Question about SanDisk Sansa e140 MP3 Player
Can not access device neither directly nor via PC
When I turn the power button it goes through language set-up (English) and the the message is displayed:
"Not enough momery (sic!) connect to PC and delete 4M of songs for Sansa system files"
When I hook-up to PC I can not access the drive, error message is:
"E:\ is not accesible
The request could not be performed because of an I/O device error."
I have tried different computers, cables and USB ports.
  • kermitose Apr 18, 2008
    My problem is exactly the same.
  • Anonymous May 21, 2009
    me too :(
I have the same frigging problem with mine. What's the solution?
Posted on Jun 11, 2008
Change language from spanish to english
Try going to your menu button or setup button on the remote. Look for the word "Idioma". That is spanish for language. Once you select ENGLISH to change, make sure you follow the exit instructions so it will be memorized
Mar 31, 2016 | Magnavox 39MF412B/F7 Widescreen 39 Class...
My GPS only shows a "non" English language. How do I fix this?
Hi
You did not mention which gps systems do you have. Anyway giving you details of tom-tom gps language change instructions.
Change the language settings on your TomTom GPS device. If your TomTom GPS receiver is set to the wrong language, change the current language to the language of your choice. Perform a reset on the device as described in Step 1. When your GPS unit turns back on, tap the button in the lower right corner of the screen to continue. Tap the next screen to access the GPS receiver's main menu. Tap on the wrench icon to access the "Change Preferences" setting screen. Scroll through the "Change Preferences" screens until you see the "Change Language" icon, identified by three flags. Tap the "Change Language" icon and choose your desired language from the list. Depending on which language you chose, you may be asked to choose a new voice for turn-by-turn navigation.
For Garmin device:-
Try this below
Touch the Wrench icon which is located on the screen with the Magnifying Glass and Map icon
Touch the down arrow
Touch the Lips/Mouth icon
Touch the top right blue box
Touch the up arrow until you see American English
Touch American English
Touch OK
This should now be in English.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 07, 2011 | GPS
Change language setting back to english
Hope you got it working already. If not, unplug the power supply (the black box behind the printer where the power cord is attached) with the power cord still attached to it and the other end still plugged in to the power outlet. Hold down Start and Cancel buttons at the same time. While holding down the buttons, plug the power supply back in the printer. Continue holding down firmly the two buttons until English language selection appears on the screen. Then, let go of the two buttons and set your printer like your setting it up for the first time - choose language, set the time and date. By the way, this doesn't change network settings in the printer.
Mar 31, 2010 | Lexmark X4650 InkJet Printer
Change language ,send pictures via bluetooth on touch diamond 2
In order to send pictures from your phone to other devices via Bluetooth, the following steps should be taken:
• Access your phones picture library
• View the picture you want to send
• Hit the menu button
• Select “Copy” from the menu list
• Chose “Bluetooth”
• Hit “Yes” when it asks you if you want to temporarily turn on Bluetooth
• Select “Look For Devices”
• Once your phone finds the device and lists its name, you select that device name
• The receiving device is then prompted to accept/reject my file
• Once accepted, the picture is sent (takes about two seconds)
Jun 21, 2009 | HTC Touch Diamond Smartphone
Lost remote control. can't change language
It is always more difficult to operate the menu features of a tv using the manual buttons on the tv. I recommend you unplug the ac cord of the tv from the wall for a day while you go out and buy a universal remote control. After plugging the tv back in and turning it on initially most television on screen prompts immediately direct you to the set up menu which includes setting the language.
Follow the instructions on the universal remote and program the remote to the tv using the power button on the remote to determine if you have reached the right code. It will then be possible to operate the menu features of the tv via the remote control and thus change the language back to english.
Apr 28, 2009 | Hitachi C21 F800S TV
A student has reset the menu to Russian.
My company uses nothing but HP printers some are connected to the network while others are locally connected to a computer. I have worked with this exact model.
First, the easiest thing to try is to power cycle the printer. Hold down the button to turn off then turn back on. You can also unplug it from its power source then plug back in.
Power cycling this printer should reset the language to default (English) or it will let you select the language when it comes back on. If that doesn't work then you can try to change it using the installed software.
Considering the fact that someone accidentally changed the language, I am assuming this printer is connected directly to a computer that you all have access to and this is not a network printer.
If this is a local printer (connected directly to the computer via USB or parrallel port) then you should have an HP Toolbox app or some other program that allows you to configure software related settings for the device. Open this tool and you should find an option for the language. This may not be available, depending on how the installation was handled (if it was installed using the CD provided by the manufacturer or installed using downloaded drivers).
Try this out and let me know if it helps.
Mar 26, 2009 | HP Color LaserJet 2600n Printer
Change language settings htc diamond
my phone is in danish languages how can i changes it to english?pls help me plsssssssss
Mar 25, 2009 | HTC Touch Diamond Smartphone
Htc touch only with Russian even after i switch to English
pls try to hard reset the device pls backup ur data b4 doing it and take out ur memory card also and see if it gives u screen to select the language to english , other wise u need english rom from www.htc.com just go and download an updated rom from the site and do as directed
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if not solved then go to www.htc.com for latest English Rom update download and update backup ur data first
Feb 22, 2009 | HTC Touch P3450 Smartphone
Printer Canon MP600 turned Japanese!
There are language settings. Go to the main menu and rotate through to the pliers/screwdriver icon. (settings) Click the right button to select the icon with two sliding tabs. (device settings) Scroll down 4 selections to language selection. Select English.
Dec 17, 2008 | Canon PIXMA MP600 all-In-One InkJet...
MS access
Have you tried changing your Regional settings in Control Panel? This should change your language in all MS Applications.
Best of luck
DeltaC
Oct 11, 2007 | Microsoft Office Standard for PC
SanDisk Sansa e140 MP3 Player Logo
258 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
