Question about NetGear WGR614 Wireless Router
Security lock I'm trying to "lock" my Netgear wireless connection but don't know how.  I'm trying to get to the Netgear screen by typing in http://192.168.0.1 but it's not doing anything.  I have a Macbook.  Can you please help so that nobody will piggyback me anymore?
  • 667 Answers
If it doesn't come up with user and password screen do a reset to factory defaults. Here is a link for your manual. There's a version number after the 614 I believe it's on the bottom. Just choose the correct version for manual and ifo and firmware. The NAT's will protect your network but read the manual. Not very hard. Please rate if helpful. Thanks. http://kbserver.netgear.com/products/wgr614.asp
Posted on Mar 19, 2008
SOURCE:
I am trying to connect a hp photosmart wireless all in one B110 series copier/scnner/printer and its asking for a passphrase I presume the one that my young man usd to connect the wireless modem(Netgear...
Most likely you don't. But, you can create a new one if you know the password to the router. Most Netgear products use admin as the user name and, by default, password as the password. Out of the box, the address of an N300 is 192.168.1.1 If you open a browser on a WIRED connection and type in that address, it will open a box to log into the Netgear. If you can't remember THAT password, then you only recourse is to reset the router and start over.
Once you log into the router there's a tab down the left side that says Wireless Settings. In it, you will have a list of the wireless security and, if WEP the passphrase will be displayed. For any other type of security, just pick a new one. Instructions are on the right side of the screen if you need help.
Carl
Aug 27, 2011 | NetGear N300 Wireless Router
Can't be able to connect internet by wireless
netgear wireless, first thing we need to make sure is that we are connected hardwired to the router. after ensuring that we are connected. try to open a browser, be it internet explorer or mozilla firefox.
after you have the browser on your screen try to go to the address bar and type in there 192.168.1.1 the username is always "admin" all in lower case, and the password is the word " password " itself. all in lowercase. after successfully accessing the netgear page, try to check the leftside of the screen and look for wireless settings. and click on it. then look for network name, type in, or create your own network name there. next is look for security options. and make sure to choose WPA-AES(TKIP) after choosing it. type in your passphrase now on the box below it. make sure its 8 characters and longer. then click on apply settings. this would take a couple of minutes. after its done applying the settings, exit from that screen and try to locate your network name and connect. this should work
Aug 05, 2011 | NetGear WGR614 Wireless Router
What is the security key of netgear wireless connection?
Security key in side the router. To get the key you need to access the routers web interface. Please follow the steps below on a wired pc. A pc which is directly connected with the netgear router using an Ethernet cable.
1. Open internet explorer and in the address box type http://192.168.0.1 and press enter. It should ask you a user name and password. User name is admin and password is the word password. click on login or ok.
If you don’t get user name and password window with http://192.168.0.1 and try http://192.168.1.1 or http://routerlogin.net
2. Click on wireless settings on the left hand side.
3. Under the security section if the security is wep then note down the key one and this is the security key you need.
If the security is something else then you wont be able to see the security key it will ******. In this i'll suggest you to change the security key to wep, encryption should be 64 bit and authentication type should be open. In the security key one box you need to type in the security key, The lenght of the key should be 10, you can only use a-f and 0-9. For example 123abc567f. and save the settings.
Try connecting on the wireless pc.
Note: if you change the security key then you need to connect all the wireless devices with the new key.
Hope this helps you!
Rashish.
Aug 16, 2010 | NetGear WGR614 Wireless Router
Pasword protect my router how?
There are two kinds of password protection for your ROUTER;
(1) The Web Interface can be password protected by changing the default password
(2) The Wireless connection password (encryption)
Which one do you want enabled to protect your router?
Jul 27, 2010 | NetGear WGR614 Wireless Router
I want to password protect my netgear router how can i?
I assume you are referring to the wireless security - if not post back exactly what you are trying to protect from
  • if you goto this site - http://kb.netgear.com/app/home enter the model and version and in the question - ask - " how to set wireless security" - you should see a page listed
Apr 12, 2010 | NetGear DG834G Router
How can i make my wireless router connection secure? i mean for other people not to get my signal.
You need to set up network security on both the router and the computers you connect to it. Log in to the web settings page (probably https://192.168.0.1) for the router and you'll find a security tab.
Oct 03, 2009 | NetGear RangeMax WPN824 Wireless Router...
Need to protect my wireless network!
you must logon to the NetGear wireless router and setup wireless security. choose a security type usually WEP, type a key phrase or passphrase and voila, you will have to re-connect on your clients by entering the password when you get prompted for it.
Jun 03, 2009 | NetGear WGXB102 Wireless Range Extender...
Netgear locking
I'm assuming we mean wireless security?
Run your internet browser - Internet Explorer or Firefox type the router address in the address field (usually http://192.168.0.1)
Default user name of admin and default password of password
Click the Wireless Settings link in the main menu of the DG834GT firewall. There are a number of options available with WEP the most basic. For basic protection select WEP, put in a passphrase (anything you like) and the router will provide you with 4 keys based on your passphrase - take a note of the keys. When you try to connect to the router wirelessly (laptop, game console, etc) the router will require you to input one of these keys to verify your access and that should be it.
For further information to go the netgear website and have a look at the manual - http://kbserver.netgear.com/pdf/dg834gt_manual.pdf
Feb 26, 2009 | NetGear DG834G Router
Cannot get wireless connection through router
Hi MistiShay,
You did mention that it was working fine for several weeks suddenly your wireless computers stopped functioning and your getting a message that the security key in incorrect. This only means that its either your entering the wrong encryption key or someone changed the previous security key to something else. By the way what type of wireless security did you configured on the router initially was it WEP or WPA, if its WEP(64 or 128 bit) and your using a bulit-in wireless adapter on your laptop you need the default WEP key because the passphrase only works with a Netgear WLAN Utility.
Know if your having difficulties accessing the setup page of the router you may need to check on your browser settings, turn off the pop up blocker and firewall temporarily, also try another computer. Now if all fails you may need to press that reset button on your router and set it up again.
I
Jul 28, 2008 | NetGear RangeMax WPN824 Wireless Router...
NetGear WGR614 Wireless Router Logo
109 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
