Home | A4tech | WOP-35PU Optical Mouse (dsa4wop35pu) | A4 tech ***-35pu mouse
A4tech WOP-35PU Optical Mouse
Problem for A4tech WOP-35PU Optical Mouse (dsa4wop35pu)
By quabass on Mar 19, 2008
Formatted my computor and know when i scroll with the scroll with the top button on my mouse the page jumps thru the screen and does not scroll smoothly like before could it be i need to install driver? i don't have the driver and don't know where on line to get it.
Please help.
Bill Z.
Same Problem
Apr 13, 2008
-   I have the ***-35PU and just finished fixing it. I found that lint/dust had gathered at the scroll wheels.
Here is how I fixed the problem. Carefully remove the 2 rear white glides at the rear of the mouse - the side away from the wire. Use tweezers and gently pry them out to expose the retaining screws that hold the top of the mouse to its base. After removing the screws, gently lift this rear section away from the base and slide it slightly rearward (away from the attached wire). Note the 2 small slots at the front of the base which receive the 2 small protrusions from the case top. Sliding the small protrusions into the slots and reseating the rear of the case is an important alignment before replacing the mounting screws during re-assembly.
Now that the mouse has been opened, use the tweezers to remove the accumulated dust/lint by the axles of the scrolling wheels. You will notice that the wheels have optical semi-conductor sender/receivers beside them. The sender projects light through the spokes on the wheels to the receiver. The dust/lint has interfered with the light path causing the unreliable scrolling performance.
Be sure not to touch, with your fingers, the adhesive side of the 2 white glides that were first removed to expose the screws. The oil on your fingers will reduce its adhesion to the base when replaced.
This opening and cleaning procedure also fixes problems with the left and right mouse button reliability problems due to mis-alignment of the top and base. My mouse also had this problem too. It works great now.-   Guest
Solution #1
posted on Mar 22, 2008
Somewhat Helpful)
jongira
Rank: Apprentice
Rating: 70%, 4 votes
check the mouse settings in the control panel, and be sure it's set to 4-5 lines, and not whole screen.
Was this helpful?
Yes
No
Popular Solutions for A4tech WOP-35PU Optical Mouse
Questions and Unsolved Problems for A4tech WOP-35PU Optical Mouse
Do you recommend A4tech WOP-35PU Optical Mouse (dsa4wop35pu)?
Answer
Answer
I have a mouse that spins the cursor in circles every 5 minutes. The the screen blanks out and... (More)
Answer
When I push the space bar instead of taking me along one space it takes me to next line
Answer
i need a keyboard for a netbook x110
Answer
I spilled a little Coke on it and the optic was fine,but one of the buttons was hung up with syrup... (More)
Answer
Horizontal wheel scrolls vertically, how du I get it to scroll horizontally? All settings seems to... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For A4tech WOP-35PU Optical Mouse:
Top Keyboard and Mice Experts
Rank: Guru Guru
Solutions: 14110
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Keyboard and Mice Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
