Can you tell me if a Linksys Router will work with Windows 2000(Millenium) - XP or Vista. I have a Linksys Router Model # WRT54G. My friend also has a Linksys Router (I dont know model # of that one. He is trying to use it with a 2000 (Millenium Windows )& and an XP computer. & is having trouble. Does it work for Laptops & desktops.
  • 4,234 Answers
This should work fine. Report here with the specific problem that are being encountered and we should be able to determine whether or not the actual hardware has a problem.
Dan
Posted on Mar 19, 2008
SOURCE:
I have drivers for windows vista but they can not be installed on windows 7. I need install my router on windows 7
If you have the Windows Vista or Windows XP driver, try installing in Compatibility Mode. Here's a tutorial I've posted recently (click HERE.), but please select Windows Vista instead of Windows XP. There isn't problem even if you select Windows xp, but since it's windows vista driver, that should work perfectly.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
May 26, 2011 | Linksys Wireless-G WRT54G Router
I am not able to connect to the internet using my Linksys WRT54G V8. When I connect the cable directly to my laptop, I am able to access the internet, so it is definitely a problem with the wireless...
Title: Setting-Up a Wired Computer to Obtain an IP Address Automatically Article ID: 4033
Configuring a wired computer to get an IP address automatically will enable it to get an IP address from a DHCP server. Instead of manually entering the IP settings which will consume much time, performing this procedure will ensure that the computer will get the correct TCP/IP settings.
Configuring a computer to get an IP address automatically is useful when:
  • Connecting a computer to a network with a DHCP server. Ensuring that the computer is getting the correct TCP/IP settings.
To configure a computer to automatically get an IP address, you have to check the TCP/IP properties of the Ethernet Adapter installed on the computer. Follow the steps below for instructions.
NOTE: Make sure the wired computer is properly connected to a network with a DHCP server.
Checking if the Computer is Set to DHCP
NOTE: The instructions provided below only apply to Windows 98, ME, XP and Mac operating systems. If you are using Windows Vista, click here for instructions. For Windows 7 users, click here for instructions.
Windows 2000/XP
Windows 98/ME
Mac OS
Sep 29, 2010 | Linksys Wireless-G WRT54G Router
I have the Linksys WRT54G router hooked up thru Ethernet to my desktop PC with Windows XP. I go thru a cable modem to the internet. I have 2 laptops, both with Windows Vista on, wirelessly linked to to the...
Low or poor signal is mainly caused by the following major factors:
Going Around Physical Obstructions
Wireless networks are also susceptible to obstructions that may lead to low signal. Often, the signal gets reflected, refracted or absorbed by the obstruction.
Common obstructions are:
  • Cabinets
  • Mirrors
  • Glasses
  • Metal objects
  • Thick walls and ceilings
If you have any of these objects between your wireless adapter and access point, consider relocating your access point somewhere high to get around the obstruction.
Aug 05, 2010 | Linksys Wireless-G WRT54G Router
Installer for windows vista
Plug into router with an Ethernet cable, logon with the word admin, & use admin as password, Then in the left hand side you will see a Setup Wizard, run this wizard, fill in the SSID (The NAME YOU Give it) & Your ISP's Details, & DNS. also Your logon & password for your internet account. When finished make sure you "Save" your configuration.
Feb 10, 2010 | Linksys Wireless-G WRT54G Router
Wrt54g linksys problem
are you trying to set up the router for the first time ?
OR the router was working before and you are trying to add a new windows 7 computer to the network ?
If you are trying to set up the router for the first time then you can do it manually without the CD also.
If your router is already working and you want to add the computer to the network then you just need to connect to the network
Click Here for more info
Dec 26, 2009 | Linksys Wireless-G WRT54G Router
Remote Assistance Firewall Issues
Use Crossloop. Each session is encrypted and doesn't require turning off firewalls in your routers. You will have to give it permission to run in Vista and XP, but it works and I've used it many times.
If this is what you're already using, go to their help page to resolve the problem.
Hope this helps.
Mar 24, 2009 | Linksys Wireless-G WRT54G Router
Routers
Yes, this will work fine on any operating system Like Vista , all of the new Linksys router now like this one is already made to work with Vista operating system....
Hope that helps........
Oct 05, 2008 | Linksys Wireless-G WRT54G Router
WRT54G linksys router
The first thing I would do is check to make sure the desktop with XP has the network card set to "obtain an IP address automatically"
if it is set to obtain an ip address automatically, I need to know the following:
What is the IP addresss of the router?
