Question about Canon Powershot SD450 / IXUS 55 Digital Camera
Wet Canon Camera
My Flash camera got wet and now the Flash wont work
  • marjiegray20 Jul 25, 2008
    when I hit the flash function switch the macro icon comes up and I can not override the flash or turn the flash off.
    When i view the pictures i've taken and want to view in the order I've taken they can only be seen in the reverse order.
  • 477 Answers
You have eather a damaged bulb or flash circuit. The flash circuit can be replaced easier than tring to solider on another bulb those thinks can sometimes be a pain.The flash circuit is normally held in by two screws after the case is removed and is connected by a ribbon cable. WATCH out for the compasitor that thing can shock the stuffing out of you lol take it from someone who knows lol. anyhow once that is replace the flash should work if it does not then you mainboard is damaged and that will have to be replaced.
Posted on Mar 19, 2008
SOURCE:
Camera has died after getting cold and wet. How can I get it to restart?
Hi A Strootman,
How did it become wet? Was it rain, snow, or salt water. If salt water you may be in for a big repair bill. Most digital cameras do not do well in rain, nor in very high humid locations as well. You may need to have a CLS performed by Canon.
Jan 31, 2016 | Canon PowerShot ELPH 530 HS Digital Camera...
Camera wont flash
Need to open and check the flash ciruit, possible that since this was wet the inverter circuit was damaged. Use a iron to solder if there is dry marks on components. Check power to the flash board when triggered, if not the control board is faulty.
If power is present without any flash then you will need to confirm the driver working or else it is damaged.
Oct 01, 2011 | Kodak Easyshare C182 12MP Digital Camera
Wet camera
It's possible to let it sit for few days either in a warm temperature and hope that it will turn back on or send it back to the manufacturer to be repaired.
If the unit was on when the camera got wet, it's very possible that it may have shorted or fried certain components. I would take out the battery, put a fan against it or let it air dry and try to turn it back on in the next couple days.
Nov 07, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Water problem with canon digital camera
u must let it dry if you did not remove the battery when the unit got wet then its a goner water damage sends electronics to there grave fast! if battery is left in the gold and copper traces start to corode ! and in minutes not days!
Aug 29, 2009 | Canon PowerShot A95 Digital Camera
Camera got wet. Now, the shutter is slow when the
Sorry to say you that electronic main enemy is wet. You may consider your camera unserviceable. However, try these two actions:
1). put your camera so the sun can warm it and facilitate some evaporation. Keep the battery compartiment open.
2). Remove the lens. Use a hair dryer to blow in a warm air into, CAREFULLY to avoid dust to enter in the camera. Also blow warm air into the battery compartiment.
If the camera doesn't works, consider to carry it to a service center.
Good luck, and sorry
Aug 06, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Flash is not working
Check and snug tighten all the screws around the perimeter of the case. Canon digital elphs use some of the case screws as a safety switch to turn off the flash if missing (thus preventing electrical shock from the flash if the case is opened). If this doesn't correct the problem, then you may be experiencing more severe internal corrosion problems that you cannot fix yourself.
Jul 20, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Camera got wet and is now showing a e-18 message
e18 is a general error code for canon. if you got from best buy repost if you got the accidental plan from them
Apr 29, 2008 | Canon PowerShot A75 Digital Camera
FLASH WONT TURN ON
You can try cleaning the terminals in the battery compartment with a pencil eraser (a good idea in any case). Otherwise, I suspect hidden damage or fault. If not an expensive unit, replace it.
Feb 10, 2007 | Canon SPEEDLITE 580EX TTL Flash
Open Questions:
Canon Powershot SD450 / IXUS 55 Digital Camera Logo
145 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
