Question about Dishwashers
Dishwasher will not drain
The diashwasher will not drain. you can hear somthing tryin to get it to drain but nothing happens
    President:
  • 2,651 Answers
I would start by rermoving the drain line from under the sink and checkin for a clog right there.
Posted on Mar 20, 2008
Kitchenaid DW KUDS30FXSS Cycle starts then I hear a solenoid actuate 4 times then unit goes into cancel drain cycle
Here's a link for the repair manual for your dishwasher:
http://www.appliancerepair.net/kitchenaid-dishwasher-repair.html
Concentration should be on Chapter 2 subsection 2-3 "No Fill"
Then go to Chapter 6; subsections 6-2, 6-3, 6-3a, 6-3b, 6-3c, and 6-3h for testing procedures on relays, actuator valves, etc.
Nov 30, 2013 | KitchenAid KUDS30FXSS Builtin Dishwasher
So frustrated - LG dishwasher washes 5 minutes then shows OE code - have cleaned drains, sump pump, out let pipes. Still doing it. ONly 9 months old..... My old dishwasher worked for 10 years.......
Hi there Diane OE on your display relates to the water draining system (water is not pumped away). the diashwasher is not seeing the water drain away. Dishwashers start by draining before they take on fresh water. Start your dishwasher and listen for a pumping noise from the waste pump if you dont hear any noise it may be the pump is blocked or faulty. please advise if this helps kind regards gary.
Nov 08, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
GE Nautilus built-in dishwasher suddenly won't spray
micro switch at the door lock has failed. it just happened to me.
I wired it direct and it worked. just dont open the door until you get a new switch. it wont shut off
Jul 11, 2010 | GE Nautilus 24" Built-in Dishwasher
Dish washer not working, lights come on but nothing happens, will not drain water that is in there either.
flooding the sink won't have anything to do with the dishwasher.unless the check valve on the dishwasher got stuck closed. Can you hear the pump come on?
Oct 29, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher confused
i suspect this is nothing to do with switching off during the cycle.
take the bottom plate off and check if there is water leaked into the bottom pan. alternatively, if you can, tilt the machine back to 45deg and see if water runs out.
most machines have a float switch in the base so that if water leaks, all that will happen is that the drain pump runs and i think this is what you are hearing
Aug 07, 2008 | Dishwashers
Washer not cycling
I manually turned the impeller on the motor and "broke it loose". I found out if you don't use the washer for even a small period of time the motor may do this.
Jul 25, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
Maytag dishwasher wont start
Drain the water out of the dishwasher. The high water switch ius engaged, lowering the water will disengage.
Sep 10, 2007 | Maytag MDB7100AWB Dishwasher
Dishwashers Logo
76 people viewed this question
Top Dishwashers Experts
