Question about Samsung SyncMaster 710N 17 in. Flat Panel LCD Monitor
I have 2 samsung 710N LCD monitors that are exhibiting the same symptoms. When they are powered on, they display fine for about 10 seconds, and then go completely black. If you turn them on and off again, the same thing, regular screen for a few seconds, then black. They're both between 2-3 years old, and it doesn't matter what PC they're hooked up to, I've tried them on several, and the behavior is the same. Interestingly, if they sit powered off over night or for several hours, they will work fine for a time, but then revert back to this behavior. What component could be causing this?
  • rickenator Apr 08, 2008
    i turn the monitor off, then back on. quickly, i hit the auto adjustment button (right next to the power button) and it will stay on. is there a fix for this?
  • Anonymous May 11, 2010
    its the microchips NT68F63L problem in vga board or bad capacitors. you need to open monitor to solve the problem. Can you open the monitor?
    or
    if
    you want there is manual how to repair samsung monitors with this
    problem you can find on ebay: Repair manual Samsung monitor 710n, 913v,
    510n and more, Item number: 220389041052.
    it shows step by step reparation process.
    Scholar:
  • 36 Answers
Hi
I am a technician-informatic. I have repaired about 40 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it on eBay.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Posted on May 15, 2009
  • Anonymous May 15, 2009
    hi
    I am a technician-informatic. I have repaired about 60 Lcd Samsung
    monitors.The repair process is very easy and simple 10-30min. does not
    if you are interested check it.
    thank you
SOURCE:
Samsung Syncmaster 710N PROBLEM !!!
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 10, 2010 | Samsung SyncMaster 710N 17" LCD Monitor
My SyncMaster 710N comes on for only a few seconds then the screen goes blank. if i turn it off ,then right back on, the log on display is there , but then it goes blank again after a couple of seconds , ...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 16, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
Samsung SyncMaster 710N Monitor SLEEP MODE
The monitor is not going to sleep the power supply board is shutting down. If you can solder you should be able to repair the monitor yourself. The problem is caused by blown capacitors on the power board. Go to our web site at : www.ccl-la.com/badcaps.htm We have pictures of what to look for. Open your monitor and look at the power supply board for any blown capacitors, replace all that you find. The replacement parts can be ordered from several places on the internet or we can supply them for you. The replacement parts will need to be high temp and will be marked 105c. The values you need to get will be marked on the sides of the ones you take out but will be something like 220uf, 470uf, or 1000uf etc. and then a voltage rating. When you install the new ones be sure to insert them with the polarity stripe going the same direction as the old ones come out. If you don't want to do the repair yourself we do offer a repair service for $35 plus return shipping. If you have any questions just let us know
I hope this helps if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
Oct 17, 2009 | Samsung SyncMaster 710N 17 in. Flat Panel...
I have the syncmaster 710N. I recently had a
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
thank you
Feb 24, 2009 | Samsung SyncMaster 710N 17" LCD Monitor
Samsung Syncmaster 710n no display and no LED light
The power button should be on the FRONT BOTTOM RIGHT. and there should be a little led/light next to it. make sure everything is plugged in correctly and press the power button, the led should light up, and then boot your computer.
Let me know --
If this helped please mark this thread as FixYA
Dec 26, 2008 | Samsung 710N V2 (Ivory) 17 in. Flat Panel...
Samsung 710N
hi, try with another crt monitor to check if the display card is ok..if that works fine then u will have to take it to the service center.. let me know..
Jan 10, 2008 | Samsung 710N V2 17" LCD Monitor
hi
thank you
Oct 29, 2007 | Samsung SyncMaster 710N 17 in. Flat Panel...
Syncmaster 710N resolution problem
no,
the LCD display don't harm the eyes cause don't spreed radiation.
preferred resolution 1280x1024 at refresh rate of 60Hz is not optimal.
the samsung 710N can easy handle 75Hz at 1280x1024 so just change it.
Jan 30, 2007 | Samsung 710N V2 (Ivory) 17 in. Flat Panel...
No video output
Aung, I have also a second hand 710N, and I have the same problem. Do you reach any solution for your monitor!?
Dec 25, 2006 | Samsung SyncMaster 710N 17 in. Flat Panel...
Samsung SyncMaster 710N 17 in. Flat Panel LCD Monitor Logo
965 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
RONALD CARTER JR
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
