I have a Sanyo DP19657 tv and I'm tryinh to connect a magnavox DVD player . I can't get a signal
  • 4,234 Answers
WHat input are you using. The DVD should have both composite output (Yel) and component video (3 cables). You must select the correct input on the TV as well as make sure that the DVD is sending the video out the corresponding output. Some DVDs will only provide the output to 1 output type at a time. Update this if you need more detail.
Dan
Posted on Mar 19, 2008
  • 4,889 Answers
You should choose a different input mode on the tv... the modes to try are s-video, component and AV. Try this and let me know..
  • 1 more comment
  • eagle338
    eagle338 Mar 20, 2008
    hi did it work?
  • eagle338
    Note that all the cables corresponding to different brands may not be of the same color..
  • eagle338
    eagle338 Mar 27, 2008
    Did you figure it out?
How do I program a SANYO RMT-U110 "Moonlight" to operate a Magnavox MDV 2100 dvd player?
Apparently, your Sanyo remote is programmable in which case you can "code search" to find one that works, BUT that particular remote may not have a code for your Magnavox DVD player. You may have to try another programmable remote.
Dec 01, 2014 | Sanyo RMT-U100 RMT-U100 Tv/Cable/Vcr...
Trying to connect Magnavox MWR 10D6 DVD/Recorder to Sanyo HDTV. TV is connected to Dish network through coax. cable.
Unfortunately, the Magnavox MWR10D6 recorder can not record HD signals. It's only video inputs are coax (RF) and composite video; both are limited to 480i (SD). NTSC (analog signals) are translated to video.
Your best recording option is to connect the composite video output of the Dish receiver to the video input (yellow for video, red and white for audio) of the recorder. Then set the receiver to the channel that you want to record and set the recorder to Line In.
HD recorders may exist. They are much more expensive than the SD versions.
I wish that I had better news for you. The manual for the MWR10D6 is available from Funai here: http://www.funai-corp.com/support/om/MWR10D6.pdf .
Apr 18, 2013 | Philips Magnavox MWR10D6 DVD Recorder
Set t.v /remote to work with other components
Do you have a Sanyo Universal Remote ? If not, you program your dish 500 remote for these.
Sep 16, 2009 | Sanyo DS31590 31" TV
No video output from Magnavox VCR (MDV560VR)
You need to tune a chanel on your tv to the vcr signal, using an RF cable (aerial cable between vcr and tv). That is if your tv has an analogue tuner.
May 09, 2009 | Philips Magnavox DVD/VCR Dual Player
Connecting tv, converter box, vcr, dvd player
You will need a splitter,
pixel.gif --> #bubwrapper { position:relative; width:98px; height:113px; } #bubLyr1{ position:absolute; visibility:visible; width:0px; height:0px; left:0; top:0; padding:0px; } #bubLyr2{ position:absolute; visibility:visible; width:120px; height:0px; left:35; top:-20; padding:0px; } #bubLyr3{ position:absolute; visibility:visible; width:120px; height:0px; left:-61; top:-32; padding:0px; } #bubLyr4{ position:absolute; visibility:visible; width:120px; height:0px; left:200; top:-20; padding:0px; } #bubLyr5{ position:absolute; visibility:visible; width:120px; height:0px; left:-30; top:-32; padding:0px; } function showCustomPopUp(thisUrl,thisName,theseParams) { remote = open(thisUrl, thisName, theseParams); } function showEnhanced() { remote = open("/largeImage/index.jsp?LargeImageURL=" + escape(document.path.enh.value), "largeImage", "width=505,height=525,left=0,top=0"); } function verifyFields(submitProcess,formObject) { if (submitProcess == "wishlist") { formObject.wlName.value = "wlName"; formObject.submit(); } else { formObject.wlName.value = ""; ajaxAddToCart(formObject); } } function popUp(URL) { day = new Date(); id = day.getTime(); eval("page" + id + " = window.open(URL, '" + id + "', 'toolbar=0,scrollbars=0,location=0,statusbar=0,menubar=0,resizable=0,width=300,height=50,left = 337,top = 284');"); } function submitCompare(thisForm, thisFormField, prodLength) { var prodsToCompArr = thisForm.gridProductIdsToCompare.value.split("_"); var prodList=""; for(var i = 0; i #stsbubwrapper { position:relative; width:98px; height:113px; } #stsbubLyr1{ position:absolute; visibility:visible; width:0px; height:0px; left:0; top:0; padding:0px; } function showMsg(cnt) { var x = cnt; eval("document.getElementById('stsbubLyr0_" + x + " ').style.visibility = \"" + 'visible' + "\""); eval("document.getElementById('stsbubLyr0_" + x + " ').style.display = \"" + 'block' + "\""); } function hideMsg(cnt) { var x = cnt; eval("document.getElementById('stsbubLyr0_" + x + " ').style.visibility = \"" + 'hidden' + "\""); eval("document.getElementById('stsbubLyr0_" + x + " ').style.display = \"" + 'none' + "\""); } pixel.gif $10.99
prs1c-2159957t98.jpg rsk_ourexclusive_icon.gif 2-Way Hybrid Splitter pixel.gif Model: 15-1234 | Catalog #: 15-1234 pixel.gif
Use to divide a signal to feed two TVs or VCRs, or to combine signals for transmission on a single c...
Connect conv box and vcr on the two terminals and the single one to the tv.
Hope this is a Fix Ya!
Feb 22, 2009 | Philips Magnavox DVD/VCR Dual Player
Need codes for phillips universal remote
The codes I have for the Sanyo TV are:... 002, 412, 506, 619, 902
for the Magnavox DVD player they are:.... 441, 442
Jan 03, 2009 | Philips Magnavox Learning Universal Remote
Usually a cable box has a RF (antenna connect) IN (from the external signal) OUT (cable going to the TV_RF in)
Usually one has to place TV_channel on 3 or 6 (my TV ch. 60).
EXTERNAL signal goes in CABLE box RF_in, CABLE box RF_out to the TV (RF_in).
In order to connect DVD/VCR, [IN LINE with cable & TV] just connect the RF_out from CABLE BOX into the RF_in of the DVD/VCR, RF_out of DVD/VCR to the TV RF_in.
Jul 24, 2008 | Philips Magnavox DVD/VCR Dual Player
Magnavox hd2504
try turning the dvd player on,and
inserting a dvd,and then switching
to video the tv has to have a silgnal
when you switch to video the dvd
players splash screen should come
up,and then it will load the dvd
Nov 21, 2007 | Sanyo DS25390 TV
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
