Question about Xerox DocuColor 12 Printer
Error code 15-380
Error comes up as soon as I turn on the machine. Any information is welcome.
Thanks in advance.
  • citirae Mar 19, 2008
    The error code just stopped coming up when I tried starting it for the fourth time (appx 3 hours after the first 3 tries and initial error). I really appreciate the error code definition, though. FixYa is great.
    President:
  • 2,072 Answers
15-380 means the exposure lamp in the scanner is not being senses.
Open the scanner and see if the lamp comes on.
If not, most likely the lamp has failed.
If it does come on, then the sensor or processor have failed.
Posted on Mar 19, 2008
  • Rick Kasper Mar 20, 2008
    If that's the case, the lamp is most likely very weak.
    Glad to help.
I have a code error on my fisher & paykel front loader washing machine code C on can someone advise how to fix. cheers in advance
try leaning against the door when pressing the start button. door/lid switches have a habit of failing or getting out of adjustment
Sep 06, 2015 | Fisher Washing Machines
How to fix error code 0.00
Hello friend, thanks for your post!
Based off the information you provided your Electrolux washer is displaying "0.00". Typically any error code that is labeled "00" means no error code stored, which means it's a false error code. I would recommend performing a reset on your washer due erase any false error codes. You can do that by disconnecting the power from your appliance, by either unplugging it or flipping the household circuit breaker, for ten minutes.
If this step does not help resolve the problem please provide me with the new error code or if your display continues to show "0.00" I would suggest seeking assistance from a professional to come out and properly diagnosis your washer. I hope this information is helpful. -Matt
Oct 02, 2014 | Electrolux Washing Machines
F2 ERROR
F2 04 Content Improper cartridge (Destination error, life cycle
error)
Detail The destination of the machine differs from that
of the CRUM.
The life cycle information is other than "Not
used (FFh)."
Cause CRUM chip defect
Improper developing unit
Check
and
remedy
Replace the CRUM chip.
Replace the developing unit.
Identificat
ion error
The trade mark code of the CRUM differs.
The company code of the CRUM differs.
Model
error
The boot program model code does not
coincide with the CRUM model code.
Type error When the CRUM type is other than genuine/
conversion/production rotation.
Destinatio
n error
The machine destination differs from the
CRUM destination.
Data
abnormali
ty
When an error value is included in the initial
check information. When the max. toner supply
time is 00.
When the print hard stop is 00.
Misc error When the Misc information is other than "Not
used (FFh)
Feb 10, 2014 | Sharp AR-5316 Advanced Digital Imager...
Problem with Juki DDL-5550N-7 Sewing Machine, Error Code E24
El Drv se refiere a la tarjeta interna que controla el motor, est? se encuentra da?ada.
Email: ingcegadan@gmail.com
May 11, 2012 | Juki Sewing Machines
Printer showing error code 3802, says to go to kodak. com/go/aiosupport
I am new user of Kodak printer and i used to get error code 3802.
The main cause of the error 3802 is improper installation of printer driver. To get rid of this error you always ensure that properly install the printer driver.
I was looking for the solution and then found this using google. I found this link helpful.
http://printersupportsnumber.weebly.com/blog/kodak-printer-error-code-3802-its-cause-and-solution
Any other suggestions are welcome.
Thanks in advance.
Jan 20, 2012 | Office Equipment & Supplies
What does it mean when error codes P0562-0563, come up? And it has pn 68920-01,pn 32883-046,pn 67436-04. Thanks in advance for any help. Kimberly Lang
Hi Langk27, 68920-01 is the part number for the turn signal module currently installed on your bike, 32883-04 is a reflashed ignition control module, 67436-04 is your speedometer, for more information about your question please visit the websites below. Good luck and have nice day.
Harley Davidson Sportster error codes and how to access them
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 21, 2011 | 2006 Harley Davidson XL 1200 L Sporster...
The washing machine is not finishing its cycle and with washing in or out of the washing machine it still stops on the rinse cycle with the numbers one and three shoing up and a oe symbol..I have billets...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 16, 2009 | Washing Machines
Xerox docucolor 12 system fault 15-362
Fault Code 15-362 - CAUTION: The Fuser Roll remains in a cammed-up position if power to the copier is interrupted while the copier is in use. The Fuser Roll will not be released from its position until the power is restored, the Power Switch is in the On position, and the Start button is pressed again. If the Fuser Roll remains in the cammed-up position for a prolonged period of time, copy quality defects will occur. To prevent damage to the Fuser Roll, switch the Power On as soon as possible after the power is restored, and make a copy of a document. If the machine is a DC 12LP send a print job from a workstation to prevent damage to the Fuser Roll.
Apr 15, 2009 | Xerox DocuColor 12 Printer
Error code on panasonic copier fp-1670
Welcome to Fixya.
Hopefully we can answer some if not all of your questions.
An E3-01 is an error code for your toner hopper. Did you just recently change your toner bottle?
If so, open your front door, take the toner bottle out. Close the front door, turn the machine on, and let the machine cycle and stop.
After the machine is stopped, then open the door and then place the toner cartridge back in.
Close the door, and if the error code doesn't come back your problem should be fixed.
Let me know if you have any other problems.
Good luck
Please post a rating if I have helped you with your question/problem.
have a good day
Mac =)
May 20, 2008 | Computers & Internet
Hotpoint WF640
the f-01 error code on your hotpoint all in 1 washer/dryer is a short circuit code for the motor. the only way to clear the code is to have a service tech come and inspect the reason for the error.
May 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Xerox DocuColor 12 Printer Logo
929 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
