Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
PRINTING IN REVERSE-ODD PAGES ONLY
When I try and print a document in reverse order and odd pages only, it does not print page 1. (Even though I request it to print pages 1-?).
  • Anonymous May 11, 2010
    Dears,
    I own since long ago my scanner Vuego scan - Brisa 310P its details as follows:
    Fcc ID: Jvp 688700
    Model No: 6687 – 10E
    Serial No:91685241010SS7000
    Use Leader Model No: 48160900SE
    Vuego Scan- Brisa 310P
    Version 2.6
    Flatbed Scanner
    Mira Scan
    Acer Peripherals,Inc.
    After I made a format to my window ME and tried to install its program from its CD, I discovered that some files were damaged.
    I will be too much appreciated if you provide me with the way that I can install my scanner. Software installation Menu INS T 95
    Install Shield Wizard
    Thanks in advance.
    Ali Miligi
    Inter. Commercial Consultant
    Email address [email protected]
    Novelist:
    Champion:
  • 214 Answers
Go here to downlad the driver:
http://members.driverguide.com/driver/detail.php?driverid=122121
You will need to register (for free) to download.
Once downloaded - unzip the file and run Add/Remove Hardware.
Good luck.
Posted on May 11, 2008
SOURCE:
Reverseprinton hp2540
this unit prints one side of paper only
to get it to print 2 sides when you go print on a document thee will be a section that says print all pages , print this page ,print elected pages
in the print selected section type in the pages you want to print ie 1,3,5,7,9 or even pages 2,4,6,8
or there may be a section that opens up with print all pages, print odd pages ,print even pages
to print both sides select odd pages and when they have printed take the whole of the pages and reverse them in the printer feed and then select even pages and print
the operators manual will explain how to do ti.
Feb 15, 2015 | HP Deskjet 2540 Wireless Color All-in-One...
Two side print mfc-7340
i am unable to change the language from Turkish to English
Nov 29, 2012 | Brother MFC-7340 All-In-One Laser Printer
Did the Laserjet 2550L make duplex prints? if
It is called a manual duplexing option, the bottom rung of the duplexing ladder, you phisically have to take out the peice of paper after one side is printed, turn it over and reinsert it
http://www.retrevo.com/r/258bh050/38/Printing+on+both+sides+%28duplexing+manually%29#q=HP+2550L
Sep 09, 2009 | HP LaserJet 2550L Printer
When printing a large document - about 200 pages- I wish to print on both sides of the paper. I specify print "odd pages" in the hope that I can then turn over the printed sheets and print...
Two options 1. print one page at at time, ie one sid the the other or 2. print odd pages then turn over and print even pages. it is a little tricky but can be done. on print options select which pages to print separated by commas
May 08, 2009 | Epson Stylus Photo R800 InkJet Printer
Can I print double sided documents with a hp 6310 all in one?
I don't see multiplexing as an option for your printer.
The manual way to do this though is to go through your regular print procedure but choose the option to print only the odd numbered pages and then simply put the printed pages back into the printer tray upside down (after giving them some time to dry) and then print only the even numbered pages.
Feb 22, 2009 | HP Officejet 6310 All-In-One InkJet...
Hi, my name is Gabriel and I have the Xerox Phaser 4510, I would like to know how to print one page for both sides? Thank you
There ia a duplex unit that you could buy and attach to the machine.
Alternatively when you select "Print"
Select the option to print pages in the range "odd pages
When the job is finished place the printed documents in the manual paper feed and select "Print" again and the option to print all the even pages.
You will also have to check a box to print pages in reverse order or vice versa depending on the order the first batch were printed.
A bit of trial and error might be required before you get the correct solution. Hope this helps??
Dec 19, 2008 | Xerox - PRINTERS - PHASER 4510 (N) LASERPR...
Unable to configure the HP C6380 for double-sided printing
Here is the step by step right from the user manual. also here is a direct link to the manual.
http://h10032.www1.hp.com/ctg/Manual/c01527492.pdf
Let me know how it works out for you.
Print on both sides of the page
You can print two-sided pages with the HP All-in-One manually. When printing two-sided
pages, make sure to use paper that is thick enough so that images do not show through
to the other side.
To print on both sides of the page
1.
Load paper into the input tray.
2. On the File menu in your software application, click Print.
3. Make sure the product is the selected printer.
4. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
5. Click the Features tab.
6. In the Paper saving options area, select Manual from the Two-sided printing dropdown
list.
Perform special print jobs 83
Print
7.
For binding, do one of the following:
• For binding on the top like a notebook or calendar, select the Flip Pages Up check
box.
This causes the odd and even pages of your document to print opposite of each
other top-to-bottom. This ensures that the top of the page is always at the top of
the sheet when you flip the pages up in your bound document.
• For binding on the side like a book or magazine, click to clear the Flip Pages
Up
check box.
other left-to-right. This ensures that the top of the page is always at the top of the
sheet when you turn the pages in your bound document.
3 5 1
8. Click OK, and then click Print or OK in the Print dialog box.
The product begins printing. Wait until all the odd-numbered pages are printed before
removing any of the printed pages from the output tray.
A dialog box displays instructions on the screen when it is time to process the second
side of your job.
9. Click Continue when done.
Nov 28, 2008 | HP Office Equipment & Supplies
Double sided printing Pixma MP520
here's how:
print double sided pages
1. Set your computer software for double sided printing if you have a printer that is compatible. Double sided printers are generally professional style machines, and most offices, schools and libraries will have them. On a PC, go to the drop down "File" menu and select "Double Sided Printing" under the "Preferences" or "Properties" window and print. If you have a MAC, click "Copies and Pages" under the "File" menu, select "Layout" and then click on "Long-Edged Binding" and print.
2.Print double sided with your standard home printer, again, by setting your PC writing software. When you are ready to print, click on the drop down "File" menu and select "Print." From the "Print" window select "odd pages only," or "even pages only."
3.Set your odd and even pages a bit differently if you are working with MAC writing software. Select "Print" from the drop down "File" menu and click on the arrow to drop the "Copies & Pages" menu. Under the "Copies & Pages" menu, select "Paper Handling" and then click on "Odd Numbered Pages" or "Even Numbered Pages."
4.Select "Odd Pages Only" or "Odd Numbered Pages" and then print as usual. It is a good idea to mark the top of your first page with a pencil so that you know the direction and side of the page your printer prints. Use the mark to determine how to turn your pages and place them back in the printer. Select "Even Pages Only" or "Even Numbered Pages" and print again. $('.Article .Steps .Image').each(function(i,e){ e = $(e); e.find('img').error(function(){ $(this).unbind(); e.remove(); }); });
Sep 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Print Odd or even pages only
There is no option in the printer to chose eve or odd pages bout if you print under windows environment you can do that from the able cation example if you use Microsoft world go to file chose printer then chose eve or odd from print comp box
Mar 12, 2008 | HP LaserJet 4050tn Printer
Printing out of order
A couple of things you can try:
1. If you are using MS Word, try to check (or uncheck) "Collate" when you click on the File/Print command;
2. In your printer Properties/Setup/Configuration, see if you have Options or Extra settings where you can change the Output Options (Normal, Reverse All Pages, Print Odd Pages, Print Even Pages). Determine which will work to your preference.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 13, 2008 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
85 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
