Question about IBM ThinkPad T42 Notebook
Screen shakes and it freezes
When I start my T42, sometime the screen shakes a bit (even in BIOS mode) and then it freezes up. I am able to sometime start up all the way into windows but a slight movement of screen and it's gone. What could be wrong?
  • campmjc Sep 11, 2008
    I am a tech working on a t42 that has the same problem, screen will sort of glitch and become fussy while shaking, at the same time it locks up. This will happen under windows, bios, linux or diag tools, Changed the memory didn't help. It is not a problem with the lcd cable this is a serious hardware issue. It also will not boot for sometime after being shutdown from this problem.
    I'm going to suggest a new laptop. Tools I used finished a processor test but found no problems.
  • 100park Dec 26, 2008
    I have same problem on a T41. Pretty sure it's the hard drive. I took it out and reinerted it and the PC reboots but will freeze up again if I move it. Also discovered that by pressing down on the top of the front right surface - directly on top of the hard drive - it will also reboot just fine. Some connection must not be tight. Any suggestions short of taking it to an expert to repair (may be inevitable) would be appreciated.
I have the freezing problem as well i have taken out the HD and still freezes comp is in shambles adn connections look good. I discovered it is only when you press on the left side palm rest it will freeze. I removed the pi slot it did ok for a very short time! Still freezes just wondering if I put something under the mb and the case it will quit flexing! not sure though.. I know its not the PS and the HD and the connections.
Posted on Mar 12, 2010
Try pulling the battery and just running off ac power, I did this and it fixed it. Tested my battery with a meter and it was running high at 12.43 V's on the cells, Nominal is 10.8. Thanks Abrsvcs for suggesting psu.
Posted on Sep 11, 2008
  • Davor Aug 30, 2013
    I second this. I had an T60p with unexplainable freezes wher everything would just freeze with no reaction to keyboard, mouse etc, with screen staying the way it was. Luckily, I thought, I had another T60p with broken screen so I tried replacing everithing from motherboard onward. Didn't help.
    Then I read this comment and pulled the old battery out that wasn't good anyway and it works now.
  • 4,234 Answers
For a T42 the video connection at the motherboard side is held in place by a screw down plate. It is possible that the ribbon connection at the panel end is a bit flakey, but unusual. I would look more for a power supply problem within the laptop itself. I have seen a few of this type of problem and it is rarely the cabling.
Dan
Posted on Mar 19, 2008
  • 47 Answers
If moving the laptop causes it to freeze, it is almost certainly a hardware problem, and not one you want to mess with too much (something may short). Off to the service center!
  • 61 Answers
I suspect a possible loose contact between the ribbon connecting the motherboard module to the LCD display module. if you can open up the laptop, check if the both the ends are snug and tight.
TOSHIBA SATELLITE L505D LAPTOP MOTHERBOARD V000185210 AMD start ok then freeze after seconds no any action what could be the reason ?
This problem occurred when your processor goes overheating due to fan and heat-sink problem.
Solution is that just clean your fan and heat-sink and then replace them. When you will start your laptop after this small service, the problem will has been removed.
Good Luck
Aug 14, 2012 | Toshiba Satellite Computers & Internet
My IBM ThinkPad T42 screen does not turn off when i close the lid
there's a small switch usually located physically on the body of the laptop or sometimes on the inverter called a close lid switch. it may have gone bad, you can either try to replace the inverter to see if it helps or you can look for that physical switch
May 03, 2012 | IBM ThinkPad T42 Notebook
Having problems with my laptop theres white lines that goes across my screen and freezes my hole laptop and when i try to turn it on sometimes theres nothing that even show up on the screen
Restart your computer in same mode and see if you see the same issue.
To do this tap the F8 key as soon as the laptop begins to start.
If you see the same problem even in safe mode it might be problem with your laptop screen and might need to be serviced at the service center
Aug 18, 2011 | Computers & Internet
It is stuck in a loop the screen goes from the IBM logo to a screen explaining that windows didnt start successfully to windows starting up to a blue error screen and then repeating.
You can have your T42 working again by doing the following:
1. In the windows didnt start succesfully screen choose to boot in safe mode with command prompt
2. when it starts, enter the command chkdsk (that means check disk)
3. accept all the changes done by running the command above and restart your laptop
4. everything should be OK now
Aug 07, 2011 | IBM ThinkPad T42 Notebook
Freeze and black screen after re-boot
Go into bios screen and set the settings to optimal default and save then try again. if this gives you no results try f8 at the windows starting screen and safe boot if this allows you to enter window in safe mode your problem is outdated drivers. try any old vga video card and again see if you can enter windows normaly. and remember do not get frustrated this is how we all learn how to fixya.
Sep 22, 2009 | Computers & Internet
IBM T42 gave fan error, replaced and can not get it to reboot
make sure the fan is pluged in correctly and you didnt unplug anything else such as memory or etc or bump the cpu... did you put any thermal paste on the cpu when you put the fan on it? its needed to bond the too together to make a better cooling system there maybe a setting in your bios to disable fan monitoring or cpu temp etc have to look at your bios to see
May 27, 2009 | IBM ThinkPad T42 Notebook
XP won't load onto hard drive.
Start the computer and press the f8 key as if to start in sage mode, but select the "Disable system reboot on error" (not sure of the exact wording on that). Then when the BSOD hits it will stay there so you can get the error number and message.
Alot of times these are memory errors so I would also suggest that you download a program called memtest 86. It is a small ISO file that will create a bootable cd to test the memory. You can get it from:
http://www.memtest86.com/download.html
Hope this helps
Apr 20, 2009 | HP Pavilion dv8235nr Notebook
Laptop freezes at windows login screen
If it's not a hardware problem, then you can salvage this computer by installing Linux on it. Mandriva 2009.0 works fine
on a T42 Thinkpad, and it's not that difficult a transition from Windows.
Feb 19, 2009 | IBM ThinkPad T42 Notebook
Inspiron B130
Well start a bit slower then.
go into the bios at startup F2, and navigate around does it freeze there. if no then
start windows in safe mode F8 when windows logo shows.
freezing ?
If its not freezing then turn off the startup programs.
Start/run/msconfig and then uncheck load startup items
and start normally, click the dont show me this again /ok
any freezing.
If its freezing you may have a hardware issue.
if you have 2 sticks of memory remove on and or /reseat them
boot the dell diagnostics cd and check the cpu and memory.
report back
Jan 30, 2008 | Dell Inspiron B130 Notebook
IBM ThinkPad T42 Notebook Logo
895 people viewed this question
Top IBM Computers & Internet Experts
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
Jax Planet
Jax Planet
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
