Question about Philips 30PW8420 TV
Overscan???? Picture is to big for the TV, when watching CNN etc can't see the scrolling line at the bottom. Is there anyway to correct this. I don't have a manual or the remote that goes with this TV, it was a floor model. Thanks for any help Roger
    Champion:
  • 206 Answers
Sound like it is in a expanded format. These sets have a couple of mode it can run in one is called 9X16 expand. this makes the pix to big, but you probably need the original remote with the format button on it, luckily these are cheap and be had at www.vancebaldwin.com
Posted on Mar 19, 2008
Repaired the convergence and now the image quality is good but the TV seems to be over projecting the screen. The top, bottom and sides of the image are cut off slightly. is there a way to adjust?
Hey! its me again. I think what your experiencing is called overscan. This website might help but if not just google how to fix overscan on a projection tv.
http://www.cnet.com/news/overscan-youre-not-seeing-the-whole-picture-on-your-tv/
May 24, 2016 | Televison & Video
How do I access advanced menu options so I can adjust overscan settings?
get to the on screen tv menu and look for aspect ratio change that ,save and exit
May 18, 2015 | Toshiba 32ZH46P
Overscan????
Dear customer,
            You can fix it by right-clicking on the nvidia icon in your system tray, going to "TV Out" and then in there is a box under "Screen Resolution" (I think that's what it says) where you can click to zoom in or out, or move the screen up,down,and to the sides.
           Or else your problem is  with the ratio of the signal, make sure the cable box is set to match your tv style (4x3 or 16x9)and the video output is set correctly (480p, 720p, 1080I) the set will have MORE format options on analog channels (480I) than on HD channels as the HD signal also controls the format shown by the set and also change the aspect ratio to fit your screen.. that'll solve your problem..
Apr 12, 2009 | Philips 30PW8420 TV
Panasonic viera doesn't display computer correctly
I have had what is fundamentally the same problem. I have a desktop PC that I am plugging in to my Panasonic Viera TX-32LZD80. I am using DVI connection plugged in to HDMI port.
The solution is fairly simple; use the Menu button on the TV remote to get to the Main Menu for the TV and then select Setup which should be the fourth of four options. This will get you to the Setup Menu for the TV for the current channel. Look for the Picture Overscan option, it will very probably be set to On if you have the problem of %5 or so of display being missing on all sides.
Switch Picture Overscan to Off.
This immediately should solve your problem. A note of warning on this is that I suspected this was the problem but when I first looked at the Setup Menu I could not find the Picture Overscan option.
If you are unable to find the Picture Overscan option then trying fiddling with the Aspect settings. You will probably find it set to Auto. Switch it to 16:9 and you should find the Picture Overscan option will be available from the Setup Menu.
Hope it works for you.
Mar 03, 2009 | Televison & Video
On CNN or during football games banner is cut off
It sounds like you're watching wide screen content on a 4:3 tv, so the screen may be zoomed in so that the bars that would normally be on the top and bottom are not showing. Because the picture is zoomed in, images that would be at the top and bottom are off the screen. If you're watching from a home receiver (Uverse, DirecTv, Xfinity, etc.) you need to change the video settings to let the receiver know that your TV's aspect ratio is 4:3 (full screen) and not 16:9 (widescreen). Also, if your channel lineup has the option of watching CNN on a standard definition channel, that would also help because the shape of the image would be what your tv was designed for. If you watch 16:9 programs, you will have to choose letter box mode (bars on top and bottom because the shape of the widescreen image does not match the shape of your tv), pillar box mode (bars on either side) zoomed, or stretched. Stretched will make the shape of everything appear distorted, as it squeezes a widescreen image on the sides to make it narrow enough, so that everyone will have tall and skinny heads like an old Kung Fu movie. The sharpest picture would likely be to watch 16:9 (hi def) content in letterbox mode (bars on top and bottom) so at least you get the proper aspect ratio that the sports were recorded in, and it comes from a sharper source (HD vs SD). I would just deal with the bars, because even with a widescreen tv, there will sometimes be bars because that's how programs are sometimes recorded, for different visual impact or cinematic effect.
Jun 16, 2017 | Mito Car Audio & Video
Picture not fitting on screen
Unfortunately, this is an internal adjustment that can not be done by you without voiding the warranty. Call the store and request warranty service. You should not have to pay to get this resolved.
Dan
Jun 11, 2008 | Televison & Video
SCROLLING LINES AT BOTTOM OF TV SCREEN
need replace the capacitors at side of the ic vertical marked on the , init to the big first.
Jan 11, 2008 | Apex Digital AT2708 27" TV
if your tv has a warranty take it back to where you you bought it.or check if your remote has the zoom feature,if it does zoom it back.or else you will have to call the repair man to program it for you.
Mar 23, 2007 | JVC AV-29LX 29" TV
Picture slants right to left
Hope you have fixed this problem by now, if that tv is unserviced, I mean if nobody has ever opened it, it could be a problem with the positioning of your tv, just tilt the tv in different positions and find out the position in which it will show the right fit. If it is serviced, especially yoke is changed, this is rare, it could be because the position of yoke is not aligned properly.
Dec 16, 2006 | Philips 27PT5445 27" TV
Sansui - BOTTOM OF SCREEN CUT OFF
Your problem is not a vertical alighnment or size adjustment. No, Im sorry to say its the old vertical output IC and /or the small capacitors around the ic and in the vertical circuit. If you dont have the right tools, like a soldering iron a multimeter know how to read a schematic diagram, then you should seek out a repair person to assist you in this repair.
Sep 12, 2006 | SansuiS2001 20" TV
Philips 30PW8420 TV Logo
150 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
