Question about Dryers
DRYER NOT DRYING
CLOTES TAKING 3 OR MORE CYCLES TO DRY
  • 2 more comments
  • mr lou Apr 23, 2008
    Dryer not drying clothes.Checked lent vent and hose severything is clear.Model #rgs7648kq1 roper.
  • cabeeny Oct 18, 2008
    i have to run the dryer 3 times to dry clothes. it heats up and rotates but takes 3 cycles to fully dry. this is a whirlpool LER3624JQ any advise is appreciated.
  • mabrykim Dec 02, 2008
    My GE dryer takes two cycles of 80 minutes to dry. What needs to be fixed? It worked fine one day and the next it's been this way for about six months.
  • Anonymous Mar 16, 2009
    dryer does not dry clothes after two cycles. Lint passes the trap in the dryer and accumulates in the duct of the house. Puddles of water also appear during every cycle.
    Scholar:
  • 178 Answers
I need to know if you have an electric dryer, or a Gas Dryer. I also need the make and model # so I can properly help you diagnose the problem.
Posted on Mar 19, 2008
Dryer hot but not drying quickly.
Sounds like you have a clogged vent. Hopefully you've gotten this repaired.
Feb 25, 2012 | Frigidaire Washing Machines
Not drying as well as it was, not getting as hot as it used to, taking 3 cycles to dry towels
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
May 02, 2011 | Whirlpool Dryers
My dryer is slowly - over the course of about 2 years - taking longer and longer to dry my clothes. I usually have to run the clothes through 2 or 3 drying cycles to get them dry. What do you think is...
Usually this is caused by the heating element (s) going out.
Tear the dryer down to the elements and test for continuity through them. If one fails the continuity test, replace it.
Best regards, --W/D--
Jan 21, 2011 | Dryers
My dryer takes 2 to 3 cycles to dry my clothes.
Check the following areas to combat this issue. in most cases, this will be a Venting issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Not heating properly, many cycles to dry loads
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
3. Heating element
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
Dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Apr 21, 2009 | GE DBSR453EBWW Electric Dryer
Taking to long to dry
This could be two problems. First problem, you must have good ventilation. Blow out the dryer vent with a leaf blower or some other type of fast moving air. Also be sure that the vent on the outside isnt blocked by little woodland creatures trying to find a nice warm home. Also be sure that the vent isnt kinked or blocked between the dryer and the wall. If that doesnt work, you may have only 1 of the 2 elements actually heating behing the drum. This would entitle removing the front and drum to check. Let me know if you need further help.
Dec 08, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Dryers Logo
261 people viewed this question
Top Dryers Experts
