Outlook 2007.
Take care.
Aug 10, 2010 | Palm Tungsten E2 Handheld
Got a new computer with windows 7. Downloaded latest software for palm. It won't sync with my tungsten e handheld using a usb cable. I have all the latest information in the desktop software on another...
well i had the same problem, and the problem turn to be that the latest software is ****! uninstall that software and install the palm desktop 4.14 that should do it! its sound like old but its the same thing!
Jan 24, 2010 | Palm Tungsten E Handheld
When using palmtungsten e2 message appears "Reset memory Mgr.c line 3751 free handle"one of my program i cannot use. thanks help who do i contact
The first thing to do is to make sure you have everything backed up on your PC. Then do a hard reset. Here are the directions for that:
1. Press and hold the power button.
2. While holding the power button, use the tip of the stylus ( or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your hand held.
3. Wait for the Palm2.gif Powered logo to appear, and then release the power button.
4. When you see the message that warns you about erasing all of the info on your hand held do one of the following:
a) Press UP on the 5 way navigator button on the bottom of your hand held to finish the reset and show the touch screen2.gif.
b) Press any other button to do a soft reset.
5. When prompted , tap to align the screen, and then set the language you want to use on your hand held. A screen appears showing the Palm logo and a progress bar. From there continue to set up your Palm and then do a hot sync. Best wishes....Hope this helps.
Sep 18, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Usb connection in my Tungsten e handheld is not
DO NOT ATTEMPT TO FIX. Ebay and get another. Trust me.
Aug 22, 2009 | Palm Z22 Handheld
Palm will not turn on
have you tried a hard reset?
Todo a hard reset, First press and hold the power button, while holding the power button use the tip of the stylus to gently press and release the reset button. wait for the logo to appear then release the power button.
when you see the message that warns you about erasing all of the info on your hand held press up on the 5way navigator to finish the reset
Dec 21, 2008 | Palm Tungsten E2 Handheld
Desktop software
Please click the below mentioned link to download the desktop software for Palm Tungsten E2:
Palm Desktop 6.2 and HotSync Manager 7.0 for Palm Tungsten E2 (Vista/XP)
Thank you
Aug 08, 2008 | Palm Tungsten E2 (Multilingual) Handheld
Appropriate software for tungsten e2 palmOne
If you said you have the software (desktop), your doing it backwards. Run the desktop software by going to my pc and running the disc. The software will then ask you to plug in your E2 so it can register it. It will then synch and your in business. Had E2 for a very long time. Can tell you things that guy can do that would surprize you. Have everything but unit now.
Mar 15, 2008 | Palm Tungsten E2 (Multilingual) Handheld
Hot Sync with desktop and laptop computers
it is possible but if I well understood u wanna hot sync with ur laptop calendar and contact from ur Tungsten E, (that is having updated data from ur office computer). you can in fact synchronize verything there with ur laptop, and make ur hand held over write ur whatever is in ur laptop, for this u need to install the PDS and go to the hotsync manager on ur system try, go to custom and and on the list of conduits go to contact and change the action to hh overwrite desktop, (do the same for calendar) DON"T FORGET TO CHECK THE OPTION : MAKE AS DEFAULT. U can of course disable the rest except the system conduit. Never forget to set the conduits u change to set as defaults. Like this, u must have always updated data on ur hand-held, for this, u need to keep synchronizing with ur office computer. good luck,
Sep 12, 2005 | Palm Tungsten E Handheld
Tungsten E- Synch appears to work but nothing actually happens
1. Go to red/blue arrows in lower right corner
2. Right click and select custom
3. Make sure pc know WHAT you wish to transfer and direction
You might not be letting it overwrite anything
Computers & Internet Logo
132 people viewed this question
David Payne
David Payne
