Question about Frigidaire FWS833A Top Load Washer
Waterpump won't pump and spin cycle won't start.
Machine fills up and agitates but won't pump water out and won't spin. Door switch is ok and and timer was switched with a spare. Pump was checked and works when it's plugged in manually. What next????
Ray
  • smuggdenbz Mar 20, 2008
    when u say switch u mean the door switch? I tried that too! I bridged the 2 brown wires over and still nothing. Dam what are the odds that both timers have the same problem?
To spin the door must be latched or locked. motor will spin clockwise to pump out water. run reverse or counter clockwise when agitating.. replaced lid switch. this is not ordinary contact switch but a thermal relay type to delay lid opening latch lever
Posted on Jul 01, 2008
    President:
  • Frigidaire Master
  • 2,651 Answers
One of 2 things are happpening iether hte timer is not sending down the power to operate the pump , or switch is not closing correctly to allow power to the pump
Posted on Mar 19, 2008
Hello, I have a Maytag Bravos MVWX550XW washer that will not rinse or spin, only wash. The drum moves. I replaced the washer inlet valve, did not fix the problem. Removed the lid switch assembly...
hi Melanie.
this is all i could find out.
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
How to Drain Washing Machine That Won Drain Family Handyman
What is wrong with a washer that does not spin? If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle
Washer Doesnt Agitate or Spin
Maytag Washing Machines will not rinse or spin Google Search
Dec 12, 2017 | Maytag Washing Machines
Tip
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
on Dec 12, 2017 | Washing Machines
My washer won't spin
HI Rhonda.
If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. ... The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch.4 May 2012
SOLVED: Why won't my Washing Machine pump but not spin during ...
https://www.ifixit.com/.../Why+won%27t+my+Washing+Machine+pump+but+not+spin+...
What causes a washing machine not to spin?If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) ... 1Check the washing machine's spin cycle. If this works, the motor is operating and the belt is not broken.14 Aug 2014Washer Doesn't Agitate or Spin - HomeTipshttps://www.hometips.com/repair-fix/washing-machine-agitate-spin.htmlSearch for: What causes a washing machine not to spin?
Why is my washer not spinning the water out?If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ...https://www.ifixit.com/Answers/View/.../Why+won%27t+my+washer+spin+or+drainSearch for: Why is my washer not spinning the water out?
What causes a washer not to spin?Over time, the repeated friction of the clutch pads rubbing against the housing can cause the clutch to wear and create a scraping sound. A worn clutch can prevent yourwashing machine from spinning, or may cause a slower spin speed which will leave your clothes wet after a cycle.How to Fix Washer That Won't Spin ' Washing Machine Repairhttps://www.partselect.com/Repair/Washer/Will-Not-Spin/Search for: What causes a washer not to spin?
if you need more help go to this link.
washer won spin Google Search
Nov 23, 2017 | Washing Machines
My front load washing machine agitate but won't spin
If your machine is rather old or used quite frequently, you should check out the motor brushes. Go to youtube for details on washing machines brushes.
Mar 06, 2015 | Washing Machines
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
Washing machine will not drain
Since you've already checked the pump, hoses and motor, here are some additional issues to look at:
1. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
2. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
3. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Washing Machines
Water fills to over flowing and never starts agitate or spin cycle
With the tub empty disconnect the air hose from the water level switch in the console. Blow through it to see if its kinked or restricted. Check the air bell for a buildup of **** especially near the opening where the air hose attaches.
If all is OK reattach the hose and disconnect it from the air bell. Turn your water off and set it to wash. Blow through the hose to see if the switch goes from fill to agitate.
Jan 03, 2012 | Maytag Performa PAV2200
Washing machine refills after spin cycle
Can you hear the pump running if not the machine may be syphoning out, if the outlet is into the down pipe too far this can cause it to syphon. The outlet should only be into it by about 6". The machine will fill with more water on the rince than the wash cycle that will cause the problem. If you can hear the pump running the machine mite be over filling there may a blockage in the presure system if you take the lid off (making sure the powers turned off) you will find a round switch with a thin hose comming off it tace the hose and you should find a small bottle this may be blocked. Hope this helps you.
Dec 22, 2008 | Washing Machines
Frigidaire FWS833A Top Load Washer Logo
140 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
