Question about Panasonic SR-MM10NW Neuro Fuzzy 5-Cup Rice Cooker
National SR-MM10N rice cooker not working
I have been used this rice cooker for over 6 years and it worked great until
now....
I plug in the power cord, the display looks normal, menu works good.
But after I select any cooking menu, press start... LCD changes to
"H 02" in 1-2 second and no buttons work anymore.
Thanks for help!
-Jun
  • Anonymous Apr 23, 2008
    My National just did the same thing..
  • Anonymous Apr 30, 2009
    Same problem, "M02" code.
    New Friend:
I had similar problems.
There are some wires connecting the lid and the main unit. These wires run behind the hinge area and over time they got clipped from opening/closing the lid.
To fix the problem, you will have to open up the hinge unit and the top lid and reconnect (soldering) the disconnected wires.
I fixed mine more than once. IMO it's a design flow.
Again, don't attempt unless you know electrical wiring and feel comfortable with soldering. Make sure you cover the exposed wires with proper electric tape. You don't want to mix electricity with water and steam as there are much in the lid.
ChauChau
Posted on Nov 19, 2009
Service manual at
http://www.usersmanualguide.com/panasonic/rice_cooker/srmm10n
has instructions for self-test and some error codes.
Posted on Feb 21, 2009
Yes..my cooker did the same...and i have the same model. I brought mine to the local panasonis service center here in Manila ( where I live) and they say they need the service manual. I wonder where i may get one. If anyone can help me pls email me at [email protected]
Posted on Oct 27, 2008
SOURCE:
I have an ikeda 10 cup rice cooker, it wont power on
Try it in a different outlet. Does the unit have a light that comes on when plugged in? If the light is in the cord and the light is still out on a different outlet, the cord may be faulty. If it lights, check to see that the connection between the cord and cooker is tight.
Jan 21, 2018 | Kitchen Appliances - Others
Sanyo ECJ-D100S Micom 10-Cup Rice Cooker stop working. Just use couple hours ago before it stop working. It is 5, 6 years old, looks like there's no power, only clock. All buttons do not response...
I have the same problem today. I'm lucky to find this thread and fix the problem. The cooker have two broken wires. The good news is that one wire is black and the other is yellow. If both were yellow, I might have to figure out which one connects to which.
Thank you all for the questions and answers,
Liyan
Aug 29, 2011 | Sanyo ECJ-D100S Micom 10-Cup Rice Cooker
I purchased the elite rice cooker short of four months ago. I've used it 10-12 times since the time of purchase. Up until now i was in love with it, i told everyone how great it was but tonight im not so...
open the bottom side of your unit.. then check the resistance of thermal fuse, it's look like resistor which is connected to line wire, usually covered by insulator..
Sep 30, 2010 | Maximatic DRC-100 X 10-Cup Rice Cooker
Rice cooker power cord
Thank you. I resolved the problem myself. I found a power cord from my slow cooker and it works.
May 04, 2009 | Panasonic SR-MM10NW Neuro Fuzzy 5-Cup Rice...
Won't turn on after 1 time use
Mine did the same thing.. They said to return unit for replacement
Jan 04, 2009 | Oster 3072 20-Cup Rice Cooker
Rival rice cooker stopped working
Mine just did as well today. Thought I blew a fuse, but no, just not working, although it did finish the pot of rice.
Jul 10, 2008 | Rival RC61 6-Cup Rice Cooker
Rice cooker
First you have to make sure that the power outlet is working fine using a Multi Tester. Next is disconnect the Power Plug from the Rice Cooker and test continuity within the cord.  make sure those two are both working good.  next step is to open the Rice Cooker Bottom.  Again using a multi tester, Test the continuity of the Thermostat, make sure multi tester setting is on the ohm setting. reading should be zero, if reading is higher than 200 ohms, the thermostat is defective.  Which is the reason why your cooker is not turning on is due to an open in the circuitry.  Check warranty with the store you purchased it from or the manufacturer of the rice cooker.
Aug 22, 2007 | Black & Decker RC550 10-Cup Rice Cooker
Panasonic SR-MM10NW Neuro Fuzzy 5-Cup Rice Cooker Logo
2,610 people viewed this question
Top Panasonic Kitchen Appliances - Others Experts
Irene Tulloch
Colin Stickland
Colin Stickland
Are you a Panasonic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
