Question about Cameras
HI, the camera was hanging on back of a chair with the strap and slip off to the Tile floor. The camera takes pictures but, lines come across the screen as soon as the picture is taken. My wife has down loaded the camera and relayed that all the pictures taken after the drop either have the lines or just didn't take at all. The drop to the floor was probably 18" to 24"
  • 790 Answers
Hello ,
Guess the lens has damaged !! better take it to a technician!!!
Posted on Mar 24, 2008
  • Kanth raj
    Kanth raj Mar 24, 2008
    Switch on the cam and blow air with ur mouth with full pressure into
    the gaps between the lenses. Then give a gentle whack to ur camera on
    all the sides. Later switch off and then on ur camera. It works as
    usual and u can now take ur pics. Just clean the gaps b/w the
    lens again with a vacuum cleaner in its "Low pressure" mode. Its works
    awesome.
    What i warn is don't hit the camera too hard and don't blow the air on to the lens !!!
What best flooring for kitchen large dogs
Better Ceramic Floor Tiles where can easily clean.
Apr 13, 2015 | Building Materials
Tip
Ceramic tile installation
To Start a Ceramic Tile Project:
1st: Figure out the Size of the Room-Length x Width. This will give you the suare Footage of the Room, and will Determine the amount of Materials You will need for Preparation of Floor before Tile Installation.
2nd: Pick out the size of Tiles, and the Color you wish to Purchase(Decide if it is a High Traffic Area) Tile Comes in different Grades, and if a High Traffic area, you will need a Higher Grade Tile.
3rd: Materials needed for Preparation- Hardy Backer Board(1/2"-3' x 5'). HardyBoard Screws, Unsanded Mastec, Spacers-Depending on Tile Spacing/size of Tiles, 1' x 4' boards. (Tools Needed- Drill, Chalkline, Measuring tape, 3/16 x 3/16 Trowel, 1/4 x 1/4 trowel).
Installation; )Preparation) 1- Apply a 3/16 x3/16 trowel of Unsanded mastecon floor before laying the Backerboard. Screw the Backer Board to the floor recessing screws. (Never have Backerboard meet with 4 pices meet together, off set each piece of backerboard during Installation). After sweeping the room, use a trowel to fill screw holes with unsanded Mastec. Tape all Joints and fill with un-sanded Mastec.(Let Dry for 24 hours).
Tile Installation:- 1st- Sand Mastec used for joints, and screw holes. 2nd- Sweep roome very good and vacuum very well. 3rd- Measure each wall to find the Center Point of the room.(I prefer nailing a board down across one side of the line to keep tiles straight, and butt tiles to the board, and put spacers in between tiles). I use a 1/4" trowel to butter tiles before laying. With using Spacers, buttering tiles, laying tiles.( I prefer using a 2 x 4 and tap tiles across with a rubber Mallet to keep all tiles same heigth). Let One side tiles laid for 24 hours. 4th- Then do the same thing with other side of line.
Finishing Project: Once all the tiles are set, and all spacers removed. Mix up color of Choice unsanded Grout, and follow Manufacturers mixture Specs. Use grout Float and fill Spacing between Tiles. Let dry for 15 minutes. Use bucket of Clean water and Big sponge rinsing frequently removing all Grout from Tiles. Let dry for 30 minutes, and clean tiles again with Clean Water. Let set overnight. Next day, take Clean towel and rub haze off the tiles. Lastly, Seal Tile and grout.
Enjoy your project, and the Satisfaction of doing it yourself. Hope i was some help!!
on Feb 06, 2012 | Ridgid Saws
Can plywood be glued to tile floor before laying vinyl planks ??
There are cement based compounds on the market that will allow you to just go over top of your tile floor. Make sure your tile floor is not loose anywhere, clean the floor well and use a patching compound over the existing tiles (this will fill in the grout lines and any uneven areas of the tile). It may take a couple of coats, maybe even 3 to get the floor smooth and level. You should be able to install your vinyl right on top of this and not have the added height of the plywood. If you insist on the plywood you could use a good quality construction adhesive with drilling and installing screws.
Mar 06, 2015 | Building Materials
Is vinyl floor tile strong enough for wheelchair...I am always in the kitchen, cooking
No- It may work for awhile but the wheels on the chair will cut into the tile. If the wheels are thick- over 2 inches thick and are tire type it would help. Try it out - if you see ridges on the tile- Stop- the tile is too soft.
Oct 19, 2013 | Montgomery Ward Vinyl Floor Tiles -...
Hi, I want to replace an old American Standard toilet bowl that is a 4 bolt tie down design to the floor. Can I replace this with a standard 2 bolt floor mount design? If not are 4 bolt tie down models...
If you go with the 2 bolt you will need (I presume) to drill 2 holes into the tile. put toilet in place where it will sit and mark the holes , take away toilet and drill the holes with a 7ml tile drill bit (masking tape put over the tile will help you to not slip when starting off the hole). Drill deep enough to insert 7ml rawl plugs. then place the toilet back and fix down with screws long enough to go through the toilet and 3/4 of the rawl plug. You will need; Electric percussion drill or descent battery drill. 7 ml tile drill bit 2 x rawl plug 7ml 2 x screw masking tape is handy hope this helps, Alex
May 18, 2011 | American Standard 2294.011.020 Afwall...
Odd black shadowy line across pictures.
Make sure your Camera Strap or Lens Cover is no laying across your lens.
Nov 21, 2008 | Canon Rebel XT / EOS 350D Digital Camera
White lines appearing across screen
Call toll free number for support.
Cheers!!!
Ujjwal B Soni
Sep 29, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Black line across display screen
Beyond repair I would imagine - these thing cannot usuaslly be repaired in these circumstances.
Oct 31, 2007 | Olympus Camedia C-50 Zoom Digital Camera
Dropped my camera, now it's broken.
Take the batteries out and recharge them and also look in the battery compartment for any cracks or contacts out of place. what your describing is that the camera can't get enough power to load up.
Jul 06, 2007 | Sony Cyber-Shot DSC-P92 Digital Camera
Cameras Logo
83 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
