I do not have the software to install my lexmark4200 all in one printer. where can I get this software?
    Problem Solver:
  • 4 Answers
Lexmark.com they usaully have the software/driver for your product
Posted on Mar 19, 2008
SOURCE:
Problem with instalation
Whenever you install a printer you should install the installation software that came with the printer before you connect the printer. Usually the installation software will tell you when to connect the printer and then it will configure it and print a test page. I would go to add/remove programs and remove any remove any software you have installed for the printer. Then remove the printer from the control panel at the printer icon. Then disconnect the printer and re-start the computer. Now use the installation cd and follow it's instructions.
Sep 26, 2009 | HP LaserJet M1120 MFP All-In-One Printer
Message about software not in effect
First - did you have the printer turned on before installing the software? Printer MUST be ON!
Second - did you install the software before plugging in the usb cable? Printer must be on when cable is plugged in, and should not be plugged in until installation software says to plug it in.
Third - you must completely uninstall any previous printer installations you've done for that printer before attempting another installation. If the printer doesn't work after an install, you must delete the printer under "Printers" in the control panel, and check to see if you need to uninstall the software through the Add/Remove programs portion of the Control Panel. If you do a new install over a bad install, the printer still will NOT work. You must meet ALL these conditions to make the printer work.
Last, but not least, download the printer software from the manufacturer and not from a third part vendor, and make sure you select the correct operating system when you select the software to download.
Apr 20, 2009 | Compaq A1500 All-In-One InkJet Printer
Lexmark4200 series fax machine
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Jan 09, 2009 | Lexmark X4270 All-In-One InkJet Printer
I have a Dell XPS420 & I have a Lexmark4200 it is an all in one
The key will be the drivers. If you have an install disk for the fax, copier, scanner and it loads without problem then it should work.
Dec 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
J5780 Installation Problem on Windows 2000 PC
hi this is due to improper Software Installation stapes below
  • Un install all printer driver & software u install
  • disconnect printer from computer
  • restart u r computer
  • insert Software cd in to cd rom
  • install software ,follow instruction & fill up Information.
  • when notify you to please connect printer thorgh USB please connected Usb cable to your Printer.
  • printer shuld be ditected then follow instruction
  • complite Installation & cheak it out..
If this information is useful for u please rate me....
Jun 09, 2008 | HP Officejet J5780 All-In-One InkJet...
Have new hp computer lexmark4200 wilol not printcan not understand the people on the phone with foriegn accents please help
To use a new printer on your computer, you need to install driver for that printer.
Check out there must be a setup CD/DVD shipped with your printer. If got it do the following steps.
  1. Remove all connection from printer to computer.
  2. Put the CD/DVD in computer.
  3. It will start automatically
  4. Follow the simple on screen instructions
  5. If setup display any message to connect printer, then connect your printer to computer and on it.
  6. After setup finished, you will able to use your printer.
If any problem....just Ask me
Gud luck
Iqbal
Apr 15, 2008 | Office Equipment & Supplies
PRINTER
well..do you have good drivers for it? the cd may not be current..try this link to find out if there are better ones.
Mar 23, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark4200
mstull3219, hi, I looked all over their (lexmark) support and did not see anything to do with windows ME in the driver section. I suggest you go here, and fill out the rest of the info and have them email you direct with your solution.
http://support.lexmark.com/cgi-perl/siebelemail.cgi?ccs=229:1:0:439:0:0&category=
let us know how you make out,, thanks, Mechanic
Feb 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
Open Questions:
-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}
Oct 16, 2019 | Computers & Internet
-\&;-OPTONLINE Customer Care Phone Number #{+ I8OO-828-O294 } AB .U.S.A This Optonline USA phone number is ranked #2 out of 2 because 7,728 Optonline USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the Optonline USA Customer Care department for problems like Where to buy, Complaint, Customer care, Repairs, Returns. As far as we can tell, Optonline USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. Optonline USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact Optonline USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling Optonline USA Calling Optonline USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from Optonline USA Customer Care can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with Optonline USA's Customer Care department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare Optonline USA's phone numbers against each other. Contacting Optonline USA in General While I8OO8280294 is Optonline USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact care for you to look at as well. One thing to keep in mind as you try to reach Optonline USA help by calling them, is that other customers give their customer care at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact Optonline USA.
Oct 16, 2019 | Best Computers & Internet
Hackers apparently from India have taken over FIXYA and 6YA. Don't trust your password, credit card information, or personal information here. This Comcast USA phone number is ranked #2 out of 2 because 7,728 Comcast USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the Comcast USA Customer Care department for problems like Where to buy, Complaint, Customer care, Repairs, Returns. As far as we can tell, Comcast USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. Comcast USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact Comcast USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling Comcast USA Calling Comcast USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from Comcast USA Customer Care can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with Comcast USA's Customer Care department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare Comcast USA's phone numbers against each other. Contacting Comcast USA in General While I8OO8280294 is Comcast USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact care for you to look at as well. One thing to keep in mind as you try to reach Comcast USA help by calling them, is that other customers give their customer care at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact Comcast USA.
Computers & Internet Logo
29 people viewed this question
Ekse
Alun Cox