What is the IP address of the Vista computer?
What is the IP address of the xp computer?
You can find the ip address by going to start, then run, then type cmd and hit enter. at a command prompt type: ipconfig and hit enter.
Feb 21, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
New vista HP computer wont send e-mail
try to dl all latest updates and linksys latest driver for your os ok
Feb 09, 2008 | Linksys Wireless-G WRT54G Router
The Computer doesn't recognize the Router (And Yes. the wireless switch is turned on)
DON'T use the software.
Are you trying to connect by way of ethernet cable or wireless?
Either way you do it, you do NOT need that crap software. 90% of the time, that software interferes with everything. Up to AND INCLUDING preventing your system from connecting to the router.
Before you can get any help with this, you will need to give us more information about your setup.
NOTE: We CAN NOT POSSIBLY figure out all of the variables if you do not give them to us. So don't go marking my post as "Thanks for trying" just because your problem is not solved in the first post.
Instead, if you want answers, you're going to have to be more specific.
I see a Linksys WRT54G wireless router. Is there a version number on there?
Example: WRT54G v3 (Mine.)
You're also going to have to tell us more about your computer. Is it Windows XP? Service Pack 1/2? Windows Vista? Linux even? (Give model numbers if it's a pre-built system from an OEM manufacturer such as HP, Dell, etc.)
Then there's the internet connection. Cable internet? DSL? Satellite? Give us MODEL NUMBERS of the equipment they have issued to you for your internet connection.
Then tell us how you have things connected. Wireless? Ethernet cable? What is connected to what?
See what I mean?
FULL details bring quicker resolution of your problem. I will be monitoring this post as you seem capable of providing this information to us. When I see more complete information, I will help you further from there.
Thanks. :)
Cyryl
Nov 21, 2007 | Linksys Wireless-G WRT54G Router
Open Questions:
Comcast Technical Support Phone Number # I:8OO-828-O294 .U.S.A This Comcast USA phone number is ranked #2 out of 2 because 7,728 Comcast USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the Comcast USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, Comcast USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. Comcast USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact Comcast USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling Comcast USA Calling Comcast USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from Comcast USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with Comcast USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare Comcast USA's phone numbers against each other. Contacting Comcast USA in General While I8OO8280294 is Comcast USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach Comcast USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact Comcast USA.
Oct 16, 2019 | Best Computers & Internet
BITDEFENDER tEcH SuPpOrT PhOnE /@\{18OO8O3/@\1O69} NuMbEr .U.S.A AsIf This BITDEFENDER USA phone number is ranked #2 out of 2 because 7,728 BITDEFENDER USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the BITDEFENDER USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, BITDEFENDER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. BITDEFENDER USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact BITDEFENDER USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling BITDEFENDER USA Calling BITDEFENDER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from BITDEFENDER USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with BITDEFENDER USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare BITDEFENDER USA's phone numbers against each other. Contacting BITDEFENDER USA in General While I8OO8O31O69 is BITDEFENDER USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach BITDEFENDER USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact BITDEFENDER USA.
Oct 16, 2019 | BitDefender Computers & Internet
BULLGUARD tEcH SuPpOrT PhOnE /@\{18OO8O3/@\1O69} NuMbEr .U.S.A AsIf This BULLGUARD USA phone number is ranked #2 out of 2 because 7,728 BULLGUARD USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the BULLGUARD USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, BULLGUARD USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. BULLGUARD USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact BULLGUARD USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling BULLGUARD USA Calling BULLGUARD USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from BULLGUARD USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with BULLGUARD USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare BULLGUARD USA's phone numbers against each other. Contacting BULLGUARD USA in General While I8OO8O31O69 is BULLGUARD USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach BULLGUARD USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact BULLGUARD USA.
VIPRE tEcH SuPpOrT PhOnE /@\{18OO8O3/@\1O69} NuMbEr .U.S.A AsIf This VIPRE USA phone number is ranked #2 out of 2 because 7,728 VIPRE USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the VIPRE USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, VIPRE USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. VIPRE USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact VIPRE USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling VIPRE USA Calling VIPRE USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from VIPRE USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with VIPRE USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare VIPRE USA's phone numbers against each other. Contacting VIPRE USA in General While I8OO8O31O69 is VIPRE USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach VIPRE USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact VIPRE USA.
Computers & Internet Logo
94 people viewed this question
Ekse
Alun Cox
