Question about Optoma MovieTime DV10 Multimedia Projector
Apple Macbook pro video out to VGA port ("d-sub") on Optoma
My MacBook Pro recognizes that it is connecting to a DV10, but the projector doesn't see any signal coming from the Mac. I have the appropriate DVI to VGA adapter cable and have connected to the back of an HDTV and the connection has worked fine. So, am I missing some little step, or is there some kind of random incompatibility here, or what?
  • 6 more comments
  • Anonymous Aug 28, 2008
    Same problem with an ibook g3. No solution still?
  • Logofet Nov 28, 2008
    Same problem. No solution found yet.
  • rlguertinbie Jan 20, 2009
    so frustrating!
    has anyone figured out a way around this? a different way to conect? perhaps with some sort of s-video adaptor?
  • Anonymous Mar 19, 2009
    same song here
    hi, I just bought a hd700 and the same thing happened. no signal from macbook pro to projector. it seems to see the image in the background, but when I try to detect the display, it doesn't work.
  • delhicitizen May 16, 2009
    same issue. very frustrating.
  • Anonymous Mar 22, 2014
    while i have an HDMI ti VGA cable
    while i have a hdmi ti vga cable
There's no solution. it will not connect with macbook pro or any other mac. as on the phone with all technicians and they do not know what to do. I had the unit replaced and still would not connect.
Posted on May 26, 2008
    New Friend:
I'm using a DVI to HDMI Adapter. It's working with that solution but the image on the HD700 is a bit strange. Does anybody have a solution for that?
cheers,
Flo
Posted on Jan 08, 2010
SOURCE:
What might be the problem since my macbook pro is connected to the projector through a HDMI to VGA adapter, yet the screen remains black?
Vga and hdmi are different formats. Unless you are using a coverter box that translates the data from one format to another it won't work. Vga is analog and hdmi is digital
Oct 08, 2016 | Sharp Office Equipment & Supplies
My mac book and epson projector doesn't show the signal
To my knowledge there are no video drivers to output video on a Mac USB port in the Mac OS system. There are however, devices that connect to the USB port that will give video out on Conventional (VGA, DVI, HDMI, etc) connectors.e.g. http://www.newertech.com/products/viddu2dvia.phpMost projectors connect via VGA - what Projector are you using?
Jan 19, 2012 | Apple MacBook Pro Notebook
What type of cable do I need to connect my macBook Pro to a Dell DLP MP1200?
You should be able to use a USB - 4 pin mini-DIN cable with this projector.
Mar 01, 2011 | Computers & Internet
How can i connect the macbook pro into an lcd projector, which adapter should i use....?
what are your options on the projector side?
Your Mac comes with a DVI (Digital Visual Interface) port.
Attach the DVI to VGA adapter to the VGA connector of the external monitor.
depending on the external monitor/projector, you may need different adapters.
Sep 11, 2010 | Apple MacBook Pro Notebook
What cable(s) do I need to connect a dell 3300mp projector to my Macbook Pro?
HI.... ........YO U NEED A ADAPTER WHICH IS CALLED MINI-DIV TO VGA ADAPTER....THIS ADAPTER WILL HAVE TWO PORTS ONE PORT IS CALLED MINI-DIV PORT ANOTHER PORT IS CALLED VGA FEMALE PORT (WIDER THAN DIV PORT)..NOW PLUG THIS DIV PORT TO YOUR MACBOOK AND THE OTHER ONE IN YOUR PROJECTOR ...YOU MAY ALSO NEED A VGA CABLE..
May 27, 2010 | Dell 3300MP Multimedia Projector
How can I hook up MacBook Pro with Optoma 1690 Projector? Am I supposed to hit a certain function key to get Projector to see MacBook
You may need a certain connection (MiniDisplay Port to DVI, or MiniDisplay Port to VGA). If you're connecting to an HDMI-compatible projector, you'll need an adapter. You'll also need an adapter if connecting your MDP (MiniDisplay Port) to a DVI or VGA port. Here are some helpful links:
#1 MDP Adapter Video (YouTube)
#2 MDP to HDMI Adapter (RadioShack)
#3 MDP to VGA Adapter (Apple Store)
#4 MDP to DVI Adapter (Apple Store)
http://www.radioshack.com/product/index.jsp?productId=3898890&CAWELAID=447271885
http://store.apple.com/us/product/MB572Z/A
http://store.apple.com/us/product/MB570Z/A
Mar 12, 2010 | Apple MacBook Pro Notebook
Is these a driver to get USB connection to macbook
Are you asking if there is an adapter? There actually is an adapter (USB to S-Video) that will work between the two. However, with my MacBook C2D 2.4 GHZ, I use mini DVI to VGA adapter. This allows instant laptop to projector picture and sound. You can use it for anything from powerpoint to movies or even as a giant monitor. The mini-DVI to VGA adapter can be purchased at Best Buy for less than $20. Look for it in the accessory aisle near the Apple machines. IMO, this is a priceless addition to your MacBook. I hope this helps! Please remember to vote if it does.
Jan 27, 2010 | Apple MacBook Pro Laptop Computer with...
Macbook recognizes dell projector, but not vice versa
Your Macbook should automaticaly find the best resolution, if everything was OK. Is there any HDMI input on the dell projector? What projector is it? Is there is an HDMI input, you can use a HDMI to mini DVI cable: better picture and sound than VGA, and will probably solve your problem
Jun 26, 2009 | Apple MacBook Pro Notebook
Macbook pro + IBM m4000
Depends on the connections you have on both. Most MacBook Pros have a DVI connector on the side. If the IBM projector takes that sort of input, then all you need is that cable.
If the IBM projector has a VGA input, then you'll need an adaptor from DVI to VGA.
(VGA input is standard monitor looking connector.)
Jul 26, 2008 | Apple MacBook Pro Notebook
Optoma MovieTime DV10 Multimedia Projector Logo
3,247 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
