Question about Brother MFC-8440 All-In-One Laser Printer
Brother mfc8440 clicking sounds while printing
I started using a refurbished drum about a month ago. Now it makes a loud clicking noise when it prints. Help please!
Thanks!
I had the same problem when I used a refurb toner cartridge, had to replace cartridge with oem for it to print. After a while started making same noise, had to take it in to have parts replaced. Now I don't take any chances on non-oem parts, it's not worth it.
Posted on Apr 16, 2008
SOURCE:
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
I have an HL-5280DW it keeps making this loud ticking sound when I go to print and it said to replace the drum and I did and it continues to make the loud ticking/popping sound. What should I do?
Take out the drum and toner shut the door and power up, if the noise is still there during the power up short run, you probably need a new fuser. If the noise goes away with toner and drum removed you probably need a new toner. New ones, especially generic toners are too hard to turn and make that noise.
Jan 25, 2010 | Brother HL-5280DW Laser Printer
Mfc8440 won.t print. can't cancel
Hi, prossible cause, tray not seated properly. If it is not seen by the mfc it will remain in manual mode.
Jul 24, 2009 | Brother Office Equipment & Supplies
HP Color Laserjet 2840 now makes ear-splitting whine every time
Did the noise start right after you replaced a toner? If so it must be a bad toner which is causing the gears to grind. If this noise happened out of the blue then it might be a bad fuser drive gear which is the gears that connect the fuser to the machine.
Jun 25, 2009 | HP LaserJet 2840 All-In-One Printer
Making a clanking noise when printing
Could be a fuser gear is broken or a Toner gear is about to break. Needs TLC by a Authorized Tech.
Feb 11, 2009 | Brother MFC8440 Remanufactured Laser...
Replaced printer drum but still printing with vertical lines
Hi dermtex,
since the faint lines are vertical, I think there is some thing distored the laser beam, try clean the lenses of the laser unit by clean soft cloth.
hope this helpful for you,
thanks
Hamedo
Aug 18, 2008 | Brother HL-2070N Laser Printer
Brother MFC-8440 All-In-One Laser Printer Logo
420 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
